Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Pusher Park Jets
Old 08-09-2011, 03:33 AM   #1
KenSue
Default Need Help with Pusher Jet Plans
I have recently acquired a surplus of campaign signs (about 1/8" thick). I would like to make a straight forward, simple, pusher jet. Any ideas on any free plans?
KenSue is offline
Old 11-17-2011, 04:43 PM   #2
berrier87
go on youtube and look at the ones they build out of cardboard... its an easy build and they fly great
berrier87 is offline
Old 11-17-2011, 04:44 PM   #3
berrier87
do you know about brushless setups for these pusher jets?
Old 11-22-2011, 09:20 PM   #4
Dr Kiwi
Outstanding Contributor Award
Motors like the 39g Grayson Microjet v3 work well on moderate sized profile pusher jets.
Name:	Grayson MicroJet V3 p.1.jpg
ID:	155045   Click image for larger version
Name:	Grayson MicroJet V3 p.2.jpg
ID:	155046   Click image for larger version
Name:	Grayson MicroJet V3 p.3.jpg
Dr Kiwi is offline
Old 11-22-2011, 09:31 PM   #5
Tsavah
Watt Waster
Tsavah's Avatar
View Tsavah's Gallery4
Club: LAFFS, but ...
Default Pusher Jets and Corrigated Signs
Just about any foam prop-n-slot plane or jet can be made using the corrigated signs, but the end result will be heavier. Generally speaking, you want to make the prop-n-slot copy around 20% larger to reduce the wing loading, and go up around 500-800 on the kV rating for the same motor weight. Normally that give what you need for a corrigated sign copy that was originally in foam board. I think you might be a little disappointed with the heavier bird if a foam copy that is a little smaller wants to race. You will be tempted to use a larger battery pack in the hope of getting the flight time back up near the foam copy, but that will only add more weight and work the motor harder. You might want to start with a simple Pizza Box Flyer design and decide if you like the heavier, corrigated plastic option. Just keep in mind what I said above and expect your version to fly a bit slower due to the extra weight.
Tsavah is offline
CHELLIE'S Scratch Built Planes & Plans CHELLIE Scratch and Kit Built Aircraft 16 10-10-2014 01:44 PM
Conwing L-16 Plans? HeliScRapYard Foamies 7 09-05-2013 08:26 AM
First good EDF jet peteflys Electric Ducted Fan Jets 6 03-29-2011 02:07 AM
VTOL depron JET MarkAntony General Electric Discussions 8 01-23-2011 02:43 PM
3-Blade Pusher Props iFLYrc_Vic General Electric Discussions 7 01-04-2011 10:52 PM
Page generated in 0.06444 seconds with 29 queries
