Old 05-07-2011, 09:15 AM   #1
Tom Sawyer
Tom Sawyer's Avatar
Default How do I balance charge my lipo packs?
Although I have used lipos for a while I have never balanced them....and subsequently mine seem substantially down on capacity.
Do I need a dedicated balance charger or do I buy some kind of seperate balancer device?
I have a charger called a 'pro peak quattro plus' which I assume just charges the lipos to a peak but does not balance them (it only has the 2 main charge leads)
I have several different lipos (most are over 4 years old) all with different balancing plugs so how do I choose the right balancer that will work with all of them or will I need to buy new items that are all from one sytem?
(I am sorry if this has been covered elsewhere!)
Tom Sawyer is offline
Old 05-07-2011, 09:34 AM   #2
View CHELLIE's Gallery13
Friends: (327)
Hi you can use a Blinky Balancer with your charger, its a universal Balancer, they work great, its all that i use with my lipos, normally you dont have to balance your lipos every time you charge them, every 3 or 4th time is good enough, here is the blinky Balancer. you just plug it into your balance port, and it will do the rest, its done balancing when it stops blinking, with your lipos being over 4 years old, i think they are worn out, and balancing them is not going to help much, normally a lipo will last for about 2 years before they start getting weak, hope that helps, Chellie
http://www.readyheli.com/BLINKY-Astr...r_p_32209.html
Astro "Blinky" Battery Balancer
This Battery Balancer is specially designed for Lithium Batteries. The balancer accepts one to six cell lithium battery packs.
-Now you can see if all cells are above 3.2 volts before charging (LED's will not turn on if below 3.2V).
-Now you can Balance your pack while you are charging.
-You can also Balance your pack after you are finished charging.
-This unit also allows you to Discharge individual cells that are over charged (will not allow cells to be charged over 4.2V)
Connector has 0.100 in pin spacing with 0.025 square pins and fits Apogee and other brands. Pins should be in order: red, black, black and black with no gaps or missing pins in the sequence.
Old 05-07-2011, 10:51 AM   #3
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
The Blinky work ok if the packs are not very far out of ballance. If they are in rough shape it doesnt work very well and takes forever.
Id get a better - safer - charger. Using a charger that does not balance charge is not very safe.
I recommend the FMA cellpro. Its good for up to 4S packs and is reasonably priced and is a top quality product. Its also easy to use.
Dont cheap out on the charger. Its insurance to keep you from burning down your house
You WILL need to order adaptors for each different battery brand you want to charge. No way around that. FMA offers all the current ones with the chargers.
http://www.usastore.revolectrix.com/
I think I need a signature.
Larry
Larry3215 is offline
Old 05-07-2011, 06:34 PM   #4
Ditto comments on the FMA Cellpro chargers. I've got a Cellpro Powerlab 8, that handles balancing the cells while charging the batteries.
FYI, I used an Astroflight "Blinky" on my A123 batteries for a year or so, that thing wound up killing two cells in my 6S2P battery pack. IMHO, the voltage drop on those A123 cells is flat, so the Little Blinky didn't work.
And my A123 cells got so far out of balance, I got damaged cells.
You can watch the individual cell voltages on the Cellpro chargers during the charge process. And those cell voltages stay matched within a percent or two all through the charging procedure.
Old 05-07-2011, 06:46 PM   #5
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Friends: (169)
Hi
I use one of these
http://thunderpowerrc.com/html/TP610CACDC.html
Or you could get one of these as an addon for use with most of the chargers out there
http://thunderpowerrc.com/html/TP205V.html
Take care
Yours Hank
kenchiroalpha is offline
Old 05-08-2011, 02:18 AM   #6
Originally Posted by kenchiroalpha View Post
Hi
I use one of these
http://thunderpowerrc.com/html/TP610CACDC.htmlTake care
Yours Hank
That looks nice, especially with the dual 100/220 VAC and 12-18 VDC inputs.
Mine requires a high powered power supply to get a high charging rate. Picked up a 25 Volt, 25 Amp power supply from www.mpja.com that does the trick. That's 625 watts.
Old 05-08-2011, 02:28 AM   #7
kenchiroalpha
Friends: (169)
Hi Denny
Its been working out very well
Im a big advocate of their batteries as well
At least 70 % of my battery packs are their brand
Take care dear friend
Yours Hank
Old 05-08-2011, 07:53 AM   #8
Tom Sawyer
Tom Sawyer's Avatar
Thanks for the advice, I would agree also that the packs have probably had thier day (I flew this morning and managed 'only' 15mins in the air against 35mins when the battery was new).
Balance cable alone charge doesn't work kyleservicetech FMA Direct 4 04-18-2011 11:08 PM
Not All Balanced LiPo Packs Are Equally Balanced Swift428 Batteries & Chargers 9 03-29-2011 10:26 PM
Best LiPo Balance Charger EFE Ideas Swift428 Batteries & Chargers 1 03-12-2011 08:30 PM
11.1V 3C 1800 Lipo Charge ? nam6869usmc Batteries & Chargers 9 03-12-2011 03:26 AM
Page generated in 0.08500 seconds with 33 queries
