Old 09-07-2011, 04:38 PM   #1
JZSlenker
JZSlenker's Avatar
Send a message via AIM to JZSlenker
Default Rctimer 50a esc not connecting to program card
I just got several rctimer 50a opto escs and a hobbywing programming card (from rctimer). I can't seem to get the card to connect at all. I've provided a 5v power input to the card, but get nothing. I believe I'm following the directions for the order of connection. I need to program 8 of these so I would prefer not to use my TX to do it. Any ideas?
JZSlenker is offline
Old 09-07-2011, 11:58 PM   #2
View CHELLIE's Gallery13
Friends: (327)
sometimes the 5v power input does not work with some esc, you need to hook up the battery to the esc, you may even need to use a y connector and send the 5v power to where the bec would normally power up everything, i think your 50 amp rctimer does not have a bec, so you will have to add power to that plug via a y connector to get the programer to work, I have run across that problem too with some esc, hope that helps, Chellie
Old 09-08-2011, 02:21 AM   #3
JZSlenker
JZSlenker's Avatar
ok, thanks Chellie, I'll try that tomorrow. The ESC's are opto, so there is not BEC but the programming card has a power input connector that I was using. Still I will give it a shot. Why not...right.
Old 09-08-2011, 12:59 PM   #4
Friends: (327)
Old 09-08-2011, 01:20 PM   #5
Friends: (327)
If all else fails, you will have to program the ESC with the transmitter, Thats what i dont like with cheapy ESC
http://www.rctimer.com/index.php?gOo...51&productname=
2 lines 1/1 pages1
Comments : dudflyer | 2011-05-18 01:34 | CheckdudflyerShow all
Total 4.0
see above review for programming link I used it and it worked fine it is quite simple to program once you print off the instructions. Speed control seems to work fine for me so far does get warm though not hot pulling about 38a heat sink works well as the warmth gets dissapated quickly.
Do you think this comment is helpful?
0(0 in total) visitors think it helpful
Comments : mamcrackin | 2011-02-01 11:06 | CheckmamcrackinShow all
Total 0.0
Here is a link to programming instructions.... http://www.rcgroups.com/forums/attac...mentid=2433925 ESC has worked great so far and remember this ESC does not have a BEC.. You will have to get that also....
4(4 in total) visitors think it helpful
Old 09-08-2011, 01:27 PM   #6
Friends: (327)
and you could have gotten a bad esc programing card. but i really think that not having a bec built into the 50 amp esc is causing the problem, where as the 40 amp size and under have a built in bec, so thats the reason i suggested adding 5 volts to where the esc would normally feed bec voltage via a y connector, hope that helps, Chellie
2 lines 1/1 pages1
Comments : mawin | 2011-07-10 23:43 | CheckmawinShow all
Total 0.0
Hi, I just got my program card and it works wery well with ESC RCTimer >10A but 6A ESC RCTimer not worked. It doesn't work with Turnigy 20A UBEC ESC, H-King ESC, HobbyKing HK-18A ESC If it works it seems to be a good product.
Reply by vendor
Hi Mawin,
Thanks for your enquiry, this is Official Program card of Hobbywing, it can use for our ESC10A/18A/20A/30A/40A.
Thanks.
Comments : timmybeetle | 2011-04-28 12:33 | ChecktimmybeetleShow all
Total 0.0
Warning......???!!!! I have this program card BUT it doesn't work with some ecs. I have several ECS from hobbyking, mystery and some others but none of theme works with this card. I had one ecs 30A which sadly burned out due to bad Motor which worked with this card. But if it works it is a great and easy tool too use. greetings hans
Reply by vendor
Dear sir,
This program card can use on Hobbywing, Hobbyking and RCTIMER ESC, if the card still cann't work with them , please return it to us, we can resend a new to you.
RCTIMER
http://www.rctimer.com/index.php?gOo...88&productname=
Old 09-08-2011, 05:31 PM   #7
Friends: (19)
I have to say that considering many of the Hong Kong / China sellers ... RCTimer does try hard to satisfy / help it's customers.
I use RCtimer a lot for motor / ESC gear and only problem I have had is actually post service ... NOT RCTimer.
I am a customer of RCTimer and have no commercial or other interest.
Old 09-09-2011, 02:39 AM   #8
JZSlenker
JZSlenker's Avatar
Well I tried the Y adapter to no avail. I don't get any lights on the card whatsoever. I guess the programming card is bad. I started down the road of programming with the TX. Four programmed, four more to go tomorrow. Talk about losts of beeps.
Connecting esc to motor: RONALDO_UK General Electric Discussions 9 08-24-2011 09:56 PM
Seperate RX battery..does the LIPO pack need to be connected to program the ESC liposucker General Electric Discussions 6 06-12-2011 01:40 AM
ESC programming card compatibility? DanWard Beginners 1 04-01-2011 09:19 PM
Help Weird constant beep noise when connecting the battery, esc, and motor to the receiver jbar1001 Support & Suggestions 6 02-20-2011 04:15 AM
Page generated in 0.14386 seconds with 34 queries
