Old 07-06-2011, 07:07 PM   #1
Ray_ja
Default Deltrum 70 MM DEF power combo set
Does anyone know anything about this EDF. I am proposing to put it into a power pod for a scale glider wieghing around 3.5 pounds (2.6 meter sailplane). What type of perforance will i get? Will it be way under powered? Should i scrap this idea and cut the nose off and go with a standard motor and folding prop?
Any information would be much appriciated.
Ray_ja is offline
Old 07-06-2011, 11:33 PM   #2
View CHELLIE's Gallery13
Friends: (327)
Buy the power pod from Nitro planes and look for a 70mm EDF with thrust specs on the web.
here is a 72mm edf that will put out about 4.2 lbs of thrust with a 6 cell lipo, use a 80 amp esc and a ubec, a 2650mah 40C or bigger mah will work great, this will give you better than a 1 to 1 power ratio, it will be very quick
http://www.hobbyking.com/hobbyking/s..._1200watt.html
http://www.nitroplanes.com/ventus-di...sailplane.html
http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s..._6S1P_40C.html
or
http://www.hobbyking.com/hobbyking/s...Warehouse.html
http://www.bphobbies.com/view.asp?id...0&pid=B3144784
a ubec is a must when using 4 or more lipo cells, remove the red wire from the esc to the receiver at the plug when using a ubec.
http://www.wattflyer.com/forums/show...t=ubec+chellie
Old 07-06-2011, 11:40 PM   #3
Friends: (327)
using a standard motor and folding prop will be a cheaper way to go, EDF cost more money to produce thrust because they are very inefficient. Just my 2 cents worth, take care, Chellie
Old 07-07-2011, 02:48 PM   #4
Ray_ja
Thanks for the information. i will reconsider using a power pod and most likely cut the nose off.
Ray_ja is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 01:56 AM
Deltrum 70 MM DEF power combo set Ray_ja Hi-Performance and Sailplanes 0 07-05-2011 04:35 PM
Page generated in 0.09509 seconds with 25 queries
