Old 09-16-2011, 04:06 AM   #1
Monterey10
Monterey10's Avatar
Club: RCBees
Send a message via Yahoo to Monterey10
Question Slow stick motor
This motor appears to be a high speed motor, not suitable for the slow stick. This motor turns a 5X7 prop.
http://www.hobbyking.com/hobbyking/s...idProduct=5428
I gather the slow stick needs a large propeller moving at a slow speed. Or, will the small 5X7 be okay?
Thanks in advance.
Monterey10 is offline
Old 09-16-2011, 04:20 AM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
It'll work, but not optimal.
SS is a s..l..o..w.. plane (as designed-some folks seem determined to deviate from this design).
Works better toward that goal, with a low KV motor (800-1000) turning a larger prop (~10").
fly
flydiver is offline
Old 09-16-2011, 04:46 AM   #3
Monterey10
Monterey10's Avatar
Club: RCBees
Question Outrunner
What is the popular stick mount, low KV, outrunner these days?
Old 09-16-2011, 06:12 AM   #4
flydiver
flydiver's Avatar
These days? Not a clue since I don't pay attention. I use anything in the 50-70g range with a low KV. It's a SS, doesn't matter a whole lot.
Stuff like this will work.
http://www.headsuprc.com/servlet/the...-Slofly/Detail
http://www.headsuprc.com/servlet/the...ushless/Detail
You knew yours wasn't optimal. Where did you get that info? There are threads and threads and threads on the SS. Do a bit of searching.
fly
flydiver is offline
Old 09-16-2011, 06:47 AM   #5
HeliScRapYard
Foam Junkie
HeliScRapYard's Avatar
View HeliScRapYard's Gallery3
Send a message via AIM to HeliScRapYard
Alot use the 2410-09Y from headsuprc.com try it out with a 3s and 10x4.7 prop.
Need More Glue!!!
HeliScRapYard is offline
Old 09-16-2011, 07:26 AM   #6
flydiver
flydiver's Avatar
I looked for that. It was my very first brushless on my original SS. In fact, it still hauls the original (with a new wing) around but I rewound it after the wires broke.
He doesn't seem to carry it anymore. I think it's being phased out. TP may be getting out of the 'bell' motor production I read speculated.
Looks like you can still get it an HobbyKing. Ah, nope-back ordered. A mess of them are. Phased out after all?
Maybe this one: http://www.hobbyking.com/hobbyking/s...00kv_180W.html
Have to get a stick mount for it.
fly
flydiver is offline
Old 09-16-2011, 02:21 PM   #7
Monterey10
Monterey10's Avatar
Club: RCBees
Default 2509
I checked my box of stuff and found a 2409. I'll put it on the stick.
What plane would use the stick mount motor mentioned above?
Old 09-16-2011, 03:11 PM   #8
HeliScRapYard
Foam Junkie
that might work good with a 800mm airfield warbird from Nitroplanes.
HeadsUp still has the 2410-09Y. Just now labeled the HURC 2410 instead of the TP 2410. http://www.headsuprc.com/servlet/the...ushless/Detail
Need More Glue!!!
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 146 05-07-2013 03:24 PM
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 255 01-03-2013 11:49 PM
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 05:33 PM
Slow stick adjusting downward motor thrust? Monterey10 Beginners 9 09-14-2011 03:50 PM
Page generated in 0.20886 seconds with 33 queries
