Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > For Sale & Wanted Forums > Batteries and Chargers Forsale/WTB
Batteries and Chargers Forsale/WTB list your batteries and Chargers for sale here
Old 07-11-2011, 08:01 PM   #1
livinma1
WAA-08 Pilot #24
Club: PARCS
Send a message via AIM to livinma1 Send a message via Yahoo to livinma1
WAA-08 Pilot
Default 30 Amp Paraboard
$19.00 SHIPPED
30 AMP PARABOARD FOR CHARGING 6 BATTERIES AND BALANCNG @ THE SAME TIME
This device is to be used with a balance charger to simultaneously charge multiple lithium batteries in parallel. By this method you can significantly save time on battery charge process.
The principle and practices of parallel charging lithium batteries have been well discussed in the forums on RC Groups. This method has been proved to be a safe and efficient way to charge LiPo batteries, and is being widely accepted by more and more RC hobbiests all over the world.
Parallel charge can save your time significantly. If you charge four batteries at the same time, the charge current is four times of that you used for a single pack, and you need only approximately 1/4 of the charge time to charge every battery separately. Similarly, if you charge six batteries at the same time, the charge current is six times and time is only 1/6.
Each board has six set balance ports, from 2S-6S (except for the HP type that does not have 5S ports), and six T-plugs. Since these ports and connectors are arranged in parallel, a T-plug and a balance port can be randomly matched for battery charge. These ParaBoards can be used for charging up to six batteries at the same time.
ParaBoard is made of selected high quality components. The PCB board is made of two ounce copper and the main power circuit is heavily tinned to allow the use of high current. ParaBoard products have been fully tested under 30 A continuous current, and is safe to be load at 40A for a short time (10 - 30 minutes).
This board can be used for the following brands of LiPo batteries:
3E Models
ABF
ACE
Air Thunder
Align
Beyond Power
Blue Batteries
BP
Common Sense RC V1 (reversed polarity)
Common Sense RC V2
DN Power (reversed polarity)
Dynam
EC Power
E-Flight
eFuel
Electric Power
Electrifly
Energy EC
EP Buddy
Esky
E-Watts
Exceed RC Fusion
Flightmax
Fully Max
Gadex
GE Power
G-Force
Grayson Power
Hextronic
Hi Models
Hobby City
Hobby Loong
Hurricane Flight Systems
HXT
Imax
Kong Power (Old version)
Lightning Power (2S-5S)
Loong Max
MaxForce
Mega Power
Mojo
Mystery
Nine Eagles
Park Zone
PolyNoOne
PowerEdge
PowerSource
Precision Aerobatics
Protek
Reedy Power
RFI
Rhino
SMC
Super Tigre
Tenergy (old version, reversed polarity)
Top Racing
Tower Hobbies
Trinity
Turborix
Turnigy
Vampower (New version)
Venom
WOW RC
X-Caliber
Xtreme
Zippy
Name:	Hyperion Duo Charging.JPG
ID:	150672   Click image for larger version
livinma1 is offline
Old 07-13-2011, 08:48 PM   #2
electrodude71
Send a message via AIM to electrodude71 Send a message via MSN to electrodude71 Send a message via Yahoo to electrodude71
will this plug in and work on a hyperion duo 3
"hi my name is frank and im an rc addict"
electrodude71 is offline
Old 07-13-2011, 08:52 PM   #3
spad
Nope, not if you want balancing: it is a JST connector, NOT HYPERION.
spad is offline
Old 07-13-2011, 08:57 PM   #4
electrodude71
how come it is connected to a hyperion in the pic?
i need one of these boards to use with my hyperion duo 3
for turnigy lipo's with deans
Old 07-13-2011, 09:29 PM   #5
spad
The one shown connected has a different spec from the one on the right, which is described below it!
If you want a Hyperion version, go to epbuddy.com or progressiverc.com and order one.
Apples to apples, oranges to oranges.
