Old 06-16-2011, 11:51 PM   #1
pawankt
Newbie:)
Default Hawk Sky ESC First time use/configuration
So I just received my shipment of the Hawk Sky I ordered (my first plane yay!), and it comes with instructions on how to use the ESC for the first time and it sort of looks like a precise set of steps.
I had a couple questions as I wait for batteries for my tx to arrive. First, is there an ESC configuration that needs to be set up? I googled around and some say throttle on full, others say throttle on zero, some say connect lipo to esc first and then turn throttle on and others vice versa. Is there anything I should be aware of?
Sorry to sound like a n00b, I am one
pawankt is offline
Old 06-17-2011, 12:59 AM   #2
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
2kW  1kW
Friends: (11)
Welcome to Wattflyer and the addictive world of RC flying. We're all noobs as some point and asking questions is what Wattflyer is for.
No, you shouldn't need to do any setup of the ESC. Just turn the transmitter on, turn the throttle to zero and plug in the battery and you should be good to go. Note that the ESC isn't going to "arm" unless the throttle is at zero. This is a safety feature and it's saved many fingers, I'm sure
Other than that: Put some loctite or epoxy on the nuts connecting the pushrods to the control horns. I've had incidents where the nut comes off and you don't want that to happen, trust me.
Also, unless you have a really smooth runway, don't bother to put on the gear and hand launch it like a glider. It belly lands great!
Good luck and have fun with this very nicely flying bird!
Edit: Oh... I just saw you've been here for a while. But welcome anyway!
AMA #959089
NJSwede is offline
Old 06-24-2011, 01:11 AM   #3
booterspaw
HawkSky Lover
Can someone help me with a battery charger ? I've got a Thunder AC6. It doesn't come with Deans connectors anymore. How do I fix this, solder one on in place of the alligator clips ?
booterspaw is offline
Old 07-07-2011, 10:15 PM   #4
dditch66
View dditch66's Gallery2
yes, in many cases with a computer charger, you either find an adaptor to buy (like epbuddy.com) or you solder it yourself. get used to soldering.
BTW, that hawsky is charge and go. Come up with a better way to hold wings on unless you think your gonna crash in the first 30 seconds. My hawsky has 15 hours on it already this year.
dditch66 is offline
Old 07-07-2011, 10:51 PM   #5
booterspaw
HawkSky Lover
That's probably about what I've got on mine this year. I did the solderin' thing for the charger, worked great. I went with the velcro method to hold the wings together. THANKS ALOT !!!
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Microjet V3 overheating issue or ESC ? zep77 Power Systems 10 12-21-2014 03:52 AM
Newbie with dynam sky hawk sadman ParkFlyers 36 09-12-2011 06:10 PM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 04:27 AM
Need to upgrade motor on SKY HAWK TW-742 zep77 Foamies 0 04-01-2011 07:37 PM
Page generated in 0.12737 seconds with 27 queries
