Old 06-15-2011, 11:57 PM   #1
Steven87
View Steven87's Gallery5
Club: N/a
Default Better understanding of r/c plane electronics.
Ok, so i unserstand that the reciver is definitly what makes a plane a good plane along with the rest of the electronics.Can anyone give me a rundown of what a 6 channel 2.4Ghz is exactly?and how long the antenna has to be for proper operation, I bought a RTF redcat P-51 and the antenna is not more than about 3/4 of an inch long when most run the length of the plane.Will this hurt me?
Steven87 is offline
Old 06-16-2011, 12:15 AM   #2
View CHELLIE's Gallery13
Friends: (327)
That short antenna on a 2.4Ghz receiver Freaks out a lot of people 2.4Ghz is micro wave, and only needs a short antenna to match the radio wave/signal, 72 mhz is not micro wave, and a longer antenna is needed to match the radio wave/signal.
Old 06-16-2011, 12:20 AM   #3
You might fine something useful in this thread: Microwave radios are covered in this PDF file.
http://www.wattflyer.com/forums/showthread.php?t=45173
Old 06-16-2011, 08:11 PM   #4
Steven87
Club: N/a
OK thanks guys i really appriciate the info!Happy landings!and chellie ive seen some of your youtube stuff.very cool.
Steven87 is offline
Old 06-16-2011, 10:38 PM   #5
Friends: (327)
Hi Steve Thank you for the complement I am Just Plane Crazy about RC Take care and have fun, Chellie
Old 06-16-2011, 11:41 PM   #6
Steven87
Club: N/a
Ok, so one other Q.....I want to add some servoless retracts to my P-51D,am i rstricted to what i can run on it?
Steven87 is offline
Old 06-17-2011, 12:45 AM   #7
Friends: (327)
you are only limited by the Channels of your radio and the electrical amps that you have available to feed all of your servos, use a 10 AMP UBEC, that will give you all the electrical power you need to run everything on your plane., you will need to remove the red wire from the esc to receiver plug and tape it off, thats your old battery feed, use a pin and lift the locking tab, and pull the red wire out, hope that helps, Chellie
http://www.wattflyer.com/forums/show...t=ubec+chellie
http://www.bphobbies.com/view.asp?id...0&pid=B3144784
Old 06-17-2011, 07:19 AM   #8
Steven,
Sorry if I'm way off track but I'm guessing, based on the question asked, that you are pretty much a raw beginner to flying R/C models?.. If so the a P-51 is really not a suitable model to learn on. Unless you have a lot of help from an experienced flyer then it almost certainly will end badly. R/C models are a lot harder to fly that the experts make it look!
Adding stuff like retracts just makes the model heavier and so harder to fly plus retracts would be likely to be damaged in less than perfect landings (and if you are a beginner most landings will be far from perfect).
Suggest you think about putting the P-51 away for a while and learn to fly on a model that's designed for beginners?
Old 06-17-2011, 03:36 PM   #9
Steven,
Agreed:
Do you have any local RC clubs in your area? If so, check them out before flying any RC models.
Old 06-17-2011, 08:16 PM   #10
Steven87
Club: N/a
Yes im fairly new to the propelled world of flying, i use to fly gliders about 10 years ago when i was 14 but have been away from the hobby focused on actual cars and school.I never really tried to understand the electronics too much becouse the planes were pre built by my dads work buddy and given to me.Im also starting off with a GWS piko stick with a foam fuse and a couple upgrades.Im a natural born fabricator and hardly impressed with factory stock.hahaha. wish me luck!
Steven87 is offline
Old 06-17-2011, 08:24 PM   #11
Friends: (327)
Ask all the questions you want the E Power stuff takes a little Learning, its a balancing act to say the least, Everyone here is happy to help out to get you started in the right direction with E Power, Take care and have fun, Chellie
BTW we are the same Age 24 Ok so i wished LOL
Staying up wind AEAJR Wiki Discussion Threads 1 06-20-2011 11:43 AM
Rubber Band Balsa Plane -> RC Conversion Electrolight ParkFlyers 7 06-15-2011 07:27 AM
Plane advice needed (acrobatic/3D) Mysterious 3D Flying 58 06-12-2011 11:08 PM
1930's style cabin plane scratch built for elec r/c. CBN FVR Scratch and Kit Built Aircraft 37 04-16-2011 01:45 AM
Page generated in 0.11251 seconds with 39 queries
