Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
View Poll Results: Which do you like better the P-51 or Me-109?
P-51 1 50.00%
Me-109 1 50.00%
Voters: 2. You may not vote on this poll
Old 06-15-2011, 07:36 PM   #1
2dogrc
2Dogrc's RC Warehouse
2dogrc's Avatar
Send a message via MSN to 2dogrc
Default New 20mm EPP WWII Series, ME-109 and P-51
We are proud to introduce a new series of EPP airplanes. These standoff scale warbirds come in a P-51 and a Me-109. The planeS comes fully decaled with an amazing paint scheme. These EPP planes are built with 22mm thick EPP and make to take some punishment! The Fuselage is reinforced with Carbon Fiber internally. The wing has a carbon fiber spar and airfoiled wings! All the carbon for support, firewall and battery tray are pre-installed.
The plane comes pre painted and assemble is very easy. As you can see all the hardware is included. You will need the electronics listed below and glue! If you use the Dualsky components all the connectors are pre-soldered so no
soldering is necessary!
Specs:
Wingspan: 840mm (33.0in)
Fuselage length: 680mm (26.8n)
Flying weight: 320-350 g (11-12.3)
Motor: T-2208 or XM2826-10
Propeller: HD8040 or APC 7x5E
ESC: Dualsky 18A
Battery: Dualsky 800-1000 mAh 11.1V Li-Poly
Servo: 9 gram servo, 3 pcs
For more information and combo deals!
2dogrc
ID:	149596   Click image for larger version
ID:	149597   Click image for larger version
ID:	149598   Click image for larger version
ID:	149599   Click image for larger version
2dogrc
www.2dogrc.com
USA Dualsky Distributer
Home of the Lipo Mate!
2dogrc is offline
Tags
2dogrc , me-109 , p-51 , warbirds
Page generated in 0.39106 seconds with 27 queries
