Old 06-17-2011, 11:27 PM   #1
kvflyer
Club: no clubs, no way! pirate flyer
Default Oh oh thiers that smell again
hey guys ,was out taking a little foamy for a spin and think I pushed it too hard, when it came down you could instantly smell it so I changed bats kicked up the Thro. and it just stutterd and wouldnt start, ok so went back to the shop hooked up another ESC and ditto, same thing. so took the motor apart and the windings/magnets looked good, but it had that all familiar smell it turned over but just didnt feel right,what goes bad when ya cook a motor?
"ALWAYS IN PURSUIT OF ELECTRIC FLIGHT"
kvflyer is offline
Old 06-18-2011, 12:07 AM   #2
View CHELLIE's Gallery13
Friends: (327)
Normally the wires get burned up and short out, and that will burn out the esc with it. get a Wattmeter, that will save your electronics and your pocket book Take care, Chellie
http://www.wattflyer.com/forums/show...ight=wattmeter
http://www.wattflyer.com/forums/showthread.php?t=35216
How to test your brushless motor
Old 06-18-2011, 05:51 AM   #3
kvflyer
already did a watt M pre-flight but that wont help now, I believe it was drawing too many Amps and prolly over proped, like I said the ESC survived the motor didnot
kvflyer is offline
Old 06-18-2011, 06:47 AM   #4
Take a look:
Maybe you'll be lucky and something will show up.
If you've cooked the windings, what likely happened is the insulation varnish got damaged, resulting in shorted turns in the copper windings in your motor. When the motor is spinning, either under power, or with a battery operated drill, those shorted turns will have very high currents flowing in them. (That's why the call them "shorted turns"!) Those are hard to find with a digital ohm meter. But, if you spin the motor with a battery operated drill per the above thread at around a thousand or three thousand RPM, shorted turns are going to get hot.
This thread has a fair amount of info in it. Hope it helps!
Old 06-18-2011, 03:59 PM   #5
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Club: www.rmvc-cumulus.nl
Take a look:
Yup. I always refer people with motor/esc problems to it. In my favorites list.
ron_van_sommeren is offline
Old 06-18-2011, 06:24 PM   #6
kvflyer
thanx for the info also check in my post re the MP motor I fried, maybe thatll explain it better, like I was saying it was prolly over proped heres another question Im assuming is correct but just making sure>>>>>is 3 W per motor gram sound right? for example if ya gotta 19G motor you should have around 57 W....that sound about right?
kvflyer is offline
Old 06-18-2011, 11:00 PM   #7
thanx for the info also check in my post re the MP motor I fried, maybe thatll explain it better, like I was saying it was prolly over proped heres another question Im assuming is correct but just making sure>>>>>its 3 W per motor gram sound right? for example if ya gotta 19G motor you should have around 57 W....that sound about right?
Yeah, a good quality brushless motor should handle 100 watts/ounce or about 3.5 watts per gram of weight. That is, assuming you're running the motor with the proper number of cells. (You can't get 100 watts/ounce out of a motor if you use 3 cells, when the motor is rated at 6 cells!)
Old 06-19-2011, 02:21 PM   #8
ron_van_sommeren
As far as frying is concerned, power (in Watts) going to the prop is not important, it's the current that kills, the power that stays behind in the motor.
Old 06-19-2011, 04:28 PM   #9
flydiver
flydiver's Avatar
View flydiver's Gallery1
If you prop RIGHT 3W is OK. You can prop wrong and produce mostly heat.
fly
flydiver is offline
Old 06-19-2011, 07:15 PM   #10
kvflyer
I agreed..........I see your from seattle, where ya been flyin? in the goodole days we flew in some local parks till they threw us out
kvflyer is offline
Page generated in 0.08355 seconds with 36 queries
