Old 06-29-2011, 06:31 PM   #1
SnapDragon 44
SnapDragon 44's Avatar
Default How do channels on a radio work?
How many channels are needed to fly a plane with elevator,flaps,rudder, and aileron? Could you recommend some radios for this? Thanks
SnapDragon 44 is offline
Old 06-29-2011, 06:47 PM   #2
5 channels would be the minimum you would need, that's one for each of the functions you listed, plus one for throttle. Ideally you would go for 6 channels and go for a Tx that had aileron mixing which makes setting up easier.
What to go for depends very much on your budget. Spektrum gear is popular and is good value. In the Spektrum range the Dx5e would be the very minimum you require but the Dx6i or better still the Dx7 or even Dx8 would give you more features and more scope to cover future models with additional functions (like retractable undercarriage for instance). I'd recommend going for the highest spec Tx you can stretch to so you don't end up having to replace it in the future when you get another model.
Old 06-29-2011, 06:49 PM   #3
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
1kW
Five. Four for the control surfaces and one for the throttle. A channel is simply what conveys the movements of the sticks to the movements of the servos and electronic throttle. You want to move this:
1) Throttle
2) Aileron
3) Rudder
4) Elevator
5) Flaps
I.e. five channels. Everything you want to move/change requires a channel.
AMA #959089
NJSwede is offline
Old 06-29-2011, 07:38 PM   #4
SnapDragon 44
Okay thanks this really helps!
Old 06-29-2011, 07:53 PM   #5
Friends: (16)
Put me down for the Spektrum radio systems also. I've got two DX7 transmitters (One is a backup I got NIB at 1/2 cost from a club member), and 7 AR7000 receivers.
As others have indicated, buy the best you can afford, and unless you are flying very low cost back yard flyers, kind of stay away from the cheap import radios.
As for the Spektrum radios, I ran across a club member that is flying a multi-thousand dollar wet turbine model with a Spektrum DX6i transmitter. He had many many flights with it, with zero problems.
As for me, I'd go to a little more expensive radio for those turbine models, but you can't argue with success.
Most club members that went to 2.4 Ghz radios are using the Spektrum or JR radios DX7 or higher. No one in my club is using Futaba or any other brand of 2.4 Ghz systems.
One guy did have problems with his Spektrum DX7 radio losing binding last year. (Never lost a model, just could not take off with a dead radio) Sent it back, got it back, and after a few flights it lost binding again. Sent it back again, and Spektrum returned a brand new transmitter and receiver at no charge. From what I've read, this customer response for Spektrum is not unusual.
Old 06-29-2011, 07:57 PM   #6
Friends: (16)
If you go for the Spektrum DX7 system (Just recently upgraded to something like DX7s or similar) you've got 7 channels. That allows you to put two servos on the ailerons, two on the elevator, and do the mixing for these servos in the transmitter. Nice.
Old 06-29-2011, 08:17 PM   #7
NJSwede
3D wannabe
NJSwede's Avatar
1kW
I agree with Dennis. Plus, you have perfect timing! Spektrum just replaced the tried and tested DX7 with a new model (DX7s), so you should be able to score a cheap used DX7 from someone who wants the latest and greatest. The DX7 design still has many years of service left in it and since I personally own one, I can attest to the quality and reliability. I've probably had 100+ flights with my DX7 so far, and not a single glitch that could be related to the transmitter.
AMA #959089
NJSwede is offline
Old 06-29-2011, 08:28 PM   #8
Friends: (16)
I've just got to go one up on this, my DX7 transmitter has over 500 hours on six different models on it. (The Spektrum DX7 transmitter has timers for each of the models in its inventory.) Not all of these hours are flying time, but they do add up to over 600 flights in the past four flying seasons. And also, not a single loss of signal, or glitch during this entire four years.
Old 06-29-2011, 08:41 PM   #9
NJSwede
3D wannabe
NJSwede's Avatar
1kW
You're the biggest one-upper here at Wattflyer, but you still have my respect! (Because you have the experience and knowledge to match your one-upping...)
AMA #959089
NJSwede is offline
Old 06-29-2011, 09:11 PM   #10
SnapDragon 44
How about this? http://www3.towerhobbies.com/cgi-bin...=LXRXF4**&P=TS its in my price range!
Old 06-29-2011, 09:31 PM   #11
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (13)
Its not 2.4 first of all so you will need to make sure no one is on the same frequincy ,if they turn on your plane goes down. second they want you to buy all the stuff listed below it for more money and if you buy a dx6 or dx7 they come with servos and all the goodys. Save up some cash and buy 2.4 radio you wont be sorry . I own 2- dx7s and 2 old futabas and i never use the futabas any more . joe
road king 97 is online now
Old 06-29-2011, 09:49 PM   #12
SnapDragon 44
Then how about this? http://www.hobbytown.com/Shop/5-chan...-tx-novus125cp
Old 06-29-2011, 10:00 PM   #13
Rockin Robbins
Rockin Robbins's Avatar
Friends: (7)
I'd be wary. To quote the website you linked to:
No specifications are available for this product.
Rockin Robbins is offline
Old 06-29-2011, 10:01 PM   #14
road king 97
old hat
Friends: (13)
Here is a dx-5 channel with 6 channel reciever for 99 bucks http://www.horizonhobby.com/Products...ProdID=SPM5510
Old 06-29-2011, 10:09 PM   #15
SnapDragon 44
Cool Thanks!
Old 06-29-2011, 10:11 PM   #16
road king 97
old hat
Friends: (13)
If you can afford a little more radio the planes come and go but your radio is realy a good invesment . You are welcome and happy flying . joe
Old 06-30-2011, 12:42 AM   #17
Friends: (16)
Or check these out:
http://www.spektrumrc.com/Products/D...ProdId=SPM6610
http://search.horizonhobby.com/index...d=130DDCCEB8B9
Note Spektrum at Horizon Hobby has a receiver/transmitter for under $100.
Helping People Learn to Fly AEAJR General Electric Discussions 166 04-08-2013 05:54 PM
choice of radio, reciever etcc... eseeweb RC Radios, Transmitters, Receivers, Servos, gyros 16 07-09-2011 12:59 AM
Radio Questions - Futaba 6EXH brutusjm Beginners 4 06-13-2011 08:23 AM
bananna sky flight radio info wlester RC Radios, Transmitters, Receivers, Servos, gyros 3 05-10-2011 11:53 AM
Flyzone playmate radio range gcedillo Indoor & Micro Electric Planes 4 01-06-2011 03:18 AM
Page generated in 0.80298 seconds with 51 queries
