Old 06-03-2011, 04:56 AM   #1
LETMEFLY
Send a message via MSN to LETMEFLY
Default e-flite power 10 outrunner
When I open the throttle I get a clanging jerking motion from this motor. It acts like it is having a hard time getting going.
I can turn it over by hand and there is no problems what so ever but when I give it throttle again I still get this weird motor movement.
This outrunner is brand new and has never seen air time so it has me baffled.
Bob
LETMEFLY is offline
Old 06-03-2011, 05:30 AM   #2
View CHELLIE's Gallery13
Friends: (327)
Bob
Hi Bob you may need to change the timing on the ESC, also check your solder connections on the esc to motor wires, sometimes a cold solder joint will be the problem or a loose connection, Take care, Chellie
http://www.wattflyer.com/forums/showthread.php?t=62307
Old 06-03-2011, 06:03 AM   #3
LETMEFLY
Default outrunner problems
Hi Chellie,
Ok here is what I using in my fun cub.
1. Turnigy Plush+ 40 amp esc
I have one of the turnigy program cards and I have it set up this way.
Brake--------on
Bat type----Li-XX
Cut off------cut off
Cut off voltage--high
Start mode----normal
Timing-----high
I do not want to mess around with this power 10 outrunner right now as it is brand new and still under warranty from Horizon Hobby. Now concerning the Turnigy esc I have been using it in one of my powered parachutes using a Turnigy C3542B 1250kv outrunner and have not had one problem. In this case this motor starts very slowly and does not chatter or make any un-neccessary noise.
I called Horizon and they said send it back as these E-flites are not suppose to make any noise at all. I want to see what the guys at the field say when i go this Saturday and maybe they can tell me what they think it wrong. If they have no ideas I will send the motor in and see what they find.
I will check the connections on the esc just for the heck of it. If I find bad soldering I can fix that.
Thanks for the info so far,
Bob
LETMEFLY is offline
Old 06-03-2011, 06:56 AM   #4
Friends: (327)
Hi Chellie,
Brake--------on
Bat type----Li-XX
Timing-----high
Bob
Take off the brake, start at the default low timing, and try the motor operation, your motor may not like high timing, every motor is a little different, you just have to experiment with different timing settings. bring the timing up one step at a time and try the motor. hope that helps, Chellie
Old 06-04-2011, 01:33 AM   #5
LETMEFLY
Default motor problem
Hi Chellie,
I am so glad that you were here on Watt Flyer to help me with my problem concerning my motor issue. I re-programmed the motor to the low timing and took off the brake setting.
The motor now works so well. There is no jerking or anything. It must have been the timing that was the problem. If it works ok I will then put back the brake setting. Time will tell.
Thanks for your input.
Bob AKA LETMEFLY
LETMEFLY is offline
Old 06-04-2011, 03:10 AM   #6
Friends: (327)
Hi Bob We are all glad to help out here on Wattflyers, thats what its all about here sometimes a certain motor will not like a certain ESC they just dont get along with one another no matter how you adjust them, and sometimes its just a matter of getting the timing set right, you just have to try different things sometimes, Take care and have fun, Chellie
For Sale E-Flite Power 60 Brushless Outrunner Motor brianfp_400 Motors and Speed Controllers for sale & WTB 7 04-14-2011 10:16 PM
Flite Test Videos: Appreciation Thread FlyingMonkey Off Topic Chit Chat 66 04-04-2011 05:58 AM
Wattflyer Buyers Club #10 2 Dog Yak 54 Inquiry thread Nitro Blast General Electric Discussions 12 02-26-2011 03:59 PM
2200 KV MOTOR getting hot, smells?? BOB275 Power Systems 13 02-18-2011 03:06 AM
MPJA Power Supply kyleservicetech Batteries & Chargers 0 02-15-2011 03:02 PM
Page generated in 0.07306 seconds with 29 queries
