Old 05-06-2011, 05:00 PM   #1
What Flyer
What Flyer's Avatar
Default Servo hookup for dual elev
Hi, I'm setting up my new Katana SR, and while its my first sport plane, its also my first plane with dual elev servos. Now I am stumped. How should I wire those with my DX7/AR7000? does the extra elev go to aux or gear? Or could i use an AR500 and a Y harness for elev?
Also is there a specific tx setup for using dual elev servos?
What Flyer is offline
Old 05-06-2011, 05:06 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
There is no pre-programed mix in the DX7. Use Pmix one or two and it will slave trim for you.
Then you will need a reversed servo to work properly.
The other option is to you use reversing Y connector with no programing.
OR - you can use two different brand servo. Futaba and Hitec/JR normal rotation is opposite.
Old 05-06-2011, 05:32 PM   #3
constantCrash
prefectionist
constantCrash's Avatar
Send a message via AIM to constantCrash
You can reverse it using the p-mix and a spare channel so you don't need a reversed servo.
I wanna be a pirate. Arrrrr
AMA - 885997
constantCrash is offline
Old 05-06-2011, 05:32 PM   #4
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (65)
Although I'm DX7 clueless, do you really have to use a reverser when mixing if you need the servo go to the opposite direction? You cant use something like a -100% setting to get a reversed servo?
Dang, if thats the case thats pretty basic stuff they omitted.
I use reversed mixing in so many places I'm actually pretty shocked you cant do it.
Nitro Blast is online now
Old 05-06-2011, 05:35 PM   #5
WAA-08 Pilot
Friends: (9)
Correct if you use a separate channel you can use Pmix 1-2 and reverse only that slave channel.
Old 05-06-2011, 05:45 PM   #6
What Flyer
What Flyer's Avatar
Thanks, guys. I'm still not sure which servo connects to which output on my rx. The arf manual shows all ports of a 7 ch rx being used but doesnt name them.
I guess this is basic stuff but I'm still new to airplanes and I dont seem to grasp it yet.
Old 05-06-2011, 05:53 PM   #7
WAA-08 Pilot
Friends: (9)
One elevator servo goes to elevator the other to an unused channel. Then you go into the sofware - go to P-Mix and "slave" that channel (wherever you plugged in the other elevator lets say ch7) to elevator (100% both directions). Also reverse one channel so both elevator halves go the same/correct direction.
Old 05-06-2011, 05:58 PM   #8
Turner
Have a look at these:
http://www.spektrumrc.com/Articles/A...ArticleID=1798
http://www.rcgroups.com/forums/showthread.php?t=611837
http://www.flyinggiants.com/forums/s...ad.php?t=14739
Turner is online now
Old 05-06-2011, 06:19 PM   #9
What Flyer
What Flyer's Avatar
As a "visual learner", this is very helpful, thanks!
Old 05-06-2011, 07:07 PM   #10
WAA-08 Pilot
Friends: (9)
I wonder if mix 5-6 are the slaves for trim. They might be based on that doc since they recommend those mixes. You do want trim slaved for dual elevators.
Old 05-07-2011, 02:56 PM   #11
mred
mred's Avatar
45 Minute Thermal Duration  30 Minute Thermal Duration
Unless you are hurting for space around the servo, you can simply go to the other side of the servo arm and not have to worry about reversing one of them. That will reverse it for you. On my 9303 I haven't have much luck with using the gear channel and mixing them for duel elevators, so I used the AUX channel and it works great.
Ed
mred is offline
Old 05-07-2011, 05:28 PM   #12
Friends: (16)
I've got three models with two elevator servos on my DX7 transmitters and AR7000 receivers.
You need to use the Aux 1 or Aux2 channels on your AR7000 receiver. Then use either mix 5 or mix 6 for mixing the elevator stick with the Aux 1 (or 2) channels. Don't use the gear function, the gear toggle switch will still be active.
Don't use mixes 1,2,3 or 4, they don't include the trim function on the elevator stick.
Using the various trim, sub trims, and servo travel adjustments, you can match the two elevator surfaces to an exact match.
Old 05-08-2011, 12:48 AM   #13
WAA-08 Pilot
Friends: (9)
Yep I was remembering bad - shocking I know. 5-6 slave trim. Why all don't is a bit of a mystery.
Old 05-08-2011, 01:10 AM   #14
Friends: (16)
Good question.
Lets see, dual servos on elevators, dual servos on flapperons. Any other's that could use dual servos on a radio???
Old 06-02-2011, 03:38 AM   #15
Racer09
racer09
Club: no club at this time
Can all this be done on a dx6i also with a ar7000 rx or do i need a DX7.
Racer09 is offline
servo setup for elevons, flying wing lakeside1000 Delta & Flying Wings 9 12-29-2011 04:49 PM
Now I have a servo problem... CrimzonRider ParkFlyers 5 04-05-2011 06:30 AM
3S or 4S Battery Question(s) RCFlyer44 Power Systems 22 03-29-2011 04:55 AM
PZ F4u corsair-lost contact...hard landing, broke aileron servo arm-need replacement tehlump Warbird Electrics 12 03-07-2011 06:40 PM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.32208 seconds with 47 queries
