Old 08-18-2011, 10:13 PM   #1
mcav8tr
Default Turnigy Motor w/ Turnigy Plush 10A ESC Problem
Hi. I was wondering of some of you could help diagnose a problem I'm having with this motor/esc combo. When there is no prop on the motor it runs fine. As soon as I put the prop on (APC 7x3.8 SF) the motor fails to start. It will turn very slowly while the ESC is trying to start it up but after a few seconds it goes into "failed start" mode. I can remove the prop and it starts up and runs just fine. The ESC is running with the default settings, my battery is fully charged (2s 500 mAh Lipo), all solder joints are good, I've set the throttle range correctly and I've tried the 3 different "start modes". Again, with no prop, the motor starts and runs fine. As soon as I put the prop on, it won't start correctly. Weird. Any suggestions would be greatly appreciated.
Motor: Turnigy 2730-1700
ESC: Turnigy Plush 10A
Battery: Zippy 2s 500 mAh 20C
TX: DX7
RX: Spektrum AR6100e
mcav8tr is offline
Old 08-19-2011, 01:23 AM   #2
roberted5r/cnut
Sounds like a bad solder joint from motor wires to bullets connectors.
You tin your wires and bullet connectors 1st,then you solder them together to avoid cold solder joints.
If you have another ESC that you know works try it 1st to avoid wasting time.
Each wire coming from motor should test continous.Some volt meters test continuity.
If the motor is terminated Wye,it could be that connection also.
roberted5r/cnut is offline
Old 08-19-2011, 03:34 AM   #3
TX: DX7
Quickest solution is to try another ESC and/or motor. Or go through the following procedure that might help verify if the motor is OK.
Drytesting brushless motors
http://www.wattflyer.com/forums/showthread.php?t=35216
Old 08-19-2011, 11:59 AM   #4
View CHELLIE's Gallery13
Friends: (326)
Either a bad electrical connection or your Battery is weak IMHO
Old 08-19-2011, 02:03 PM   #5
M@!
M@!'s Avatar
I have a similar motor that exhibits the same problems with 2S batteries. It flies fine on 3S but it will barely fire up on a 2S. This is with two different ESCs. Is there an ESC setting that could be wrong?
M@! is offline
Old 08-19-2011, 02:10 PM   #6
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Yes it is likely set for a higher 3 cell voltage cutoff.
Old 08-19-2011, 02:20 PM   #7
M@!
M@!'s Avatar
Looking at the ESC manuals; Thunder Bird 9 has no option to change Voltage cutoff and supposedly my Pro Series ESC adjusts voltage based on the number of cells. For Li-xx battery,number of battery cells are judged automatically,low / medium / high cutoff voltage for each cell are: 2.6V/2.85V/3.1V. For example: 3 Cells Li-Poly, when medium cutoff voltage is set, the cutoff voltage is: 2.85*3=8.55V.
My Thunderbird 9 stutters a little on a komodo 1300KV motor but nothing like on the Turnigy.
Could start up mode or timing cause the problem?
M@! is offline
Old 08-19-2011, 04:36 PM   #8
gyrocptr
Something to check:
On the male bullet connector, there is a tubular, cage-like piece with lots of little slots. This tubular piece has a belly-out shape that provides a spring-pressure, which help maintain electrical contact between the male and female connectors. The tubular piece should be free to rotate around the main body of the connector. Sometimes during soldering, excess flux can bubble into the area between the tubular-piece and the main body, and then solidify. If enough solidified flux (whitish or brownish in color) gets into this area, it can block the rotation of tubular-piece, and also create a high electrical-resistance between the tubular-piece and the main connector body. If your brushless motor is single-phasing (oscillating), or failing to reach full power, check to make sure the tubular-piece in each male bullet connector is free to rotate, and free of flux. If not, clean with contact-cleaner (or lacquer thinner, acetone ….). The cleaning may solve your problem.
gyrocptr is offline
For Sale Turnigy plush 40a (amp) esc brushless speed controller LOWERED PRICE 2.4ghz Motors and Speed Controllers for sale & WTB 8 11-11-2011 03:46 AM
Turnigy Plush 6A ESC programming issue JZSlenker Power Systems 0 04-20-2011 02:22 AM
HELP, Turnigy Plush 40 amp ESC KenSue Power Systems 2 01-20-2011 10:09 PM
HobbyKing Swarm: Turnigy Plush 60A ESC radialarm Basement Bargains 4 01-16-2011 06:48 PM
Page generated in 0.09971 seconds with 33 queries
