View Poll Results: what method do you use to charge your field battery?
I have one of those plug in home car battery chargers. 5 71.43%
I use my car's engine to charge it (the field battery, not the car's battery). 0 0%
I use the same charger I use to charge my plane's batteries. 1 14.29%
I've come up with another way, here's how I do it: (Tell us!) 1 14.29%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Old 05-04-2011, 08:37 PM   #1
FlyWheel
Ochroma Lagopus Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
Default How do you charge your field batteries?
Assuming that you use a seperate battery, other than the one that is in your car to start it, that is.
Which of the above methods do you use to put the electrons back into that big heavy deep cycle marine battery?
"Give a man a plane and he'll fly for a day.
Teach a man to build a plane and he'll fly for a lifetime"
FlyWheel is offline
Old 05-04-2011, 09:23 PM   #2
Figure.N9ne
Figure.N9ne's Avatar
View Figure.N9ne's Gallery8
Club: Mako's RC Jet Club
Send a message via AIM to Figure.N9ne
I have some humongous craftsman battery charger than I inherited from my grandfather a few years back. The thing is probably over 20 years old, but it still works and if anything, it's too powerful. Can charge my deep cycle marine battery in a 3-4 hours. Been wanting to upgrade it to one of those new-fangled peak detection systems but the craftsman just won't die.
Figure.N9ne is offline
Old 05-04-2011, 10:56 PM   #3
Friends: (18)
I've got three models with a 6S2P A123 pack, and one model with a 12S2P A123 pack. The charger is a Cellpro Powerlab 8 that can recharge that 12S2P pack in 18 minutes. This charger pulls 44 Amps out of the deep cycle battery while charging.
The source batteries is a PAIR of parallel connected 12 Volt 120 Ampere Hour deep cycle batteries, charged at home with a Sears Craftsman 10 Amp battery charger designed for deep cycle batteries.
Old 05-05-2011, 02:26 AM   #4
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Why not just connect them up to the car charging circuit? That way they will always be charged with no special steps or worried about forgetting.
They will always be fully charged every time you arrive at the field and get re-charged on the way home.
If you dont want to leave them charging constantly, just install an RV cut off switch in the charge line. Simple, reliable and cheap
I think I need a signature.
Larry
Larry3215 is offline
Old 05-05-2011, 05:32 AM   #5
Friends: (18)
Yeah, I've thought about that, but my giant scale model pulls about 60 Ampere Hours out of the deep cycle batteries on 5 flights. (As checked with putting my Astroflight Whattmeter in series with the deep cycle battery charger)
And since the field is only 20 minutes from my home, running at full blast, the alternator in my old airplane truck (Chevy S10) would never get the batteries recharged completely.
Old 05-05-2011, 05:48 AM   #6
Larry3215
Larry3215's Avatar
Most alternators are capable of putting out well over 50-80 amps. That would put a big dent in the charge level at least. Then you have the drive back to the field the next day. Id bet you would stay charged up if you also made a side trip or two in between.
Most people wont be pulling nearly that much out of their batteries on a normal basis. You are a major heavy user in that regard
Larry
Old 05-05-2011, 06:06 AM   #7
Friends: (18)
Most alternators are capable of putting out well over 50-80 amps. Id bet you would stay charged up if you also made a side trip or two in between.
Yup I am.
FYI, I just changed the oil in the S10 yesterday, last time it was changed was August 12, 2010. And I drove it a total of 647 miles to the flying field and back, and no where else in the past 6 months. (It's my airplane truck!) It's a 1991, and has 92,000 miles on it.
Old 05-05-2011, 10:31 AM   #8
Friends: (8)
last time it was changed was August 12, 2011
What about the Flux Capacity Convertor ?
I read with horror posts where a deep cycle battery is charged in 3 - 4 hrs ! I'm amazed the plates are still ok .... and would expect electrolyte to boil away.
There are various electronic ways to charge batterys via your car system and can be splitters (without diode voltage drop), relays, or charge boosters that fool the alternator to give extra ....
I don't need a field battery usually but I carry one of those emergency starter packs in the back of my car plugged iinto the 12v socket. It's good enough to run my field chargers for the smallish packs I use.
I have posted this before but will repeat again ... (I know the next as fact as I spend most of my 'other spare time' sorting out boat electrics) ....
Deep cycle marine batterys are NOT designed for HIGH AMPS load discharge or charge use. They are designed for steady moderate demand usage that takes them down below recc'd 50% capacity usage of standard cranking batterys. They have thick plates for this purpose and less surface area for electrolyte to act. Cranking batterys - your normal car duty batterys have thin plates and greater surface area to give that high ampage demand, but on dragging down below 50% capacity starts to buckle the plates.
So in theory : If you want high ampage power you should go for high capacity cranking batterys and accept that you cannot drag them past 50% capacity level. Charging them up asap. If you are a moderate or low amps demand user then a deep cycle battery is fine and can be taken below 50% ... but advised not too low !! 30 - 35% is usually ok.
Of course there are always those who prove above wrong ...
Old 05-05-2011, 11:12 AM   #9
View CHELLIE's Gallery13
Friends: (304)
I Can find nothing wrong with the above post, i need to go into the future too and change my oil, so i dont have to do it now Take careand have fun, Chellie
Old 05-05-2011, 03:19 PM   #10
Henry Sistrunk
Henry Sistrunk's Avatar
1kW  2kW
Friends: (13)
I will change mine too. It should be due by then.
Henry
Henry Sistrunk is offline
Old 05-05-2011, 04:30 PM   #11
Larry3215
Larry3215's Avatar
I did not know about the slow charge requirements of deep cycle batteries. Thanks!
Larry
Old 05-05-2011, 05:22 PM   #12
Friends: (18)
LOL
Got me, need to change that to 2010, (Another keypunch error!)
Old 05-05-2011, 05:24 PM   #13
Friends: (18)
Interesting:
My Sears Craftsman charger has both a high and a low rate, along with voltage limiting.
Think it will just be set to the low 5 Amp rate, for the two parallel 120 Amp Hour batteries. That gets it charged up in 24 hours or so.
Tags
battery charge , field , poll
Warning to anyone new to RC and Lipo batterys EpoweredRc Beginners 143 07-27-2013 10:17 PM
Sneak Peek at the NEW Cellpro PowerLab 8 Tim Marks FMA Direct 63 09-21-2012 05:09 AM
I've committed no offense against them, but 3C lipos won't charge. Ugh. syd123 Batteries & Chargers 26 01-05-2011 02:31 AM
Page generated in 0.22103 seconds with 44 queries
