| Seaplanes E-Powered Discuss electric powered seaplanes here |
#26 | ||
old hat
Club: joliet rc club rt 66
Friends: (13)
Originally Posted by jap71173
I have my motors only on my esc and i cut the wire to my bec and put heat shrink on it . I run a second 2700 sanyo flight pack battery for my servos and reciever . This way i dont have to worry about my motor batterys shutting down my reciever or servos when low.Iam running my metal gear high tek servos on 6 volt but some like less voltage. joe
#27 | ||
BigWatts.shutterfly.com
Friends: (8)
Well, I've got everything setup right and tested... But one of my motors seem to be running faster than the other... By the time I back down the throttle from full to 1/4... One motor stops and the other is still spinning slowly... on top of that, once that motor stops, it wont respond to throttle control again unless i fully back it down to zero... I tried moving the BEC connection straight to the battery but this had no effect on anything... Any ideas? Are my esc timing's programmed differently?
Sent from my EVO |
Every takeoff is optional. Every landing is mandatory!
AMA #964800 |
#28 | ||
Friends: (281)
Swap your ESC around and see if the problem happens to the other motor, if not, the motor KV is not matched, if you got the motors from heads up rc, give Jeff a e mail, you might need to send the motors back and have Jeff send you a matched set of motors, the KV on motors will fluctuate a Little bit from motor to motor. if the problem happens to the other motor when the esc is switched around, then your ESC is to blame, reset the ESC throttle end points, one at a time, hope that helps, Chellie
http://www.wattflyer.com/forums/show...tle+end+points |
I may be getting Older, But I Refuse to grow Up
I am Having to much Fun to Grow Up LOL
#29 | ||
Friends: (8)
Originally Posted by CHELLIE
You were right (as usual)... it's the motor kv. Switched them and the opposite side was the one to slow down first. Just as a backup, i did the second test of reseting the throttle end points and no change so it's definantly different motor kv... i guess this is not uncommon in low quality motors. Thanks for your help Chellie... i'm sure Jeff will help me fix the problem. |
AMA #964800 |
#30 | ||
Friends: (8)
Well Chellie, it turns out it's not the motor kv, but rather just a bad motor. Jeff explained that if I can "see" the difference in speed, then it's something wrong with either the solder connection points or the motor itself. He said you can take two completely different motor kv's (ex: 1000kv & 2000kv) and they will both stop and start at the same exact time because that’s what the esc tells them to do... I of course tested his theory for myself as i have tons of motors just lying around so i tried a wide variety of mixed match motors on the two esc setup and he was right... never once could I tell any difference in speed "visually" and they both started, slowed and stop all at the same rate. The ONLY way to tell the difference was with my tachometer.
So long story short, it was a defective or damaged motor i got and he's swapping them out for me. So in truth you were correct that 2 motors can in fact be spinning at different kv, just that you can’t see it visually the way I was and in my case it was a defective motor. Thanks again for your help.
AMA #964800 |
#31 | ||
Friends: (281)
Glad you and Jeff got it figured out, I belive that Wrench66 here on Wattflyers had a similar problem with twin motors, he sent them back to Jeff and Jeff was able to get him a Matched set, i belive that problem was one motor was spinning faster than the other motor at higher speeds and would cause the plane to want to turn with out rudder, jeff got him a matched set of motors and the problem went away, so i belive in that case the kv of the 2 motors was off enough to cause a problem, Take care and have fun, Chellie
#32 | ||
old hat
Friends: (13)
So i get this straight if i want to build another multi brushless motor plane i need to have them all matched and the esc,s by the seller ? I have twins coming up on 3 different builds and will have to get the right ones. joe
#33 | ||
Friends: (281)
Originally Posted by road king 97
Hi Joe
if your going to build a twin and if you get the motors from Jeff at Heads Up Rc or any other seller, have them Match the motors for you to get the KV as close as possible, the kv will be off a little between motors of the same rated KV and brand, its just good cheap insurance to do that before the build, hope that helps, Chellie
#34 | ||
old hat
Friends: (13)
I own a K+A grumman mallard sea plane that was going to be brushed motors and i will pull a extra wire for brushless . http://www.kamodels.com/ thanks chellie.
joe
#35 | ||
Friends: (8)
Originally Posted by Fly Time
Hey Flytime, You still there... i need your help on this build???
AMA #964800 |
#36 | ||
Friends: (8)
Well, decided to start it without help...
first problem i ran into was the ESC/Motor wires were not long enough to be routed through a shaft leading under the wing... so i used 22 gauge servo extension wire... I’m thinking it may cause some resistance in power flow since both the esc and motor wires are heaver gauge. |
AMA #964800 |
#37 | ||
Friends: (281)
Hi, Use the Same size/gauge wire as the ESC to motor or your might burn up your motor or ESC.
