Old 09-02-2011, 08:30 PM   #1
Otto Dieffenbach
Check six
Outstanding Contributor Award
Default Giant Foamie F-15 Scratch Build
After building my large foamie Sea Dart (3 lbs 10 oz) and foamie Eindecker (11 lbs), I decided I wanted to add to my fleet of F-15s. I have a 9 lb F-15 that I built and first flew in 1973 and coverted to electric and flew earlier this year. In addition, I have a 1.2 oz outrunner micro and a 6 oz foamie that have been fun.
My project will be built from Home Depot materials with the primary material being 1/2" R-Tech foam insulation that comes in 4x8 sheets for $7. My target weight is 3 and 1/2 lbs with power system being my Scorpion 3026-980, 60 amp ESC and 4s5000 battery with an APC 10x7 prop. This will generate 5 lbs of static thrust and should make for great performance given my experience with the Sea Dart. Dimensions are 42" wingspan and 55" long. My design parameters included that it must fit in the car, takeoff from the ground (no toss launch), have great performance/handling (TBD) and be inexpensive to build.
This is my first build thread so as questions, if interested. I have taken a bunch of pictures that help explain the build and I will have more detail after first flight, which should be within a week.
ID:	152493 Battery box with retention bar
ID:	152494 Battery box recessed into foam wing
ID:	152495 Cut R-Tech foam parts
Name:	Leading edgesparjoint.jpg
ID:	152496 Leading edge/spar joint
ID:	152497 Motor Mount Area
ID:	152498 Nose Section glued with Gorilla
ID:	152499 Foamie parts rear angle
ID:	152500 Sides glued to wing, Tail box
ID:	152501 Skeleton: Motor mount, skid and battery box
ID:	152502 Side mating from the front
Otto Dieffenbach is offline
Old 09-02-2011, 08:35 PM   #2
Otto Dieffenbach
Check six
Default More photos
More photos...
ID:	152503 Top shot of Skeleton
ID:	152504 Skeleton integrated with wing
ID:	152505 Tail pieces prepared for assembly
ID:	152506 Attachment of vertical stabilizers
Old 09-03-2011, 05:56 PM   #3
Slowjohn
You can bury me after I'm done flying
Slowjohn's Avatar
Club: Just Some Friends
1kW  Globetrotter Pilot
Friends: (28)
Interesting build.
Standing By,
SJ
Blue Skies, Calm Breezes & A Full Hanger
Makes Me A Very Happy Man
Slowjohn is online now
Old 09-04-2011, 06:54 AM   #4
Otto Dieffenbach
Check six
Default Build complete less paint
I've completed the build and will fly before painting. I'm waiting on a receiver that should arrive Monday. First flight Tuesday. Here are more photos. Total weight 3 lbs 12 oz.
ID:	152575 Top view of motor installation
ID:	152576 Rudder linkage and servo
ID:	152577 Elevon linkage
ID:	152578 Completed tail from below
ID:	152579 Bottom view motor installation
ID:	152580 Battery/ESC installed
ID:	152581 ESC from the rear
ID:	152582 Completed plane
ID:	152583 Inlets and nose
ID:	152584 Rear shot
Old 09-04-2011, 07:51 AM   #5
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Nice Otto!
What the plan for landing gear?
I started to make a comment about the elevons - possibly - not being enough for good roll control at low speeds, but the center portion is in the prop wash so that will help. Throttle off in a hi alpha attitude may leave you a bit lacking though.
Somewhere I have some shots of how to operate the elevons and ailevators from single servos - makes for extreme control in all axis
I think I need a signature.
Larry
Larry3215 is offline
Old 09-04-2011, 08:03 AM   #6
Larry3215
Larry3215's Avatar
Here are some shots of how I did it.
Basically, when an elevon moves, the same side aileron goes in the same direction.
Both surfaces are driven from a single servo using a split push rod.
This gives you much better low speed roll control but it also enhances pitch control.
When you give UP elevator both ailerons go into reflex which allows the model to loop in a much smaller diameter circle and more importantly - maintain very stable hi alpha flight.
This allows for very scale looking take-offs and landings where the nose wheel comes up early before the mains take off. Same thing on landing.
You can easily take off or touch down with the nose hi and keep it there if you want while you roll out.
The mains need to be set very close to the cg for this to work well though.
Its pretty cool
oh - it also allows you to do a cool lomchavack and even tumble the model if the cg is back far enough at the same time.
Name:	IMG_4033 (Medium).JPG
Name:	IMG_4042 (Medium).JPG
Larry
Old 09-04-2011, 08:49 AM   #7
Otto Dieffenbach
Check six
Default Hi Larry
Thanx. I designed it to skid across the ground like the Polaris for takeoff. While on the Polaris, did you put the minus 2 degrees in your thrust line and stab? Looking forward to first flight Tuesday.
Old 09-04-2011, 09:05 AM   #8
Larry3215
Larry3215's Avatar
Yes I did.
Good luck on the maiden - get video!
Larry
Old 09-04-2011, 08:16 PM   #9
Otto Dieffenbach
Check six
Default Giant F-15 1st flight
Ok, I accelerated my schedule and ripped a receiver out of one of my other aircraft to first fly this morning. Handles like the Parkjet version only better with thrust vectoring rudder. Vertical performance is excellent. Need to do some slight thrust angle ajustments for loop tracking.
