Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Special Interest Aircraft
Old 09-16-2011, 03:32 PM   #1
flightmode
Default The odd airplane that i fly
This airplane really flies different. It took me awhile to get it under control, but it works including doing a loop. The key is that you can do only aileron or elevator, not both at the same time. Rudder helps.
flightmode is offline
Old 09-16-2011, 04:35 PM   #2
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
That's pretty nifty! Can you post a few pics of how your control surfaces are done? I might have a suggestion or two that would allow both aileron and elevator to work simultaneously.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is online now
Old 09-19-2011, 12:08 AM   #3
flightmode
I will get some pictures to you soon, but if you look at the video where it sits on the chair, the rudder is in the back of the vertical component inside the ring. Aft, the horizontal slab is divided in 2 segments to make up my elevron.
Old 09-19-2011, 01:30 AM   #4
crxmanpat's Avatar
Friends: (24)
OK, so here's what I would suggest. At the rear of the center section that is horizontal inside the loop, I would cut ailerons into the foam and then ditch the elevator on the rear altogether. Then use only 3 servos total, 2 for elevon and 1 for rudder.
This would give you both elevator and aileron control together.
Pat Gagnon
Old 09-19-2011, 07:23 PM   #5
flightmode
Thanks for the tip.
I had thought about it, but decided no, because the circular section flys about 20 degrees up in normal flight. So if you try a loop or go real steep, you will have poor and turbulent airflow across the control surfaces. When I added the rudder, it does not help that much in a turn. As you can see, I got good control at the end and that is good enough for now.
Anyway, I am working on about 3 other projects (STOL, airbrakes, and high alpha)so this one is on the back burner for now. If I ever run out of projects, might try your suggestion. In fact, thanks to you, I might even set up dual elevrons with one set of servos.
Have you ever thought about using dual set of elevrons on your mini F-22 using only 2 servos?
Old 09-19-2011, 08:46 PM   #6
crxmanpat's Avatar
Friends: (24)
I have done that on the bigger birds, but on the smaller ones it is not necessary. But on the bigger ones it does help with the roll rate.
Pat Gagnon
Tags
foamy , hoop , odd
Fly Zone Sensei Rx-R guapoman2000 Foamies 8 11-27-2011 09:06 PM
fly with your head,not over it..advise to begginers experience level stuart Beginners 28 10-05-2011 11:58 PM
Beginning airplane to see if I like RC Sidhewynder Beginners 24 07-29-2011 01:38 AM
How to Fly an HZ Champ wolfewinde Beginners 2 06-16-2011 02:15 AM
Page generated in 0.73788 seconds with 30 queries
