Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > Castle Creations discussion
Castle Creations discussion All things Castle
Old 06-13-2011, 03:59 AM   #1
rckrazy
rckrazy's Avatar
125mph Speed Demon
Friends: (4)
Question Castle Link
I purchased a castle link some time ago and haven't had any luck getting it to work. The lastest computer loads the software without any issues. How ever when I connect the Castle Link the status never changes from red. When I try to update/load the driver it says no device loaded. Any ideas?
Thx
rckrazy is offline
Old 06-13-2011, 04:17 AM   #2
Thx
I ran into problems with mine when I got it several years ago. The red wire of the servo connector was not fully seated. The CC Link connected to the PC, but it would not connect to the ESC. Worked fine after fixing that.
Picked up a second one from CC that came free with their 80 Amp ICE HV ESC. Worked perfectly the first time it was plugged in.
For the most part, it is just plug and play though. I'd contact Castle Creations and see what they think.
Old 06-13-2011, 08:00 AM   #3
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Does the program start up ok?
Is it the RED status box on the program screen your talking about?
What color are the led lights on the link itself?
Try a different usb port and a different usb cable.
If that doesnt work - call castle support. They are great.
I think I need a signature.
Larry
Larry3215 is offline
Old 06-13-2011, 09:09 PM   #4
rckrazy
rckrazy's Avatar
125mph Speed Demon
Friends: (4)
The program starts ok
Yes the red status box is on the screen
When a esc connected I get a red and green light on the link with the red blinking
rckrazy is offline
Old 06-13-2011, 09:56 PM   #5
Larry3215
Larry3215's Avatar
Ok, if you tried different usb ports on your computer, then it could be you dont have the proper USB drivers. Its also possible your Lynk is broken.
I would call Castle tech suport. They will talk you through trouble shooting which it is.
Larry
Old 06-15-2011, 05:06 AM   #6
rckrazy
rckrazy's Avatar
125mph Speed Demon
Friends: (4)
tried all the usb ports, tried a new cable that I know works with another device - still not connection.
when I plug the link in the computer see's in according to the device manager but it doesn't have a drive and I get a red light on the link itself.
If i plug in a esc i get a fast blink red light and solid green on the link
rckrazy is offline
Old 06-15-2011, 05:57 AM   #7
Larry3215
Larry3215's Avatar
In the window on the computer, which of the lower boxes where it says "Connection Status" stay red?
The top one tells you if the Lynk software "sees" the castle link itself on the usb port.
the lower box tells you if the link "sees" the controller thats plugged in.
What do you get on the computer screen in those two boxes when athe lynk and an esc are plugged in?
Larry
Old 06-15-2011, 05:59 AM   #8
Larry3215
Larry3215's Avatar
By the way - which esc are you trying to use? HV esc's require you to use a separate battery pack to power the controller. Regular esc's dont need the battery pack.
Larry
Old 06-17-2011, 01:46 AM   #9
rckrazy
rckrazy's Avatar
125mph Speed Demon
Friends: (4)
It's a 60amp not hv. Wasn't working with a bec either.
Was messing around with last night and I noticed that the computer would make noise when I connected the link. But just setting the link on the table the computer would lose then reconnect. Well I stopped off at the hobby shop and picked up a new one. Hopefully that will fix it
UPDATE:
The new link works like a charm. Once connected in automatically installed the drivers - the old one would never do that.
Thanks for the help
rckrazy is offline
Old 06-17-2011, 04:27 AM   #10
Larry3215
Larry3215's Avatar
Castle will replace the dead one - no charge.
Or did the hobby show do a swap for you?
Glad its fixed
Larry
Sold Sold 1987tc Motors and Speed Controllers for sale & WTB 0 03-05-2011 09:59 PM
red castle esc pencon Power Systems 8 01-17-2011 08:38 PM
Sold Castle Creations Berg 4L Microstamp Receivers Qty. 4 NEW $20.00 Each All American Radio Equipment For Sale & WTB 0 07-02-2010 01:11 AM
Page generated in 0.08104 seconds with 37 queries
