| Scratch and Kit Built Aircraft Discuss and share your scratch built or kit built aircraft as well as building techniques, methods, mediums and resources. |
#1 | ||
Motor E-Flite Power 25 ESC 45Amp Battery Li-Poly 3S1P 2200mah Servos Futaba S3004 Modifications: 2 Hatches - Top cowl in front of windshield, behind the main LG Changed to tail-dragger Bolt on wing CF pushrods For the main landing gear, I added a piece of 3/16" plywood just below the location of the leading edge of the wing. I drilled this to match the holes in the aluminum landing gear that I purchased. I installed (4) 10-32 tee-nuts and fastened the gear with 10-32 nylon bolts. For the tail wheel I used an Ohio Superstar tail wheel. I added a piece of 1/8" plywood to the rear of the fuselage at the bottom to fasten the tail wheel bracket. I added a piece of 1/8' balsa in front of that one bay long and taper sanded it to flow smoothly to the plywood. As the rudder configuration is unique with this model I ran a second control rod from the opposite side of the rudder servo arm to the tail wheel. I used JB Weld to fasten the 2-56 threaded rods into the end of the CF pushrods. For the wing hold downs I glued a large piece of triangular stock at the rear of the wing opening and drilled through the trailing edge of the wing and then tapped the balsa with a 10-32 tap. At the front I put in a piece of 5/32" plywood across the cabin top piece. The wings had balsa blocks glued in to fill the space between the top sheeting and the bottom of the wing. Holes were drilled and 10-32 tee-nuts installed for the 10-32 wing hold down bolts. Everything else was built according to the plans and no substitution of materials was made. Gluing was mostly Titebond, used CA and Epoxy (both 5 minute and 30 minute) where needed. Covering is Ultracoat, white to cover all the wood parts and transparent yellow, red and green for the open frame work. I was afraid of the weight as I built it and was worried how tail heavy it would be as it was designed for more weight in the nose. The final AUW came out to be 3lbs 10oz and I only needed a 1/2 oz of weight in the nose for balance. |
#2 | ||
Looks good. Could you post some close ups of the tail wheel assembly and control linkage. Thanks
#3 | ||
I will do that, it will take a day or two though
#4 | ||
Club: Springfield R/C
I like the coloring. I bet that helps with orientation. Nice looking plane. Thanks for sharing.
#5 | ||
Here are the pictures of the tailwheel, servos and pushrods. Note how I used a coffee stirrer glued to the side to hold the long antenna of the AR600 receiver.
#6 | ||
Good looking model, she'll be a lovely sight against a clear blue sky.
Apart from the taidragger UC CF rod control rods, she's pretty close to kit stock - not something you see all that often. Good luck flying her. D |
#7 | ||
Thanks Thymekiller and Dereck
#8 | ||
Excellent pic of the servo box. I wondered how to attach a tail wheel.
I really like the control rods that you have used. Are those spring loaded, kinda like little shocks? Or are they simply adjustable. Whats the brand name? Thanks for sharing. That's a very nice plane. |
#9 | ||
The push rods consist of Sullivan Aluminum Ball Connector (the Red things) 2/56 threaded rod (cut to length both ends) and CF tubing.
The 2/56 threaded rod is glued into the CF tubing using JB Weld glue, from what I have been told regular epoxy wont hold.The tailwheel pushrod has a ball connector on both ends, while the rudder and elevator have a 2/56 clevis on the control surface end. The spring you see is just to hold the "clip" over the "ball". Here is what the manufacturer says about them: HD Aluminum Ball Connector for throttle connections and internal servo arms. These ball joints are made of machined aluminum and provide a full range of motion, permitting off-axis operation. Unique spring loaded, steel sleeve holds plated steel ball firmly in place yet easily released for changes and final adjustment. They come in three sizes and three colors: 4-40 in blue, 2-56 in red, and 2mm in green. ![]() They are available from Tower Hobbies and I imagine other places. Hope this answers your question! Roy |
#10 | ||
Thanks for the additional photos. I have a couple of tricycle to tail dragger conversions planned and am looking for ideas.
#11 | ||
Turner,
I looked at a few different tail wheels and decided that I liked the Ohio superstar simplicity and the single metal tongue mounting. The "tiny" size I got included springs for attaching directly to the rudder, which would require some major modifications to accomplish on this model. For the next model I will more then likely use a Sullivan as it can be set to caster. Roy Good luck on your build |
#12 | ||
I saw the Ohio Superstars for the first time at Hodges Hobbies recently and thought they looked pretty good. I have to overcome the same problem of the H stab completely blocking the rudder. Thanks
| Sig Four-Star 20EP Kit Build | Marc | Sport Planes (Formerly I/C & Gas Conversion) | 17 | 04-24-2013 04:53 PM |
| Skyshark Hawker Tempest Build Log | Forge | Scratch and Kit Built Aircraft | 24 | 06-07-2012 01:33 PM |
| Stevens AeroModel Daddy-O 525 Build Log | Stevephoon | Scratch and Kit Built Aircraft | 229 | 05-22-2012 03:22 PM |
| $100 Scratch Build Contest "Best Looking" poll here | hillbillynamedpossum | Scratch and Kit Built Aircraft | 100 | 01-07-2012 11:12 PM |
| Mountain Models Firestorm Build | dumo01 | Scratch and Kit Built Aircraft | 36 | 04-03-2011 10:52 PM |
