Old 05-14-2011, 05:26 PM   #1
dkrhardy
Club: AMA & ECRCC & RAMM
Default IMAX B6-Pro Charger any good?
I have several chargers and none of them are very good ....read as sloooow. I do have a DC charger that is pretty good but I'd like a AC/DC charger so I can charge more easily at home. My DC does not have a plug, only alligator clips, so I'm thining a AC to DC power supply is out of the question.
I'm looking at this one.
http://www.valuehobby.com/product_de...13&item_id=197
I charge through the white connectors (balance plugs?) and this charger has one huge one. They also sell a multi plug adaptor
http://www.valuehobby.com/product_de...13&item_id=177
would I use that to charge my batteries? I use only small 1 cell, several different mAh 2 cell sizes, and some 3 cell of varioys mAh.
Anyone know about this charger? Is it capable of charging though the white plugs? Far as I know, they all do. BUT I'd hate to buy thinking one way and it turn out another. HELP?
edit: I should mention that price is a point of concern, so the ones that I've read about here on the forum are over my head.
Regards,
Don
dkrhardy is offline
Old 05-14-2011, 05:36 PM   #2
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (168)
Hi Don
That should serve your needs very well
I use one quite similiar as a back up for my main one
http://www.hobbyking.com/hobbyking/s...idProduct=6478
Take care dear friend
Yours Hank
kenchiroalpha is offline
Old 05-14-2011, 05:41 PM   #3
dkrhardy
Thanks Hank .... but my big question is will it/does it charge through the white plug as I'm doing with my DC charger? And I'll need the adapter lited above to do different cell # batts, right?
dkrhardy is offline
Old 05-14-2011, 05:54 PM   #4
kenchiroalpha
Friends: (168)
Hi Don
You can find the manual here, do check it out it should answer your questions
http://www.imaxrc.com/Products.aspx?Para=8#
Old 05-14-2011, 07:36 PM   #5
Friends: (16)
Regards,
Don
The Cellpro line, like the Cellpro 4S are pretty good. (I've got the Cellpro Powerlab 8 charger) They can charge either through the battery power leads, or the battery balance leads. The Cellpro 4S is in the same ballpark, price wise, but is DC powered only. The Cellpro chargers do their charging by balancing the cells WHILE charging. (If one cell is way out of whack, this charger will bring it up first, before charging the "good" cells.
http://www.fmadirect.com/support_docs/item_1215.pdf
You can pick up a AC/DC converter for a reasonable price.
www.mpja.com has a wide variety of AC/DC power supplies, like the one below:
http://www.mpja.com/prodinfo.asp?number=17824+PS
Or this one:
http://www.mpja.com/prodinfo.asp?number=16006+PS
These chargers are simple to wire up. Connect a 120 VAC piece of lamp cord to the power supplies marked AC input terminals, and connect your charger to its marked 12 VDC output. Might take 10 minutes, if you've never done it before.
If you're using small Lipo batteries, like perhaps under 500 milliampere hours, you could power the charger with a simple lead acid battery like those used for lawn tractors. But you'd also need a charger for that lead acid battery, so it would cost more than the power supply above.
It's a good idea to charge those Lipo's out side of the house anyhow.
kyleservicetech is online now
Old 05-14-2011, 08:29 PM   #6
I use 12v mains adaptors to my balance chargers that are supplied with alligator clip leads.
You can either plug into the same socket on charger as clip lead uses or if no socket - wire to the alligator clips.
Just make sure you get polarity right.
My mains adaptors are the ones supplied with 12v drills or rechargeable flashlights ... usually marked 12v up to 14.4v .... ( 14.4v is fine as that is what alternator on car is spec'd at - so your charger designed to run of car socket will take that fine ....)
Oh ... yes - nearly forgot .... if your 12v source - ie a car style battery is low or not full charged you will find charging of your cells slower .... so get that source battery charged up and keep it charged up ... you might be surprised at difference.
Old 05-14-2011, 09:03 PM   #7
Friends: (16)
Nice thing about my Cellpro Powerlab 8, the charge rate does not change, when varying the DC power input (provided by my 24 Volt DC, 25 Amp variable power supply) from 12 to 24 Volts DC. Don't know for certain, but suspect the Cellpro 4S is similar.
Old 05-16-2011, 09:55 PM   #8
dkrhardy
I ordered it. It is AC/DC so I can charge at home more easily. And yes I know not to do it IN the house! I'll let you know what I think of it when it gets here!
dkrhardy is offline
Show your Heads Up RC Set Up smokejohnson Heads UP RC discussion 295 04-22-2013 05:05 PM
Using the Celectra Variable Rate Charger calldaffer Batteries & Chargers 1 04-04-2011 06:07 PM
What's a good 6s, 5000mah charger larry_l Batteries & Chargers 6 02-15-2011 01:39 PM
Page generated in 0.24561 seconds with 33 queries
