Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Scale E-Powered Aircraft
Old 10-09-2011, 02:30 PM   #1
woodfit
Default Wattage figures on Pitts
Hi Guys
Finally got my watt meter coupled up to my Pitts with the new lipo's, it appears to have a stonking 2340 watts at full power with a 6s and 2s in series both 5000MaH and both at 40c, question is will she fly ?? Oh and the rpm without the prop was 7800 rpm good or bad?
woodfit is offline
Old 10-16-2011, 08:51 PM   #2
payne9999
That's gonna leave a mark
payne9999's Avatar
Club: Hillsboro Fly-A-Ways
How much does she weigh? Size and pitch of prop? I am assuming it is converted from a gas powered design. If so, what was the original required displacement?
Dave
payne9999 is offline
Old 10-17-2011, 04:40 AM   #3
2013 President of PSSF
Rule of thumb would say 2340 watts should fly 11 1/2 lbs in 3D maneuvers, and 23 lbs in aerobatic flight, even more in normal flight.
BUT these are all assuming you have the plane properly setup with the correct prop and getting the rpm you should have. At 8s you could put 2340 into too small a prop and not get airborne. It seems at 8s your motor will have to have a very low KV.
Give us more information, and we can be more help.
Dave R, Proud PGR rider.
Wildflyer is offline
Old 10-22-2011, 05:39 AM   #4
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery82
Club: rcg staff
Friends: (17)
Originally Posted by woodfit View Post
Hi Guys
I first read this and thought: A Wattage Pitts with 2340 watts is just a bit out of hand.
I heard that they had somewhat mediocre performance on the oem setup, but that's just a bit overkill.
Bill G is offline
Old 11-08-2011, 11:12 PM   #5
CT4
CT4's Avatar
What every one forgets is that all watt meters give you watts in not watts out. 2340 watts is way over the top but you will (I hope) not be flying WOT for the whole flight, at say 1/2 throttle where it is lightly most of your flight will be done you only will have about 1000 watts, good for a lively flight on a 7 pound aeroplane.
There I was.. Inverted,,nothing on the clock..and only my joystick in my hand
CT4 is offline
Old 11-09-2011, 05:47 AM   #6
Friends: (16)
Hi Guys
Yup
As others in this thread have indicated, we need to know model wingspan, weight, motor brand and model number, propeller size. (That 2340 watts could be with a 28 inch propeller with 2 inch pitch! )
One good program to sort this stuff out is www.motocalc.com. However this program is only accurate if quality motors are used, where the manufacturers motor specifications are accurate. With some of the real cheap motor stuff on the market, that may not always be the case.
I've got a Hacker A60-16M motor, swinging a 19X12 APC-E wide blade prop at 6800 RPM on a 78 inch wingspan, 19 pound airplane. That power system runs near 3000 watts at full power, and pulls the model off the ground in about 30 feet.
Take a look:
Carl Goldburg Extra 330 Electric Conversion
http://www.wattflyer.com/forums/showthread.php?t=59273
Giant Scale electric motors vs Gasoline Engines
http://www.wattflyer.com/forums/showthread.php?t=58035
Pitts special kit woodfit Scratch and Kit Built Aircraft 3 09-10-2011 07:12 AM
Wanted E flite Pitts Model 12 battery hatch Hernthehunter Airplanes - Electric For Sale & WTB 29 06-11-2011 06:38 PM
Sold Wattage Tangent Micro Pattern kit NIB evlwevl Airplanes - Electric For Sale & WTB 1 04-16-2011 04:47 AM
HobbyKing Pitts Model 12 JetPlaneFlyer Sport Planes (Formerly I/C & Gas Conversion) 10 03-28-2011 12:30 PM
For Sale Wattage Mig-15 NEW in BOX fieldofdreamsflyer Airplanes - Electric For Sale & WTB 0 03-05-2011 07:50 PM
Page generated in 0.20289 seconds with 29 queries
