Old 06-05-2011, 03:10 AM   #1
Flysohigh
electrified
Flysohigh's Avatar
Default Nexstar ep esc question???
I have been wondering about getting the nexstar ep select and I see it calls for a lipo set up 5s battery but my question the esc that comes with the plane has The dual battery plugs! I read I can use a 5s battery I would like to know how will that be possible to run one 5s pack when there is 2 deans
To Berlin and back
Flysohigh is offline
Old 06-05-2011, 06:22 AM   #2
kenchiroalpha
Retired Master Chief USN
kenchiroalpha's Avatar
View kenchiroalpha's Gallery2
Outstanding Contributor Award
Friends: (168)
Hi
That aircraft is setup for dual packs only in the stock setup
The following is a list of accessories required to make the NexSTAR
EP Select operational. Order numbers are in parentheses.
(2) 8-Cell 9.6V 3600 mAh NiMH (Nickel-Metal Hydride)
battery packs (GPMP0362)
Hobbico Dual Peak NiMH Charger (HCAP0255)
The NexSTAR EP Select can also be fl own with a 5-cell
Lithium-Polymer (LiPo) set up. If you decide to go with LiPo
batteries, you will need the following items:
*2S 3200mAh 7.4V 20C Discharge w/Balance (GPMP0622)
*3S 3200mAh 11.1V 20C Discharge w/Balance (GPMP0623)
(*Use them together for a 5S set-up
Hope this helps
Take care
Yours Hank
kenchiroalpha is offline
Old 06-05-2011, 08:10 AM   #3
Flysohigh
electrified
Flysohigh's Avatar
I called product support and they mentioned that you can also use 1 5s battery instead of 2 packs, they mentioned something about residing the esc to just run one wire to fly but I didn't u derstand what they meant when I actually saw the esc photo
To Berlin and back
Old 06-12-2011, 08:57 PM   #4
TP16
Falling with Style
The ESC is set up like a normal one with a positive and negative battery lead, but it's got two Deans connectors in series rather than just one plug. To convert it to a single-plug setup, just cut out one of the male plugs on the ESC lead and splice the wire together.
Oh, and this is my first WattFlyer post
TP16 is offline
Old 06-12-2011, 09:06 PM   #5
kenchiroalpha
Friends: (168)
Talking
Hi
Welcome aboard
Im pleased to meet you
Thanks for the tip
Take care
Yours Hank
Old 06-12-2011, 09:38 PM   #6
Flysohigh
electrified
Flysohigh's Avatar
To Berlin and back
Nexstar ep select 68 inch battery question? Flysohigh General Electric Discussions 2 06-14-2011 01:26 AM
Noob esc question imapapallama Beginners 5 04-29-2011 03:30 AM
Hobbico Superstar EP Question mrcoolpop Batteries & Chargers 1 03-10-2011 06:19 PM
HELP, Turnigy Plush 40 amp ESC KenSue Power Systems 2 01-20-2011 10:09 PM
Page generated in 0.20207 seconds with 29 queries