#38 | ||
Friends: (8)
AMA #964800 |
#39 | ||
Friends: (8)
Took me all day but it's done. This is a nice sized plane. I must say this plane is good quality and fits together nicley. Instuctions were absolutley useless and can be tossed before starting!
I used all HeadsupRC parts and the watt meter reads 19amps @ 240 watts with a 3200mAh 3S, GWS 8040x3 blade props, 45oz flying weight. |
AMA #964800 |
#40 | ||
Ask me how I know
Friends: (20)
Oh man!! Sorry about dropping out. Not sure I would have been much help anyway since I haven't built mine yet
![]() Last night I finally got around to waterproofing all of my electronics with CorrosionX. Hopefully this evening I will start the build. BTW, I share Chellie's concern about using servo leads to run brushless motors. Servo wires are rated for relatively low power loads, whereas motor leads are rated much higher. Fortunately the motors in this plane will not draw too many amps, but all the same I would keep an eye out for gremlins... Do you have a maiden flight report for us yet? |
Doug
Loves the sound of 50 amps through an outrunner! |
#41 | ||
Ask me how I know
Friends: (20)
I'm finally putting this project on the work bench! Last night I got all the electronics figured out and soldered together. The ESC's will be in the fuselage, so I had to extend the motor leads to about 20". I also added a 5A UBEC.
Before installing the motors, I figured it would be a good idea to bench test the motors to make sure everything is running within limits. So tonight, I balanced the props and mounted the motors on a block of wood. Hooked it all up to a 25c 2200mAh lipo and a power meter, and the results were perfect: with both motors spinning GWS 8040 3-bladed props, I'm getting 31 amps and 325 watts. The HK 2824's are rated for 20 amps, so divided by 2 they are running WOT at 15.5 amps. That is perfectly in the sweet spot for efficiency, and well within the limits of my 20 amp ESC's as well And this plane will have plenty of power for water takeoffs.....and hauling it's firefighting cargo
Doug
#42 | ||
Friends: (8)
Hey fly...
Whats with the seperate BEC? the HK 20amp your using has a 3amp BEC should be more than enough for 4 small servos... well i guess more is always better so nothing wrong there ,,,Your electronic package is better than mine and mine flies good so yours will do great!!! If you decide to do grass landings, make sure to spray Polycrylic on the bottom or all the red paint will come off... Also, i found the wood braces for the floats need to be supported more as the tend to rip off even for water landings... i made 1/4 rounds x4 out of wood and glued them to the brace on the wing side. P.S. Is that the Seawind stand???
AMA #964800 |
#43 | ||
Ask me how I know
Friends: (20)
I will eventually be running quite a few servos: 2 for ailerons, 1 each for rudder and elevator, 1 for flaps, and probably another 2 for my water scoop and drop system, so the UBEC is installed in anticipation of running 7 servos eventually
![]() Thanks for the advice about protecting the hull. I was already thinking of glassing the bottom, so I will almost certainly go ahead and do that now. I have used polycrylic without fiberglass on a couple of other belly floppers and found that it helps a little, but only a little. This one will get the full treatment! Bracing the tip floats was also on the list.....which is getting long! |
Doug
#44 | ||
Ask me how I know
Friends: (20)
Doug
#45 | ||
Ask me how I know
Friends: (20)
So this is why I build so slowly....
Instead of just slapping these ARF's together and flying them, I see these little things all along the way that could have been engineered better, and I can't help but make the changes ![]() The cowlings on this plane do not allow for easy access to the motors. Even though brusless motors hardly ever require maintenance, it drives me nuts to not be able to get to them if I need to. And I was having some difficulty getting a firewall installed to replace the stick mount, so I took a razor saw to the foam. After installing firewalls, I took some hatch magnets from my crashed Seawind and used them to secure the front section of the cowlings. Now I have easy access to my motors ![]() ....and I added another day to my build
Doug
#46 | ||
Club: CVMRCC, SEFSD
It takes some cajones to cut into your brand new model! |
#47 | ||
Ask me how I know
Friends: (20)
Doug
#48 | ||
Ask me how I know
Friends: (20)
A little more cutting of foam tonight
I need to pick up a few things at the LHS tomorrow to make these fully functional. |
Doug
#49 | ||
Friends: (281)
Looking Great
Just a suggestion, you might want to add 2 pins/dowles next to the magnets, one on top and one on the bottom to keep the cowel from ever wanting to twist off, Just my 2 cents worth, Take care and have fun, Chellie |
#50 | ||
Ask me how I know
Friends: (20)
You know, I was actually going to do that, but those magnets hold so strong that I can't really imagine them coming loose from the forces of airflow and motor vibration alone. A crash would knock them loose, but I'm not going to do that
Doug
| Guan Li repowered. | cyclops2 | Seaplanes E-Powered | 4 | 03-07-2011 09:07 PM |
