Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Indoor & Micro Electric Planes
Old 08-24-2011, 09:13 PM   #1
Otto Dieffenbach
Check six
Outstanding Contributor Award
Default Micro Polaris XXS
Here's my latest project a Micro Polaris XXS. It is 2.4 oz and has a 13 inch wingspan. Flight characteristics are excellent. See this video shot this morning....
Otto Dieffenbach is offline
Old 08-24-2011, 09:22 PM   #2
Otto Dieffenbach
Check six
Default Other Micros in my hanger
Here are more shots of the Polaris XXS and other hanger planes. Primary building material is sheet foam made from Chevy's take home containers.
ID:	152228   Click image for larger version
ID:	152229   Click image for larger version
ID:	152230   Click image for larger version
ID:	152231   Click image for larger version
ID:	152233   Click image for larger version
ID:	152234   Click image for larger version
ID:	152235   Click image for larger version
ID:	152236   Click image for larger version
Old 08-24-2011, 09:35 PM   #3
Otto Dieffenbach
Check six
Default Superman Video
Micro Superman
Old 08-25-2011, 04:05 AM   #4
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
very nicely done otto!
I think I need a signature.
Larry
Larry3215 is offline
Old 08-25-2011, 08:55 AM   #5
Billmanak
Club: Stand next to me when we fly and we'll pretend we are a club.
Very nice. Thanks for sharing.
Billmanak is offline
Old 08-28-2011, 04:06 PM   #6
jakkesb
They're beautiful, Otto! Do you use modelplans or are they scratch-built?
jakkesb is offline
Old 08-28-2011, 10:45 PM   #7
Otto Dieffenbach
Check six
All are scratch built. The Polaris was from reduced plans from parkjets.com. The P-82 is from two PZ P-51s. Thnax again.
Old 08-28-2011, 10:48 PM   #8
Otto Dieffenbach
Check six
Default Polaris XXS CG
Larry sent me a message indicating that my troubles with inverted flight may be do to a forward CG. I have now moved the CG back 1/2 inch from the location specified on the plans with little degradation in upright stability and an ability to fly and turn inverted. Will continue to experiment.
Old 08-29-2011, 07:26 PM   #9
Otto Dieffenbach
Check six
Finished CG experiments and have concluded that 3/8" behind stock CG gives a good blend of stability and aerobatic performance. This assumes that you have a Polaris with a 13" wingspan. I also moved the step back with a Depron shim. If you have no interest in inverted flight, CG shown on plans is great. Next, water testing.
Old 09-29-2011, 12:47 AM   #10
Otto Dieffenbach
Check six
Default First water operations
Here is a video from the first water ops. Need some suggestions on how to fix the s turning. Best.
Old 09-30-2011, 07:34 PM   #11
aeroknot
learning by doing
aeroknot's Avatar
I wonder what shimming the aft right and left wingtip floats slightly lower would do>
aeroknot is offline
Old 10-01-2011, 03:12 AM   #12
Larry3215
Larry3215's Avatar
Otto - sorry to take so long getting back to you.
Can you provide some close up shots of the bottom of the fuse at and just ahead of the step and of the bottom, rear and sides of the tip floats?
I suspect the root cause of the problem is due to prop torque forcing one side down into the water as you accelerate. Then, if you over correct, you get the reverse turn.
However, the way you do the step and the lower side edges on the fuse and the lower sides and rear edges of the tip floats can contribute a lot to making the problem better or worse.
The step itself as well as the bottom side corners of the fuse need to be almost razor sharp corners. The same applies to the tip float lower side corners and rear step.
In the air, you want nice rounded corners to reduce drag. In the water, its just the opposite. Those nice rounded corners will screw up the model badly.
If those corners are not really sharp 90 degree corners, then you get a huge increase in water drag. Any rounding of the corners can actually suck the model down into the water as you are trying to get up on step - just exactly the opposite of what you want to happen. In addition, it can make for directional instability at speed.
You might also try making the tip floats a tad shorter. You want them well out of the water when your on step.
Larry
Old 10-01-2011, 03:17 AM   #13
Larry3215
Larry3215's Avatar
By the way, this kind of thing - sharp corners on the step and sides of the fuse - is important on the larger models all the way up to full scale.
However, its even more critical at very small scales because of the meniscus effect. At small scales water tends to climb up the sides of things and 'clings' more than at large scales. So those sharp corners need to get sharper the smaller you get.
Larry
Old 10-02-2011, 04:05 PM   #14
Otto Dieffenbach
Check six
Default 1/2" step and 1/8" tip floats worked
Here's the video of water operations with deeper step and smaller tip floats. Did the trick. Thanx.
Old 10-02-2011, 07:00 PM   #15
Larry3215
Larry3215's Avatar
I dont think you needed to get quite that dramatic with the step height, but glad its working better now
Larry
Old 10-03-2011, 12:46 AM   #16
Otto Dieffenbach
Check six
The easiest of several options. I needed to lower the bottom line of the fuse to get more wing separation from the water so this was the easy option.
ELERC Micro A-10 Warthog 30mm EDF Beta Test Joe 1320 Electric Ducted Fan Jets 13 02-02-2012 01:15 PM
EasySky 2.4G 4ch Micro Super Piper Cub J3 EasySky ParkFlyers 8 11-26-2011 05:47 AM
For Sale micro airframess for your pz and micro electronics dr rc Airplanes - Electric For Sale & WTB 6 07-15-2011 04:41 AM
New ParkZone Micro SU26xp for CV, FMS, RCDP ggunners Flight Simulators 0 12-27-2010 11:18 PM
Sold Futaba Ultra Micro Flight Pack R124F RX and three S3110M Servos All American Radio Equipment For Sale & WTB 0 07-02-2010 04:47 PM
Page generated in 1.23648 seconds with 66 queries