(Note the markings on each board identify them as being different.)
spad is offline
Old 07-13-2011, 10:35 PM   #6
electrodude71
been to both and there is no were on any of them that says they will plug in to a hyperion duo 3 charger. everything but that i must be missing something
Old 07-13-2011, 11:54 PM   #7
spad
Yes, you are and so am I-sorry, I should have been more specific: YOU must modify the lead between the charger and the paraboard, OR call David at Progressive and see if he'll make one up for you.
As I recall, "Polyquest" and "Hyperion" share the same balance tap, type, but be sure and ask David.
Both sites list Polyquest type boards, with the mains connector of your choice-now, again, you must make up the cable between the charger and the paraboard, unless they are compatible with an Icharger-again, ASK DAVID!
spad is offline
Old 07-14-2011, 12:11 AM   #8
livinma1
WAA-08 Pilot #24
Club: PARCS
WAA-08 Pilot
Electrodude -. The paraboard will work with the hyperion duo with no problem. I use 2 of the on mine right now. What Spad is probably referring to is what kind of batteries do you plan on charging. If your looking to charge "Hyperion" batteries no the PCB on the board will not support that. But if your charging turnigys, blue lipo, gen ace it will work fine.
If it does not work I will gladly refund your money once I receive it back but trust me it will work.
BTW: You can check my feedback under the same name on rcgroups and you will see how much of stand up guy I am.
livinma1 is offline
Old 07-14-2011, 12:13 AM   #9
livinma1
WAA-08 Pilot #24
Club: PARCS
WAA-08 Pilot
Spad -- What leads need to be modified ?? Hyperion Duo is plug and play. Super duo you need to shave off a bit off the cable going into the balancing plug but it works fine.
livinma1 is offline
Old 07-17-2011, 03:47 AM   #10
ZAC ATTACK
Still for sale??
ZAC ATTACK is offline
Old 07-19-2011, 04:11 PM   #11
livinma1
WAA-08 Pilot #24
Club: PARCS
WAA-08 Pilot
Originally Posted by ZAC ATTACK View Post
Still for sale??
Yes !
livinma1 is offline
Old 07-19-2011, 05:57 PM   #12
RCFlyer44
RCFlyer44's Avatar
View RCFlyer44's Gallery2
Club: RC Wingers, Mooresville, NC
Send a message via Yahoo to RCFlyer44
Friends: (8)
I use one of these and it works great, just always make sure you are using the same size batteries when parallel charging and a good idea to have them all at a fairly close beginning voltage. Great product, and has saved me hours of charging!
RCFlyer44 is offline
Old 07-19-2011, 08:19 PM   #13
spad
It's fine to use varying capacities, so long as the cells are "about" the same voltage.
spad is offline
Old 07-22-2011, 02:58 PM   #14
electrodude71
i need this to work with my hyperion duo 3 charger
and with xh and deans connectors on the turnigy lipo's
Old 07-22-2011, 03:36 PM   #15
livinma1
WAA-08 Pilot #24
Club: PARCS
WAA-08 Pilot
In that case I have what you need. PM sent with paypal addy.
livinma1 is offline
Old 07-22-2011, 04:24 PM   #16
spad
These are excellent devices, and you'll be happy.
spad is offline
Old 07-22-2011, 06:15 PM   #17
livinma1
WAA-08 Pilot #24
Club: PARCS
WAA-08 Pilot
Isn't it.. I love mine. No more late night charging packs.. all my packs are charged so quick.
livinma1 is offline
Old 07-22-2011, 09:41 PM   #18
electrodude71
i found them new for $17.50 shipped and i need two sets.
so if you have two sets for $35 i'll paypal you now.
and if not thats fine and thanks anyway.
I fixed my son's amp. mclarkson Off Topic Chit Chat 2 03-25-2011 04:32 AM
For Sale Parkzone 480 960kv- Eflite 30 amp ESC swimmer Motors and Speed Controllers for sale & WTB 0 02-06-2011 07:09 PM
HELP, Turnigy Plush 40 amp ESC KenSue Power Systems 2 01-20-2011 10:09 PM
PZ T-28 problem skyman ParkFlyers 18 01-04-2011 10:42 PM
Page generated in 0.54319 seconds with 57 queries
