Old 10-01-2011, 08:05 AM   #1
n3o
Default Nimh selection + A123 selection
Hey guys!! I have access to huge number of nimh batteries . I wanted to use them on a 2212-6 motor. Can you please tell me what should be the rating of the battery. or the exact name of the Nimh battery you have used successfully on a 2212-6 or similar motor.
-n3o
n3o is offline
Old 10-01-2011, 12:38 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
What type/size of cells are they AA? Some will work fine but others won't take the amp draw.
Old 10-01-2011, 02:40 PM   #3
n3o
yeah they are in different sizes.Can you recommend specific one which i can use with a2212-6 motors?
n3o is offline
Old 10-01-2011, 03:40 PM   #4
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
That's a fairly high amp draw motor. If your NiMh are like retail grade (AA off the shelf) they simply won't do it worth the bother.
You want to try you'll need ~ 10 of them for ~12v. Weight can become an issue pretty fast.
fly
flydiver is offline
Old 10-01-2011, 04:36 PM   #5
n3o
yes , the auw is beyond acceptance. But then, what motors are ideal for nimh batteries? the small ones requiring 15A esc? considering the AUW i am guessing that only gliders can utilize whatever punch the battery has to offer!!
n3o is offline
Old 10-01-2011, 04:41 PM   #6
flydiver
flydiver's Avatar
Lots of motors run fine on NiXX. My old Super Cub was NiMh powered as is the stock Easy Star.
It all depends on what the NiMh actually ARE performance wise, and what kind of weight you'll accept. The car guys still use them but they don't use consumer grade NiMh.
The battery has to be designed for higher output (lower internal resistance) for higher power applications. The 2212-6 is a high KV fairly high performance small motor.
fly
flydiver is offline
Old 10-01-2011, 07:14 PM   #7
WAA-08 Pilot
Friends: (9)
Sub C cells would be nice - what do you have?
Old 10-01-2011, 07:31 PM   #8
slipstick
The good (for motor current) NiMH batteries are nearly all short fat ones...like Sub-C or 2/3A sizes. I still use a few of those.
The commercial sizes like AAs will rarely provide enough current and the higher the capacity crammed into them the less likely you are to get high currents out of them.
slipstick is offline
Old 10-01-2011, 10:34 PM   #9
WAA-08 Pilot
Friends: (9)
+1 - what Steve said - 2/3 A cells likely OK too. NOT AA's. Small sub C's too 1300's or so.
Old 10-02-2011, 02:44 AM   #10
Friends: (18)
-n3o
Depends on the type of Nih batteries you have. The quality and internal resistance of these batteries can vary all over the map. A lot of those "AA" size Nih batteries with 2000 Mah plus just can't put out the current these motors can pull.
For an AA Nih battery, anything over a few amps is suspect. A while back, I did a 12 Amp high current testing of a 2700 Mah 5 cell name brand AA battery. At 12 Amps, that battery dropped to 3.6 Volts DC.
If you're planning to put this setup into a model airplane, you are going to pay the penalty for a lot of extra weight, as compared to a LiPo, or an A123 2300 Mah cell.
Take a look:
http://www.wattflyer.com/forums/showthread.php?t=47965
Old 10-02-2011, 09:26 AM   #11
n3o
wow thank you all for very informative replies! well the nimh i have are sub-c types as well AA, but the guy showed me a HR-4/5AUP pack which he said is used for rc planes. keeping in mind the weight penalty, i will be using nimh on supercub just like flydiver. for fast parkjets i will stick to lipos!!
-n3o
n3o is offline
Old 10-02-2011, 05:06 PM   #12
flydiver
flydiver's Avatar
Let us know if that works out for you. No one I know actually goes back to NiMh after they've tasted lipo, not even on the super cub.
fly
flydiver is offline
Old 12-01-2011, 02:01 PM   #13
FuglyGear
Default High rate NiMH AA's
If you're committed to the NiMH platform and you want some smaller lighter ones that will yield high amps, they do make 10c AA's and even some smaller varieties. I have a ton of the 2000mah 10c AA's that in fact yield discharge rates of 20amps continuous if you're interested.
FuglyGear is offline
Old 12-02-2011, 04:21 AM   #14
n3o
No it didn't .. partly because of my amateur attempts =D .. and partly because of my poor electronics knowledge =(
n3o is offline
Old 12-02-2011, 04:28 AM   #15
flydiver
flydiver's Avatar
We learn more from our mistakes than our successes.
Therefore > success!
fly
flydiver is offline
Old 12-02-2011, 04:46 AM   #16
n3o
After a long search I found this battery pack in an abandoned project of some solar powered car. I removed the covering tape and found this!! but i cant find any kind of markings on them i.e A123 or Moli but they do seem more like moli. =D
please help to recog these cells... and how i can use 'em.
-n3o
P.S: how do i remove those strips without damaging the cells?
oh and its 4 " in the last pic
n3o is offline
Chinese NiMH packs on eBay Winston Batteries & Chargers 11 09-20-2011 01:19 AM
Need help charging nimh Mtr packs partzee Batteries & Chargers 8 08-10-2011 08:08 PM
For Sale New Turnigy Accucel Accucell 6 50W Lipo NIMH Charger & accessories. $46 shipped maverickma Batteries and Chargers Forsale/WTB 0 03-06-2011 04:57 PM
What Charge Rate for 4.8v, 150mAh NiMH Pack? exit44rc Batteries & Chargers 9 02-04-2011 04:10 PM
Page generated in 0.39956 seconds with 54 queries