Old 09-05-2011, 01:53 AM   #10
Larry3215
Larry3215's Avatar
Outstanding!
No lack of roll or pitch control at all. very cool!
Cant wait to see the color scheme you come up with
Larry
Old 09-05-2011, 02:01 AM   #11
View CHELLIE's Gallery13
Friends: (281)
Very nice build and flight keep up the great work, Chellie
Old 09-05-2011, 02:05 AM   #12
Otto Dieffenbach
Check six
Default Earned its paint
Sorry Larry, paint scheme not too exciting but functional.... no Thunderbird here.
ID:	152601 Painted side view
ID:	152602 Front view
ID:	152603 Rear quarter view
ID:	152604 With its Sea Dart brother
ID:	152605 Two great planes
ID:	152606 More Eagle and Dart
ID:	152607 They share the same power system
Old 09-05-2011, 02:09 AM   #13
Friends: (281)
Very nice scratch builds Oh BTW, It will fly better if you Paint it Pink Just Kidding, Take care, Chellie
http://www.rcgroups.com/forums/showt...793637&page=16
Old 09-05-2011, 02:20 AM   #14
Otto Dieffenbach
Check six
Cool. I've never had a pink plane but had some with pink in the scheme ala Circus Circus for TOC. Did have a friend with a hot pink Kwik Fly III back in the late 60s. Hot pink was all the rage...
Old 09-05-2011, 02:24 AM   #15
Friends: (281)
Yes, Pink is easy to see in the air
here is my scratch built Katana below, I still have it
Old 09-05-2011, 02:27 AM   #16
Friends: (281)
My Friend Steve is doing the maiden flight on it, I am doing the video.
Old 09-05-2011, 02:29 AM   #17
Friends: (281)
I Made a Blue one for Steve, He did not like Pink LOL , BTW if you would like to make one, the plans are in the thread, I used a Slow Stick fuse for the wing brace, i got it at BP Hobbies.
http://www.wattflyer.com/forums/show...katana+chellie
Old 09-05-2011, 05:17 AM   #18
Otto Dieffenbach
Check six
Looks like a fun plane but I am really impressed with the video and your ability to keep the plane in frame. I need to get you to shoot some of my acro.
Old 09-05-2011, 06:08 AM   #19
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
View HeliScRapYard's Gallery3
Send a message via AIM to HeliScRapYard
This makes me want to get back on a project I abandoned a while back. I had planned to make a 200% RC powers F22 easybuild. Hopefully ill get some time to do that soon. Congrats on a good looking and flying plane.
Need More Glue!!!
HeliScRapYard is offline
Old 09-05-2011, 09:57 AM   #20
Friends: (281)
Its easy to keep a plane in the frame but you need to make one of these mount the camera on the top bracket, aim the camera and the open sights at a object about 100ft away and adjust, set the zoom on the camera to about 1/4 or 1/3 and follow the plane with the open sights
http://www.wattflyer.com/forums/show...ighlight=rifle
Old 09-05-2011, 10:09 AM   #21
Friends: (281)
here is a video I shot of my friends fast moving heli, with the rifle camera mount.
Old 09-05-2011, 03:03 PM   #22
eflight-ray
eflight-ray's Avatar
Otto, I also enjoy large foamies, my last one, a sort of Mig 144, is EDP, Electric Ducted Prop(s). My use of a props was to keep the amps down from the usually very high ducted fans models. It worked quite successfully for what I wanted.
As for camera sighting, I tend to fly on my own and use one of the very small 'keychain' cameras mounted on the side of my sunglasses. Sighting can be a real problem, as I have found I often 'lead the plane' on fly-by's and end up film the sky in front of it. I had thought of mounting some sort of wire sight to the camera, but found a simple tiny 'spot' marked on one of the lenses has worked fairly well. It's not enough to get in the way, (it's out of focus that close up), but noticeable when following a plane.
Though I will use the excuse of only just having started using it, so I have an excuse for my poor video shots.
Ray in Wales
As I get older I think more and more about the hereafter.
I walk into a room, and think, 'now what was it that I'm here after?' :o
eflight-ray is offline
Old 09-05-2011, 04:55 PM   #23
Otto Dieffenbach
Check six
I wish I was still travelling to Wales so we could share a pint. Impressive plane; what is the weight and static thrust? Are any videos on youtube? Great paint scheme. Thank you for sharing.
Old 09-05-2011, 04:58 PM   #24
Otto Dieffenbach
Check six
Chellie, your solutions are impressive. Gold star for you. Now if I could only steady my Dad's hands.......
Old 09-05-2011, 10:09 PM   #25
Otto Dieffenbach
Check six
Default Video of painted F-15, 3rd and 4th flights
3rd and 4th flights
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 01:27 AM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 100 01-07-2012 11:12 PM
$100 Scratch Build Contest Best Build Thread hillbillynamedpossum Scratch and Kit Built Aircraft 2 05-17-2011 02:43 AM
$100.00 Scratch Build Contest: 60" Glider Propjobbill Scratch and Kit Built Aircraft 19 05-11-2011 04:08 AM
Wanted Scratch Build Plane Swap Saucerguy2 Airplanes - Electric For Sale & WTB 0 02-17-2011 09:12 PM
Page generated in 3.61206 seconds with 109 queries
