Old 07-01-2011, 12:51 AM   #1
crshbandit
crshbandit's Avatar
View crshbandit's Gallery1
Club: looking for a good club
Default spraying foam to make paint last longer?
Is there something you can spray directly on foam planes to make the the paint last longer? I see lots of foam planes at the field where the paint has rubbed off from launching, hanger rash, and landing. Maybe some sort of clear foam safe paint that will add a minimum of weight??
crshbandit is offline
Old 07-01-2011, 01:42 AM   #2
View CHELLIE's Gallery13
Friends: (326)
Hi Testor makes a clear high gloss spray enamel foam safe paint, make sure it says safe for foam on the can because testors makes a few different spray paints, use in thin coats, hope that helps, Chellie
http://www.google.com/products/catal...ed=0CFcQ8wIwCA#
Testors 1814 Spray High Gloss Clear 3 oz
$3 online
This is a 3oz (85g) can of High Gloss Overcoat Enamel Spray Paint.
FEATURES: Made of enamel and is flammable and toxic.
Can be used for:
models, ceramic, plastics, leather, stone, metal, styrofoam,
crafts, wax, glass, paper, figures, fabric, wood and touching
up purposes.
Not suitable for polyethylene or vinyl.
Contains no lead or harmful CFCs.
Easy-to-hold can.
Does not exceed 95% VOC by weight.
INCLUDES: One 3oz (85g) Can of High Gloss Overcoat Enamel Spray Paint.
Old 07-01-2011, 03:28 AM   #3
swimmer
Use Minwax water base polycrylic. Lowes, Menards or Home Depot will have it. Apply it with a foam brush. Makes a very good paint protector. Goes on easily, dries fast and makes your plane look great. I use satin as I don't like the gloss or semi gloss shine. Will not attack foam. Comes in spray also.
Allan
swimmer is offline
Old 08-30-2011, 05:21 AM   #4
dgoebel
Soaring Junkie
dgoebel's Avatar
Club: MRCSS
How about the Krylon Short Cuts that states safe for craft foam?
Has anyone tried that on elapor or Z Foam?
David Goebel
Fair Winds to all!
dgoebel is offline
Old 08-30-2011, 05:46 AM   #5
Friends: (326)
the krylon short cuts paint works on foam, but use in very thin coats, it can eat the foam if used to heavy, the testors is better because it will not eat the foam if used with heavy coats, just my 2 cents worth, as i have used both of them, the krylon H2O paint does not stick very well and is very heavy IMHO, Take care, Chellie
Old 08-30-2011, 06:18 AM   #6
jap71173
BigWatts.shutterfly.com
jap71173's Avatar
Friends: (8)
Allan
I wonder.... u think it would be possible to put this polycrylic clearcoat on as a protectant so one could use regular spray paint to achive desired colors then apply a second coat of the polycrylic to lock it in???
Every takeoff is optional. Every landing is mandatory!
AMA #964800
jap71173 is offline
Old 08-30-2011, 05:29 PM   #7
swimmer
Haven't tried that but with the polycrylic being water based I don't see why it wouldn't work. Try it on a test article first to see how it performs.
Allan
swimmer is offline
Old 08-30-2011, 09:36 PM   #8
crxmanpat's Avatar
View crxmanpat's Gallery20
Club: Arizona Model Aviators, Gilbert Quiet Flyers
Friends: (27)
Yes, it works. I've done it on both EPS and depron planes.
Pat Gagnon
crxmanpat is offline
Old 08-31-2011, 04:07 PM   #9
Azarr
Electric Junkie
Azarr's Avatar
Pledge Future Acrylic Shine Floor Wax. Although they call it wax, it's actually acrylic clear paint. Water soluble and thin. I've airbrushed it to use as a clearcoat on foam.
Azarr
Azarr is offline
Old 09-01-2011, 03:23 PM   #10
Friends: (18)
I use household vinyl silk emulsion paint ......... covers well in one coat ... water soluble to clean brushes but dries weather resistant.
You can get it mixed in store to the shade / colour you require ... only drawback is minimum qty is 1 litre ! But that leaves plenty for repairs and touch-up.
What type of paint is best on foam? RCFlyer44 Foamies 21 09-12-2013 04:40 AM
ELERC Micro A-10 Warthog 30mm EDF Beta Test Joe 1320 Electric Ducted Fan Jets 13 02-02-2012 01:15 PM
Spray foam project hayesjl Foamies 2 06-17-2011 08:22 AM
Page generated in 0.08981 seconds with 37 queries
