Old 05-11-2011, 06:33 AM   #1
View mclarkson's Gallery4
Outstanding Contributor Award
Default Quick question(s) - Brushed ESC
I recently acquired my first plane with a brushed motor - by accident (long story).
Manufacturer recommends 'at least 10A' ESC. I was planning on getting a 15A. But I have a few quick questions.
Do I have to do anything different, other than using a brushed ESC? Different Rx / servos / etc.?
With the proper ESC, I'm able to use lipos, correct?
Is this a brushed ESC? How can I tell?
http://www3.towerhobbies.com/cgi-bin...?&I=LXKZZ0&P=0
Forgive my ignorance; it's been all brushless for me up 'till now.
Old 05-11-2011, 06:49 AM   #2
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
Yes, the ESC you chose is a brushed ESC. Either GWS or an old Castle Creations Pixie 20P are about the only brushed ESCs you'll find anymore.
The main difference between a brushed ESC and brushless is that a brushed ESC only has 2 wires to the motor instead of 3.
If you click on the Tech Notes, you'll see all the specs on that ESC. It can handle up to 3S lipo, but you will need to make sure the motor can handle the volts. Most of the larger brushed motors (like a 480 or bigger) can handle 3S for a while, but it will burn out eventually.
Is there any chance you can switch out the brushed motor for a brushless? Eventually the brushed motor will die, and you'd have to replace it anyway.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 05-11-2011, 08:27 AM   #3
Thanks for the info!
I can switch it out for a brushless but I'm planning on flying it for a while with the brushed motor since that's what I've got.
This motor is a 370 with a gearbox. (Here's the plane.) I'm planning on running 1300 mAh 3S batteries, mainly because that's what I've got lying around. Is that a horrible idea?
Old 05-11-2011, 09:19 AM   #4
View CHELLIE's Gallery13
Friends: (281)
you will be fine using the 3 cell lipo on that geared brush motor, you dont want to use a 3 cell lipo with a direct drive brush motor, that will burn it up real quick
http://www.towerhobbies.com/products...tra4322_e.html
stock#
LXLHU5
Only
$59.99
Stock Status:
In Stock
Tech Notes Accessories Needed
The celebrated Bearcat is reborn as an amazing air race favorite with the 34” span 1/12 Scale Rare Bear EP ARF from Thunder Tiger! Features a 370-size motor, crash-tough foam construction, a factory-painted cowl and spinner, a 3-blade prop, sponsor logo decals and more.
  • 0.08 in. (2 mm) dia. wire main/tail gear – can be fixed or retracted.
  • Ultra-light 1.9 in. (48 mm) foam main wheels; 0.75 in. (19 mm) rubber tailwheel.
  • 3-blade propeller.
  • Factory-painted spinner.
  • Comprehensive hardware package.
  • Two detailed logo decal sheets.
  • Epoxy glue.
  • Flight-ready in several hours.
  • Limited manufacturer’s warranty.
  • Designed for intermediate/advanced pilots, with tough EPS foam construction.
  • One-piece foam wings.
  • 370-size motor with leads and red JST connector.
  • 4:1 ratio gearbox.
  • The radio compartment, which can be accessed over the wing, includes plywood servo mounts.
  • Plastic cowl, factory-painted in gold.
  • Clear, single canopy.
  • Single-servo aileron control.
Specifications
Wingspan: 34 in (864 mm) Wing Area: 221 in˛ (14.3 dm˛) Weight: 17.5 oz (496 g) Length: 29.8 in (756 mm)
Requirements: 3-4 channel radio with mini receiver and two sub-micro servos, 10A (min.) ESC, 8-cell 600mAh NiMH or 2-3 cell (2-3S) LiPo battery, Battery charger, Building
Old 05-11-2011, 09:26 AM   #5
Thanks, just double-checking. If I'd been more careful in the first place, I wouldn't have a brushed motor. Didn't want to compound the error by missing something stupid.
I'll run it 'till it quits.
Old 05-11-2011, 09:30 AM   #6
Friends: (281)
The brush motor is fine, we just all got spoiled with the brushless motors LOL
Old 05-12-2011, 02:47 AM   #7
Dr Kiwi
The motor may not last long at the very high RPM it will be turning on 3s... but so what!
I'd be more concerned about having a JST connector on it... those are rated for 2A... can survive 5A... but tend to melt beyond that.
Dr Kiwi is offline
Old 05-12-2011, 03:00 AM   #8
I'm gonna have to change connectors on the motor and/or ESC anyways. I'll prolly go with small bullet connectors (or wire nuts.)
Old 05-12-2011, 03:56 AM   #9
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (86)
solder those bullets , wire nuts will be trouble, a two-cell 30-c will give MORE than enough power and everything will last longer, You ESC may not have a low volt cut-off for lipos, (though some do) so use a timer (6-10 mins) and check voltage, use 5-gram servos to keep the poundage down,bubsteve
ps, heres the Specks,
REQUIRES: Radio: 3-4 channel with mini receiver Servos: 2-sub micro (1-aileron, 1-elevator) Battery: 8-cell 9.6V 600mAh or 2-3 cell Lithium Polymer Battery Charger: LiPo compatible Electronic Speed Control: At least 10A rating Misc. Items: Building and field items
SPECS: Wingspan: 34" (864mm) Wing Area: 221 sq in (14.28 sq dm) Weight: 17.5 oz (496g) Length: 29.75" (756mm) Airfoil: Semi-symmetrical, low-wing placement Center of Gravity: 2.5" (63mm) Back from the wing's leading edge at the wing root
Monkey Minion'air
stevecooper is offline
Old 05-12-2011, 05:51 AM   #10
Thanks. I always run a timer ... although sometimes I forget to start it. Or start it, think I forgot, and then stop it while trying to start it. Or accidentally set it to 'up' rather than 'down.' Or ...
All I have are 3S lipos, except for some tiny little ones. A quick test fit/jam of a 1300mAh 3S against the firewall balances pretty close. I'm currently disinclined to buy new batteries just for this plane.
And, with a brushed ESC, the voltage going to the motor varies with the throttle, correct? So I can reduce wear and tear by just going easy on the gas, correct?
Old 05-18-2011, 01:18 AM   #11
Anyone ever use the GWS 15A brushed ESC? It comes with a heat sink and what appears to be a super-thin sheet of rubber, the exact size of the heat sink. Any idea what the rubber sheet is? Is there adhesive hidden in there or something?
Old 05-18-2011, 10:00 PM   #12
Nada, huh? Well, not knowing what else to do, I just epoxied the sink onto the FET.
20A Brushed ESC goof up spaten Power Systems 5 04-22-2011 11:11 PM
Motor, ESC, Battery questions for a Taylor Craft Hose Man Beginners 2 02-06-2011 01:42 AM
Motor / ESC and various other newbie questions spaten Beginners 6 01-09-2011 03:07 AM
Motor / ESC and various other newbie questions spaten Power Systems 21 12-30-2010 11:20 PM
Page generated in 1.90388 seconds with 41 queries
