Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 09-26-2011, 08:21 PM   #1
brutus251
"nin caca da manga"
brutus251's Avatar
Club: Rhode Island Soaring Club
Default The best iron on covering for small BALSA planes?????
Im having a heck of a time covering the wings on my Electrifly Fokker DV11. I ran out of the covering I had which worked like a charm,it was noticeably thinner than the MonoKote I just bought which is much thicker and just wont do.The thinner brand stuck easily,stretched and shrunk easily too.The MonoKote is fine for my bigger projects but its too heavy duty for this plane.I dont remember the brand I used before,any help would be appreciated. Thanks. Brutus
"Its the exact same thing, just completly different"
brutus251 is offline
Old 09-27-2011, 02:07 AM   #2
TM4197
Dope&Fabric
TM4197's Avatar
Club: Mile High Club
Did you buy it online? or at a LHS?
TM4197 is offline
Old 09-27-2011, 02:51 AM   #3
DH82Junky
Don't know what you were using, but Coverite Microlite has the qualities you described, plus the aggravating habit of sticking to itself while trying to apply it.
I still like the stuff, though.
David
DH82Junky is offline
Old 09-27-2011, 01:28 PM   #4
brutus251
"nin caca da manga"
brutus251's Avatar
The LHS, Ill give the Micro a try. Thanks guys. Brutus
Old 10-25-2011, 09:13 PM   #5
7car7
7car7's Avatar
View 7car7's Gallery37
Friends: (12)
Did you ever try the Coverite Microlite? I've wanted to try that also, just haven't yet.
7car7 is offline
Old 10-25-2011, 10:16 PM   #6
Henry Sistrunk
Henry Sistrunk's Avatar
1kW  2kW
Friends: (13)
I used that one time. Just had a time keeping it from sticking to its self, then while trying to unstick one place it would stick in another place. Did a good job but not worth the trouble.
Henry
Henry Sistrunk is offline
Old 10-25-2011, 10:53 PM   #7
Henry Sistrunk
1kW  2kW
Friends: (13)
Used it on a Herr Cherokee. Here are some photos.
Henry
Name:	Cherofee Finished 007.JPG
ID:	154259   Click image for larger version
Name:	Cherofee Finished 006.JPG
ID:	154260   Click image for larger version
Name:	Cherofee Finished 005.JPG
ID:	154261   Click image for larger version
Name:	Cherofee Finished 002.JPG
Old 12-01-2011, 08:06 PM   #8
littleimp
Tissue & dope would be my choice for this too be honest. iron on covering doesn't add strength as much as this.
littleimp is offline
Old 12-10-2011, 06:36 PM   #9
Friends: (18)
For older planes and WW1 jobs - I use Solartex - a UK shrink material that has a fabric look and feel to it. Only downside is it is heavier than the gloss plastic shrink, so not really suitable for really small models.
I have to admit that a WW1 machine in glossy plastic film is not really what I like to see ...
Old 01-03-2012, 11:37 AM   #10
trumps1
personally i would use either litespan or polyspan, both work beautifully on small models, litespan being my favourite due to not needing to be sealed but polyspan being porous works better in my opinion on covering sheeted/planked structures due to being doped down once shrunk to lock the structure together.
the pup was covered solely in litespan
the Pfalz wings and tail surfaces were covered in litespan, and the fuse being planked was covered in polyspan.
the F2b will be covered in litespan and even though nearly 70'' w/s should work out just fine.
an added feature of moth materials is that they have a surface texture, and take paint extremely well!
my 2 bits anyway
Craig
trumps1 is offline
Old 01-03-2012, 02:53 PM   #11
CarreraGTSCS
CarreraGTSCS's Avatar
Trumps-- Beautiful models. Is the F2b the Manzano Laser version?
Where can you get polyspan and lifespan? Do you use Nitrate or Butyrate dope?
I'm just getting back into balsa and I haven't used dope in at least 35 years.
I saw in Rob's Halberstadt thread you mentioned that you painted the lozenge on the Pfalz. Beautiful work.
Thanks,
CarreraGTSCS is offline
Old 01-03-2012, 03:33 PM   #12
trumps1
Thanks Mike,
i am only new at this building caper, the pup and pfalz were my first 2 builds with the F2b being number 3, and yes the F2b is the Peter Rake designed one from Manzano's. i airbrushed the lozenge, and comet motifs after a lot of mask cutting with frisket.
the litespan and polyspan are available from Peckpoymers
http://www.a2zcorp.us/store/category.asp?Cguid={FD3F1D5A-2F40-41A2-B176-4547219B3607}&Category=BuildingMaterials:Covering
i forgot to mention that while both these coverings are heat shrunk they do not have an adhesive backing and are applied to the airframe using Balsaloc which is like a whiteglue and is painted onto the airframe, let dry and the covering ironed on as per normal. the dope i use is the only one locally available and from what i can gather reading the MSDS it is a Butyrate dope.
Craig
trumps1 is offline
Weller W100PG 100 watt soldering iron kyleservicetech Batteries & Chargers 18 05-16-2014 03:51 AM
For Sale Aluminum Motor Mounts for Multiplex, Parkzone, and Flyzone Super Cub Planes terrynshed Motors and Speed Controllers for sale & WTB 4 09-24-2012 05:33 PM
Some of my "under $100" scratch-built planes. warhead_71 Scratch and Kit Built Aircraft 4 05-04-2011 01:55 AM
Ultra Micro planes gear in the 250 size planes wattman WWI Era 4 03-31-2011 04:12 PM
3DHS 330SC - removing wrinkles from covering DanWard Beginners 2 12-12-2010 06:49 PM
Page generated in 0.34476 seconds with 47 queries
