Old 06-01-2011, 01:28 AM   #1
DanWard
DanWard's Avatar
Default How do you work carbon fiber?
Maybe this should have been posted in foamies...but...this is my 1st attempt to work with carbon fiber as part of a foamie build so I'm not sure which wins, the fact I'm a beginner or the fact that it is a foamy build.
No problem with spar in wing, I figured that out. But I want to build some stiffener for fuselage between the flat fuselage surface and the vertical fuselage surface. I've seen this done in pictures but when I zoom in it gets all blurry and search isn't being my friend.
How do you terminate the carbon fiber where it meets the surface where you want to glue it? I'm running diagonal bracing. Do you just butt it up and glue it? There is no way to bend carbon fiber, right? So you can't bend it to make a foot at the end to increase gluing surface area, right?
Hey I had to ask. Search turned up with absolutely no "how to" for carbon fiber. Search is not my friend.
DanWard is offline
Old 06-01-2011, 01:41 AM   #2
tampaflyer
to the skies of tampa
tampaflyer's Avatar
View tampaflyer's Gallery7
Club: trac
Friends: (7)
once set, it stays that shape. but glueing it is similar to fiberglass, sand it lightly to expose some fibers. this gives the glue a better grip. if not sanded it will hold good but not great.
tampaflyer is offline
Old 06-01-2011, 03:02 AM   #3
DanWard
DanWard's Avatar
Default Carbon fiber - what glue do I use? UHU?
This foamie came with a tube of UHU POR (glue) for attaching carbon fiber. But the kit is really old, been on a shelf forever, or maybe the tube was short, not quite filled from the get go. Either way I need to learn what kind of glue I can purchase to glue carbon fiber to foam.
So I searched on here and other places and it seems Michale's cares the UHU brand and I was to purchase UHU "Creative". But as luck would have it when I got to the Michale's store all they had was UHU "Twist & Glue". I bought it but doesn't seem to be the same thing.
So what do people use? Please?
DanWard is offline
Old 06-01-2011, 03:44 AM   #4
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (87)
15 or 30 min epoxy,, use as little as possible to keep the poundage down, Gorilla white works well too,
GWS glue is the stuff I think you have,, I like it as a contact cement,, bubsteve
Name:	petty an red 510.jpg
ID:	148957 dowl spars but the same apt,
Name:	petty an red 487.jpg
Monkey Minion'air
stevecooper is online now
MSR carbon rod reinforced landing gear + permanent 250mAh Li-Po holder Thewyzardofdogz E-Flite Helicopters 1 03-19-2011 06:52 AM
Will this CARBON FIBER UM fly? S.R.G. Scratch and Kit Built Aircraft 47 02-26-2011 04:34 PM
Walkera 5g6 brushless, carbon fiber frame, linear servos Mirek001 Micro Sized Electric Helicopters 0 02-20-2011 01:30 AM
Ideas for a Carbon Fiber Wing Spar, Please? Saddlebum Scratch and Kit Built Aircraft 9 01-30-2011 04:40 PM
Wanted Wanted / Carbon Fiber Wing Tube Gohmer General RC items forsale forum 0 01-11-2011 09:00 PM
Page generated in 0.43740 seconds with 30 queries
