Old 06-18-2011, 06:39 PM   #1
whipple
Memento mori
Default Turnigy C3536-1300 prop choices
I purchased the above motor as part of this upgrade: http://cgi.ebay.com/parkzone-F4F-wildcat-400-watt-power-upgrade-/350397369906 Silly me, I didn't notice that it didn't come with a propeller so I take that to mean that I should use the stock prop.
This set me to thinking, "what if I dun wanna?"
This thought made me realize that I need to look up the prop/motor amp results to make sure the ESC can handle it.
After two hours of searching, I can't find any numbers that I would deem reliable because of slight numbering differences of the motors, and that apparently this C3536 is a 400 Watt motor, but there are other Turnigy motors with the same number that have a different watt rating.
Anyone have a site I can go to that will have the amp rating for this motor with different propellers?
Thank you,
Whipple
Electric R/C flight, where resistance is never futile.
AMA 930242
whipple is offline
Old 06-18-2011, 09:54 PM   #2
crash-rc
Club: tcrcm
You have the 3536 1300 B which HK list as 400 watts+, if you go down and read the reviews you can see what others are using and there amp draws. Your motor is on page 8 of the Turnigy motors. They are using about 3 or so different size props on that motor.
crash-rc is offline
Old 06-18-2011, 10:14 PM   #3
whipple
Memento mori
Thank you.
The seller said to only use the stock prop, so that's what I'll stick with.
AMA 930242
whipple is offline
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Prop Talk jap71173 General Electric Discussions 32 05-30-2011 03:46 AM
Z8-3D Prop -- New invention revolutionizes 3D aircraft hovering performance z-8 3D Flying 227 03-13-2011 01:58 PM
Hacker A60 18L Prop? gdwyer General Electric Discussions 5 01-18-2011 05:36 AM
Page generated in 0.06244 seconds with 23 queries
