Old 07-16-2011, 03:22 AM   #1
kvflyer
Club: no clubs, no way! pirate flyer
Default Need a little help with nichrome wire
hey guys Im setting up a foam cutter on an old dremel jigsaw "taking out the blade and using nichrome wire" heres the deal>>>>>>>>> the power is from an old train transformer 120V 45watts, I have 2 leads "gator clips" from the transformer and 2 gator clips hooked at each end of the nichrome wire.....
if the leads to the wire "gator clips" isnt hooked up exactly to the wire ends it wont get any juice and is prolly shorting out on the saw blade holder thierfore wont transfer power to the wire, or so Im guessing.........
previously when I was cutting foam wings was using a 30 In. wood bow so the nichrome wire was also 30In. and the transformer was "not heating up" the problem is the transformer is getting way too hot with this dremel setup !! any suggestions?
"ALWAYS IN PURSUIT OF ELECTRIC FLIGHT"
kvflyer is offline
Old 07-16-2011, 03:31 AM   #2
View CHELLIE's Gallery13
Friends: (281)
Originally Posted by kvflyer View Post
hey guys Im setting up a foam cutter on an old dremel jigsaw "taking out the blade and using nichrome wire" heres the deal>>>>>>>>> the power is from a train transformer 120V 45watts, I have 2 leads "gator clips" from the transformer and 2 gator clips hooked at each end of the nichrome wire.....
the problem is the transformer is getting too hot, any suggestions?
previously when I was cutting foam wings was using a 30 In. wood bow so the nichrome wire was also 30In. and the transformer was "not heating up" get the picture?
the gator clips are add to much resistance and getting things hot, hook up the cutting wire in a more direct solid way, use thick 12 gauge wire from the transformer to the cutting wire, use a thinner cutting wire to keep the transformer heat down, make sure every thing is well insulated hope that helps, Chellie
Old 07-16-2011, 03:39 AM   #3
Friends: (281)
with the 30" bow you had more resistance in the wire, with a shorter wire you dont have the resistance needed to get hot enough to cut the foam with out the transformer getting hot, a smaller dia. cutting wire should be the cure. you can use guitar strings for the cutting wire, hope that helps, Chellie
http://www.wattflyer.com/forums/show...ot+wire+cutter
http://www.hhhh.org/~joeboy/resource...am_cutter.html
I think you can use from .008 to .030 wire nichrome wire. or .030 stainless steel fishing line
0.008 to 0.015-inch (thickness) single-wire steel guitar strings (available at your local music store)
Old 07-16-2011, 04:31 AM   #4
kvflyer
so in other words run a heavier insulated wire like lamp cord from the tranny to where the nichrome attaches w/o gator clips right? and in what areas do you mean "well insulated?
BTW SIG still sells real nichrome wire and is the dia. of a bottom string on an electric guitar,if not smaller
kvflyer is offline
Old 07-16-2011, 06:01 AM   #5
Friends: (281)
light cord wire will work, its 14 gauge, the smaller wire dia. the better for a short cutting wire, because there is less resistance with a shorter wire span, so you have to use a thinner wire to get the resistance and heat, hope that helps, Chellie
Old 07-20-2011, 01:24 AM   #6
kvflyer
dont mean to sell anyone short but nothing that was suggested worked, however with some fooling around was able to use 2 5in. nichrome wires coming off the reostat then gator clips attached to those going to the short nichrome cutting wire, a bit premative but what the hay,the temp can be controlled and life is good
kvflyer is offline
Night Flight Lighting Tips Galore! DragonWeezel Night Flying 7 09-22-2011 09:37 PM
Not Enough Power - - - Saddlebum Power Systems 82 07-18-2011 04:49 PM
setting up e.s.c. and battery long wire run! iflyrc1012 Power Systems 32 07-06-2011 12:43 PM
How to bend landing gear piano wire? xmech2k Scratch and Kit Built Aircraft 3 05-22-2011 06:03 AM
Measuring Battery Wire Capacity, help.. Razmo Batteries & Chargers 4 02-04-2011 02:29 AM
Page generated in 0.20958 seconds with 29 queries
