Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 07-05-2011, 04:35 PM   #1
Ray_ja
Default Deltrum 70 MM DEF power combo set
Will a 70 mm deltrum EDF power a 3.5 lb sailplane adequatley? It is sold by Nitro planes. If it is power enough, I will put it in the power pod that is designed for the discus CS 2.6M ARF sail plane glider. Nitro Planes does not indicate what the thrust is for this EDF. Should i try this EDF, or should I cut the nose off and go with the standard brushless motor and folding prop? Any suggestion would be much appriciated as i am new to electrics and know about the basics and no more. I would like to have the ability to fly this glider with enough power to play and get it to altitude. Thanks.
Ray_ja is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 01:56 AM
Page generated in 0.06381 seconds with 19 queries
