Old 06-03-2011, 03:32 AM   #1
mckibben
Crasher
Club: Darke county Aero Modelers Association
Cool Cut off switch help
I have been building and flying foamys for about a year. I think it would be great to have a cut off switch to the lipo battery. So when i install the lipo i can switch the plane on. And then switch it off. instead of taking the wing off before i turn the TX off. I am thinking an inline switch to cut off one side of the lipo. The switches i use in my nitro rc have thin wires. What switch can i use. And whats a good way to set it up.
Thanks Tom
mckibben is offline
Old 06-03-2011, 04:31 AM   #2
dumo01
dumo01
dumo01's Avatar
Club: Westerville Model Aeronautics Assc
Friends: (7)
Tom
it is a nice idea but the problem is that most switches will not handle the current load of putting them in the path of the battery to the ESC. One thing you might consider is an arming plug. It is referenced among other places in this thread:
http://www.wattflyer.com/forums/showthread.php?t=62311
see post # 20
dumo01 is offline
Old 06-03-2011, 04:33 AM   #3
View CHELLIE's Gallery13
Friends: (281)
here you go Tom And Welcome to Wattflyers, I read your profile, Favorite pet : Wife Thats a good one, I Love a sence of Humor in a person, Take care and have fun, Chellie
http://www.rctoys.com/rc-toys-and-pa...RS-WIRING.html
Old 06-04-2011, 03:43 AM   #4
FlyWheel
Tekton Ochroma Pyramidale
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
I like the idea of an arming switch. However could you put one between the ESC and the motor (you only have to disconnect one wire to disable a brushless, right)? In theory this would let you power up the ESC and the reciever, then check all the servos without having to worry about your plane going Veg-A Matic on you? Obviously you wouldn't get a beep, because the motor does that and it would be disconnected.
Would this work or am I just whistling the Confederate national anthem?
Flying: AeroCraft Skimmer "2212"; Tom Hunt Miss Stik Sr.
On the shelf: AeroCraft 1913 Eastbourne
Waiting until the day I become worthy: Dave Thornton Bird of Time.
FlyWheel is offline
Old 06-04-2011, 03:50 AM   #5
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (87)
the outie would still "phase" and bump around and jerk some,,,
best to made a deans switch from a male and female deans connectors, to switch + lipo lead. I use this set-up on a few planes, bubsteve
Monkey Minion'air
stevecooper is offline
Old 06-04-2011, 03:53 AM   #6
stevecooper
Friends: (87)
way down South ,,
in Dixieland!!!!!!!!!!!!!!!!!!your bub,steve
Monkey Minion'air
Old 06-04-2011, 10:27 AM   #7
Friends: (281)
Great Idea Steve Take care and have fun, Chellie
Old 06-04-2011, 04:32 PM   #8
Friends: (16)
I'd be a little careful on just disconnecting one wire of a brushless motor to disable power to the motor. Could be some of those many many ESC's on the market won't like it. And maybe fail in the process.
Old 06-04-2011, 04:34 PM   #9
Friends: (16)
Thanks Tom
You can find switches that can handle the current pulled by the ESC of a foamy model airplane. Problem is, that switch might be a fair percentage of the total weight of the foamy model airplane.
Most toggle switches don't go much over 10 Amps or so.
Old 06-04-2011, 06:10 PM   #10
Rockin Robbins
Rockin Robbins's Avatar
Friends: (7)
Wow, not rated for amperage. I'd have to get rid of those icky Deans Plugs too! EC3 FTW! Looks like trial and terror time though, with no amp rating.....
Rockin Robbins is offline
Old 06-04-2011, 09:33 PM   #11
stevecooper
Friends: (87)
I make my own putting the female right on the hot leg and wire and solder the back of the male,, cover with heatshrink or tape,,Only one pair needed not three and no added wire either,,MUCH LIGHTER!! this will handle my power 10 pulling a butt-load of Amps with no probs or heat,,bubsteve
Monkey Minion'air
Old 06-04-2011, 11:40 PM   #12
Then there are some ESC's available that have an on/off 'arming switch'... such as the Air Boss ESCs by Extreme Flight.
I have one of these fitted to my Yak 54. While the switch does not physically disconnect the battery it does isolate the RC gear and turn off the ESC so the motor cant start.
I cant understand why these switches aren't used more commonly, seems like such an obvious good idea
JetPlaneFlyer is online now
Old 06-04-2011, 11:46 PM   #13
stevecooper
Friends: (87)
Thanks,, your right,, it ain't right that they don't do that,,most my old brushed ESC did and do, bubsteve
Monkey Minion'air
Old 06-05-2011, 05:42 PM   #14
Rockin Robbins
Friends: (7)
A brilliant idea! Just like a bind plug on steroids and you KNOW it will handle the amperage you'll be using.
Old 06-05-2011, 06:55 PM   #15
slipstick
They're probably not used precisely because they don't isolate the battery so it's still taking current. So unless you unplug the lipo it will still die.
Also they do not necessarily prevent the motor from starting up. An old clubmate of mine still has the scars to prove this after his motor kicked into life despite the ESC switch being off. An ESC usually won't arm with the switch off but if at the end of a flight you just switch off when the ESC is already live....it's still armed.
If I get an ESC with one fitted I remove it immediately...I don't like that false sense of security.
slipstick is offline
Old 06-05-2011, 10:30 PM   #16
Friends: (281)
Hi RR that disconnect has a 14 gauge wire on it, if your lipos have a 14 gauge wire on them or smaller, you can use it, most lipos have 14 gauge wire on them. Hope that helps, Chellie
Old 06-06-2011, 01:42 AM   #17
Friends: (16)
Yup, the brushless ESC's are orders of magnitude more complex than the old brush type ESC. The brush type ESC basically had one Fet (or a number of Fet's in parallel). If you turned off the driver circuitry, that Fet just sat there, turned off, taking the load off of the battery supplying it.
But these brushless ESC's have a three phase driver with six Fets (or again parallel connected Fets). Turning off the driver AND the 6 Fets, with a little switch, is a problem not easily solved.
Old 10-26-2011, 01:59 AM   #18
John_
Default arming plug switch from www.sharpRC.com is a winner
Here is a winner! See these "ArmSafe" arming plug switch systems from www.sharpRC.com . Super small, even on the inside of the plane, and the actual plug is not all gangley like others. I use these on all my electric planes over 15amps. The pylon racing guys are running these at 80+ amps with 10AWG wire!! But when you get to these levels you need to be able to solder good, they have a video on sharpRC for how to solder deans plugs.
John_ is offline
Kosh's F-22 Laser Cut Kits Kosh New Product Announcements 7 03-10-2012 10:53 PM
Simple, Cheap remote switch for LEDS Davethebluessinger Night Flying 7 07-20-2011 07:32 PM
For Sale JR XP7202, Charger, R790UL Receiver, RX battery and switch harness bobskinner Radio Equipment For Sale & WTB 0 05-10-2011 03:43 AM
Futaba 9C switch mixing martyp57 RC Radios, Transmitters, Receivers, Servos, gyros 22 04-01-2011 07:21 PM
Be careful with Hobbico Switch motor mount gcedillo Foamies 1 12-27-2010 08:05 AM
Page generated in 0.54587 seconds with 58 queries
