Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Aerodynamics
Old 09-02-2011, 09:06 PM   #1
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
View GreenAce92's Gallery36
Default Does anyone put the extra washout on their wing tips?
I was told that it is important to either stall the wing tips first (in a turn) or not to stall I can't remember which one.
The idea though is having the washout get over extended, so that the wing tips are down facing (if that makes sense).
Here is an image of what I'm trying to describe.
I'm not sure if I drew it right, but basically it's like over "feathering"
Do life with optimism
GreenAce92 is offline
Old 09-02-2011, 09:15 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
You want the wing tips to stall last so the plane won't snap as easily. A small amount is all that is needed or desired.
I can't make heads or tails of your drawing sorry. You don't want to over do the washout as that starts to create other issues (especially in aerobatics and inverted flight).
Old 09-02-2011, 09:29 PM   #3
NJSwede
3D wannabe
NJSwede's Avatar
View NJSwede's Gallery1
1kW
Doesn't that depend on what flying characteristics you're after? If you want to do crazy snap rolls and stuff, you may want the tips to stall first. Also, if you're after insane speed, you may sacrifice some low speed stability in order to reduce the tip vortices. But if you want a stable plane that's easy to land and that flies well at slow speeds, you definitely don't want the tips to stall first.
YMMV, I'm no expert and all other disclaimers apply...
AMA #959089
NJSwede is online now
Old 09-02-2011, 10:01 PM   #4
WAA-08 Pilot
Friends: (9)
My point exactly on some planes you want aggressive snap and spin characteristics. Aerobatic airplanes for sure. But.....you would want to be mighty careful with having the tips stall first. That would mean slow down too much and the wing snaps and spins.
I had a plane like that once. A snappy Cap. It had a short but spectacular life.
Old 09-02-2011, 10:26 PM   #5
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
that would explain the flat constant chord wings on 3d planes
sorry not chord but taper
yeah i apologize about the drawing
Old 09-02-2011, 11:36 PM   #6
Club: A lone flyer!
Scratchbuilders Award
GreenAce92
It is worth remembering that washout becomes 'washin' when flying inverted which will ensure the tip stalls first!
Washout does cause a slight reduction in the wings efficiency however you can use other aerodynamic effects to ensure that the wing root stalls before the tip.
The most obvious is to use a different wing section on the outer portions (ie one that stalls at a greater angle of attack) or by aerodynamic 'additions' such as leading edge slots or stall strips at the root.
quorneng is offline
Old 09-02-2011, 11:51 PM   #7
Washout is a useful trick in many ways but as others have said needs to be used with extreme caution if the model is intended to fly inverted.
BTW.. washout does not necessarily always reduce a wing's efficiency. On un-tapered wings washout can actually increase efficiency because it can be used to optimise the spanwise lift distribution to be closer the elliptical... Elliptical being the ideal for reduction in induced drag.
You can demonstrate this with the little application here: http://aero.stanford.edu/WingCalc.html
Put in an unswept wing with no taper (taper ratio 1) and you can achieve about 4% increase in efficiency by adding 2.5 -3 deg of washout. Wing efficiency factor is the 'e' value.
JetPlaneFlyer is online now
Old 09-04-2011, 11:45 PM   #8
Club: A lone flyer!
How the ailerons perform can have a big influence on a plane's stall behaviour.
I shot this video of my Wing Dragon with separate flaps to demonstrate its speed range.
It has a tapered wing with no washout so might be expected to stall aggressively but it actually retains adequate roll control at very slow speeds with only a gentle and controllable wing drop if taken too slowly.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Note the planes angle of attack remains more or less the same when the flaps are down so the wing tips do not stall and the aileron remain effective albeit with progressively less authority as the airspeed reduces.
quorneng is offline
Old 02-05-2012, 05:00 PM   #9
norcalwelder
Basically you only need to worry about washout if you have a wing plan form other than a rectangular wing. (tapered, delta, elliptical) An aircraft's stall characteristics are determined by its wing plan form, with some stalling at the root, (rectangular) some stalling at the tip (tapered, delta) and some stalling all at once (elliptical). If you don't want to use washout, you can force a stall at the root with stall strips and a few other devices.
norcalwelder is offline
Old 02-10-2012, 09:44 AM   #10
simonrich
hi just a quick message for me inlaw.. he's building a fast slope soaring plane of a 5m wingspan..he's using the programme compufoil, with this cord and settings.... 30%>2.40"-> HN218PRO.COR/8"c/.0625"s/0.3"k/ .875"h/9.84%thk/2.33%cmb....... 10inch rootcore for the first metre, and from 10-5inch for a 1.5mtres thinned 25% on the outter pannel.. wht he wants to no is does he have to put wash out in.... or does he need the tip cord broader or not to get away without putting wash out in? any help is much appreciated, thanks Simon
simonrich is offline
Old 02-12-2012, 08:49 PM   #11
Club: A lone flyer!
As a fast glider the performance will be marginally improved without wash out, providing the wing has sufficient torsional stiffness to hold its incidence accurately all along the wing when at speed.
With such a high aspect ratio the way the structure of the wing performs at various loads and speeds is likely to be just as important as the static wing geometry.
There is no easy answer.
quorneng is offline
Electric Zero..Any suggestions on how to add some washout. liposucker Beginners 14 08-20-2011 08:48 AM
Crazy idea? WayneG Hi-Performance and Sailplanes 21 05-29-2011 08:37 PM
Page generated in 0.97273 seconds with 42 queries
