#1 | ||
I've always taken for granted the position of angle direction was taken from a cockpit view forward so my planes have the motor angled down and toward the right (starboard side) but I had a conversation with another flyer today and wondered if I had it backwards because I was viewing the aircraft improperly. Regards, Hankg |
#2 | ||
Friends: (18)
You have the right idea on the down and right.
#3 | ||
Gramps,
Thanks...I thought I had it right but at 65 years old, I'm starting to second guess myself on a few things. Regards, Hankg |
#4 | ||
Friends: (18)
Hankg I know that feeling seems the info goes into the grey matter then gets lost some where along the way.
#5 | ||
Tekton Ochroma Pyramidale
Club: Lancaster County Fliers
Thrust angle is actually a rather arbitrary term. The way I understand it, a line "drawn" along the propellor shaft (the direction the prop is pulling/pushing) and extended back, or forward for a pusher, should intercept the center of lift. Too far back and the plane will nose up as power (thrust) increases, too for forward and it will nose down.
This angle is in relation to the line of level flight. Side angle is to counteract torque. Posted via Mobile Device |
#6 | ||
OK .. lets move on. The propellor actually creates a fast spiral of moving air that flows round and back along the fuselage. When it gets to the back of the plane - it hits the vertical rudder and stab ... causing it to deflect to the side ... usually to right, nose to left. Effectively yawing the plane to the left. Right thrust is then applied to the motor mount to counter this yaw. It can now be seen that it is not torque but a combo of a little bit of torque and a lot of yaw. So sayeth the Book of Aerodynamics I have on my shelf.
#7 | ||
Curmudgeon
Club: South Jersey Golden Eagles
You were on to something by mentioning starboard. The sides remain the same no matter how you view the aircraft if you use starb'rd and port as referances.
AMA 7224 -- League of Silent Flight 1832
National Free Flight Society-- Society of Antique Modelers |
#8 | ||
Thanks! t |
#9 | ||
I've no idea what the book was but the effect if spiral prop wash is explained on a number of on-line texts, such at this one: http://www.av8n.com/how/htm/yaw.html (section 8.4)
#10 | ||
Look out for that tree!!!
Club: Kitsap ARCS & E-FLAPS
I think your book is also a bit out of date
I think I need a signature.
Larry |
#11 | ||
Steve beet me to it - and with more detail
Larry |
#12 | ||
Larry,
both spiral prop wash and p-factor play a pert but on models p-factor is a relativly small contributor because on models prop speed is high, forward speed low and angle of attack generally less than full size planes. P-factor is a bigger issue when angle of attack is very high and where the forward speed of the plane is significant in comparison to the angular velocity of the prop... such as in fast flying full scale warbirds. |
#13 | ||
Retired Master Chief USN
Friends: (168)
Originally Posted by JetPlaneFlyer
Hi Steve
That there is an excellent text I highly recommend any one interested in our hobby and in aviation in general read it http://www.av8n.com/how/htm/#contents Have read it before and lost the link until now Thanks ever so much Take care dear friend Yours Hank |
#14 | ||
Just finished reading the link you posted Steve.
I could swear I had read recently that the the helical prop wash effects were less significant than the P=factor effects as far as yaw - but that reference says just the opposite. I seem to remember reading that the helical effects were actually more of a rolling than yawing force. partly because they also impact the left and right elevator halves. Was I day dreaming? |
Larry |
#15 | ||
We were posting at the same time
![]() I was thinking primarily of take off situations and tail dragers in particular. |
Larry |
#16 | ||
Originally Posted by Larry3215
Possibly dreaming on the rolling issue.. It's true that the impact of the helical wash on the tail and wings causes a rolling torque but this acts opposite to the engine reaction torque and actually helps to partly offset it... a bit like the stators in a ducted fan...
Yes, in the fixed wing world P-factor is greatest on a taildragger when the model has a very nose high sit.. But P-factor is actually a much bigger issue on helicopters than on fixed wing planes. Steve |
#17 | ||
Thanks Steve!
Larry |
#18 | ||
A 1970's classic reprint of a UK Modellers bible ! No I will not sell my copy and as far as I know it is out of print and no longer available.
They did a run of books ... Scale, Helicopters, Aerodynamics, Slope, Thermal etc. It's a treasure trove of wing sections ... NACA, Clark etc. |
#19 | ||
Most likely not day-dreaming ... but as another says - model props are generally fast rpm and low P-effect. It's same situation with large slow props vs high speed props on boats ... large slow ones impart a part roll to the vessel ... in fact dipping one side deeper in water than other until speed comes up and vessel then NEARLY evens out.
But all I can say is be careful what source quoted - and I say to myself as well ... there are online and written texts that are discrediting the low vs high pressure factors that cause a wing to lift ... all backed up with seemingly gooid scientific research ... In my humble opinion models being fast, light, high rpm motor / prop combos exhibit pretty standard characteristics when pushed .. Pull of ground too early and steep and she'll roll .. then cartwheel to LEFT. Based on prop / motor direction and fuselage wanting to turn opposite. Wings don't have enough airflow to stabilise it. It's the one killer that you see again and again and again ... honest answer : How many cartwheels in at take off have you seen to the RIGHT ? I can't remember any ! I can remember plenty of planes 'yawing to right and then left roll in' due to pilot frantically trying to fight it into the air !! In fact I can say that lack of Downthrust effects are rarely seen on ground as they usually manifest themselves when throttling up / down in flight. Sidethrust is usually trimmed out and again shows itself when throttling up / down again ... that's my observation ... maybe I'm wrong. |
#20 | ||
Stumbled on this thread trying to figure out the reason why thrust angle was needed, and the torque explanation wasn't cutting it for me.
Very in depth, and scientific, just the way I like it! |
| Lengthen nose for correct CG | SBS_Pilot | Hi-Performance and Sailplanes | 20 | 05-29-2011 06:09 PM |
| Transmitter Lipo Voltage Diodes Question | Aientonni | Batteries & Chargers | 13 | 04-18-2011 02:55 AM |
| General Help Question | jap71173 | Beginners | 5 | 02-28-2011 08:04 PM |
| R/C transmitter mods question | sschevel | Beginners | 11 | 01-07-2011 04:21 AM |
| Motor angle setting | Tenderfoot | Scratch and Kit Built Aircraft | 20 | 12-21-2010 11:29 PM |
