Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 08-13-2011, 09:28 AM   #1
mikail511
Unhappy How to hookup servos and retracts to a Parkzone P-47?
Hello everyone,
I'm pretty new to the hobby, so maybe this is a really simple problem with a quick fix (I hope). I hooked up the retracts and the flaps, turned on the DX6i transmitter, then the plane. Everything worked fine, but the servos and retracts are basically doing nothing. They didn't move when I turned on the plane, and using the switches on my DX6 doesn't do anything. Everything is firmly connected (with Y-harnesses), but the receiver does not seem to recognize the retracts or the flaps. The servos are sv-80s and the retracts are e flite 10 - 15.
mikail511 is offline
Old 08-13-2011, 06:47 PM   #2
papabatman
papabatman's Avatar
2kW  100mph Speed Demon
http://www.parkzone.com/Articles/Art...ArticleID=2286
http://www.parkzone.com/Articles/Art...ArticleID=2232
hope this helps
papabatman is offline
Old 08-13-2011, 08:07 PM   #3
wolfewinde
Club: Largo Flying Club
Friends: (4)
If this is brand new plane you need to bind it to the transmitter first. To do that, you put the battery in the airplane first, then turn on the transmitter while holding the trainer switch in the forward position until the beeping stops and you hear the servos twitch a little - make sure throttle is off when you do this.
Also, if "new to the hobby" means this is your first airplane, you might want to consider flying something else before you try this one.
Wolfe
wolfewinde is offline
Old 08-14-2011, 02:36 AM   #4
jap71173
BigWatts.shutterfly.com
jap71173's Avatar
Friends: (8)
Originally Posted by mikail511 View Post
Hello everyone,
Not sure if i can be much help as i have never use retracts nor flaps in my 1+ yr of flying... but here's my two guesses
It sounds like maybe a binding issue where you may have bound the receiver to you TX already prior to installing the flaps and retracts and so the receiver may not be supplying power to those channels. If that was the case i would guess that re-binding it would fix it.
The only other thing i could think of is that you have the plugs backwards plugged into either the receiver or the Y harness.
If none of those work, try testing they actually work by plugging them into a channel you know already works like the rudder... it won't harm it.
Every takeoff is optional. Every landing is mandatory!
AMA #964800
jap71173 is offline
Tags
dx6i spectrum rc 2.4 , p-47 , p47 , parkzone , retracts
Page generated in 0.08513 seconds with 24 queries
