Old 10-09-2011, 03:25 AM   #1
schusterjo
Default NexSTAR EP Trainer Select RTF 38 (battery question)
Ok I have a
Hobbico NexSTAR Brushless EP Trainer Select RTF 38
coming next week an the typical batter suggested is 2X 8-Cell 9.6V 3600 mAh NiMH... I read that Lipo will give you longer flight times an just a better flying experience. problem here is cost So, i have been reading came across the post i have quoted that also mentions the lipo batteries. for some reason I cant find the page that explained in detail about how to set up the plane using lipo....
Few questions
Does the batter Lipo or NiMH have to be exactly 3600mah ? can they be 3800-4000 mah? if the voltage is correct the mah is current an will only draw what the motor is asking for correct? am sure there has to be some resistor/capacitor in the power system to keep a steady current to the motor I would think.
So can i get a larger mah battery with the same voltage?
Whats the difference between racing battery an other batteries? couldn't u still use it in a plane?
Here
Polyquest 3200mAh 2S RLP 18C Racing Lipo Pack
well i guess i cant post links so goto hobbyking check out produce 9157 an 7295
the other lipo battery with a higher mah i was looking at
Rhino 3700mAh 3S 11.1v 20C Lipoly Pack
if i could use these battier an to have any issues that would be great because the price is exactly what i would like to spend
Jo
Hi
That aircraft is setup for dual packs only in the stock setup
The following is a list of accessories required to make the NexSTAR
EP Select operational. Order numbers are in parentheses.
(2) 8-Cell 9.6V 3600 mAh NiMH (Nickel-Metal Hydride)
battery packs (GPMP0362)
Hobbico Dual Peak NiMH Charger (HCAP0255)
The NexSTAR EP Select can also be fl own with a 5-cell
Lithium-Polymer (LiPo) set up. If you decide to go with LiPo
batteries, you will need the following items:
*2S 3200mAh 7.4V 20C Discharge w/Balance (GPMP0622)
*3S 3200mAh 11.1V 20C Discharge w/Balance (GPMP0623)
(*Use them together for a 5S set-up
Hope this helps
Take care
Yours Hank
schusterjo is offline
cox 20" Extra 300 EP RTF A_Smith ParkFlyers 12 02-26-2013 07:40 PM
Wanted Wtb hobbico/tower ep trainer kvflyer Airplanes - Electric For Sale & WTB 1 07-21-2011 04:39 PM
NexSTAR EP Maiden Duco Beginners 1 07-11-2011 04:13 AM
Nexstar ep select 68 inch battery question? Flysohigh General Electric Discussions 2 06-14-2011 01:26 AM
Nexstar ep esc question??? Flysohigh General Electric Discussions 5 06-12-2011 09:38 PM
Page generated in 0.06605 seconds with 19 queries
