Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Video Parking lot
Video Parking lot Want to show off a video you found or one you are hosting online. Post a link to it here and strut your stuff!
Old 06-12-2011, 05:12 PM   #1
cbatters
cbatters's Avatar
Friends: (4)
Default DX6i elevator range problem
Having trouble getting full positive deflection on elevator. Monitor display agrees with what I see on elevator servo.
Not trying to do anything fancy with mixing or expo. Just trying to get DX6i to provide straight 4 channel function as a starting point
1 What would affect full scale throw of elevator in positive direction?
2 Is there a "reset all" function I should try?
3 Can someone confirm that they get full plus/minus deflection on elevator on their DX6i
Clint
Current - Ventura, HZ SuperCub-Freedom-Swift-AB3, PZ Typhoon, T-28 Trojan, Radian, AeroAce Biplane
Maiden - F-27C Stryker
10 years Ago - ElectroSoar 2M Glider, 2M Foam Glider, Mirage 550
Retired - Sky Fly, Red Hawk, Extreme, Challenger
cbatters is offline
Old 06-12-2011, 05:25 PM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Outstanding Contributor Award
Just checked mine, and with TRAVEL ADJ and SUB TRIM at default (100% and 0, respectively) my elev indicator on the monitor page only moves 2/3 up/down the scale. I think that's normal. You could try to increase the travel adj to greater than 100%, just be sure to not reach the servo's mechanical limits.
xmech2k is online now
Old 06-12-2011, 06:30 PM   #3
cbatters
cbatters's Avatar
Friends: (4)
So does anyone see 100% positive deflection on monitor? Seems like something else is being mixed in that is limiting travel. (haven't found any discussion or info in manual that explains why it would be any different than aileron that has symmetrical Adjustment range.
Clint
cbatters is offline
Old 06-18-2011, 01:17 AM   #4
cbatters
cbatters's Avatar
Friends: (4)
Bump -anyone see 100% full scale on monitor?
cbatters is offline
Old 06-18-2011, 04:16 AM   #5
TM4197
Dope&Fabric
TM4197's Avatar
Club: Mile High Club
CB...
Mine does not show 100% never has. My elevator on all models are deflecting full.
TM4197 is offline
Old 06-18-2011, 04:51 AM   #6
cbatters
cbatters's Avatar
Friends: (4)
To restate : the monitor display never shows full scale but the elevator shows full deflection.
Clint
cbatters is offline
Old 06-18-2011, 03:28 PM   #7
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
1kW
My DX7 only goes 2/3 on the monitor as well. And there's a reason for that. The marker on the scale around 2/3 represents 100% travel. Now, you can adjust your max travel on yout tx from 0% to 150%, so the area beyond the 2/3-mark is used to display travel greater than 100%.
So what you (and everybody else) is seeing is perfectly normal and the way it was designed to work.
AMA #959089
NJSwede is offline
Old 06-18-2011, 03:42 PM   #8
cbatters
cbatters's Avatar
Friends: (4)
Why is this different from aileron and rudder that show centered stick position and symmetrical full scale up / down operation ?
Clint
cbatters is offline
Old 06-18-2011, 09:06 PM   #9
Club: CVMRCC, SEFSD
Are you giving the full story here, cbatters? Isn't this the same problem you discussed in that other thread, where with everything set in neutral your elevator indicator isn't in the middle?
Old 06-18-2011, 10:14 PM   #10
cbatters
cbatters's Avatar
Friends: (4)
Correct. Stick in middle and all trims set to neutral does not result in elevator display in middle. If other owners of DX6i have display in center on elevator there is something wrong with my DX6i. ?(hw or sw)
cbatters is offline
DX6i flaperon trim problem skyman RC Radios, Transmitters, Receivers, Servos, gyros 4 05-31-2011 05:44 PM
Glitch / lock out problem!!!! Gee Power Systems 20 04-14-2011 03:29 AM
Unpossible servo problem mclarkson RC Radios, Transmitters, Receivers, Servos, gyros 13 02-13-2011 12:45 PM
Parkzone spitfire flight problem! Help! CPomeroy Beginners 30 02-12-2011 08:45 AM
spektrum dx6i help cottonpicker Beginners - Helis 7 01-25-2011 03:59 AM
Page generated in 0.23257 seconds with 37 queries
