Old 10-09-2011, 08:52 PM   #1
Monterey10
Monterey10's Avatar
Club: RCBees
Send a message via Yahoo to Monterey10
Question Alpha 450 landing gear
I scrounged up a used Alpha 450. On my 4th landing, the plywood block that holds the rear landing gear fell out. (on a fairly smooth landing I might say) Looking at it, it appears that there was just a tiny amount of CA (?) holding the balsa block into the airframe. Because of this, there was no damage to the block or airframe.
I am inclined to use epoxy on the block back to attach it to the air frame. This would give it more strength. Is this the correct idea, or, shall I use a minimal amount of CA, to allow the landing gear to break away again ?
I suppose the best idea would be to have it rubber mounted so it gave on harder impacts and still held the plane on normal landings. I don't see how I could do this on the bottom of the plane.
Thanks in advance.
Monterey10 is offline
Old 10-11-2011, 07:32 PM   #2
max2112
max2112's Avatar
View max2112's Gallery80
Globetrotter Pilot
Friends: (13)
Thanks in advance.
That's exactly what I would do M-10. Not a whole lot, but at least 2 or 3 drops on every mating surface.
The front gear is pretty sturdy on mine, so I believe if something bad enough happens to rip the rear landing gear off- you're going to be doing some pretty serious fuselage repairs any how!
Please Keep us posted on how it goes!
Please call me John. I came up w/ Max2112 when I thought you were all internet predators after me Lucky Charms!!
max2112 is offline
Old 10-11-2011, 08:06 PM   #3
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Use epoxy and some triangle stock to increase the glue area.... That tri stock has a huge glue area on the block and transfers the load to the sides...
Old 10-11-2011, 09:43 PM   #4
dkrhardy
Club: AMA & ECRCC & RAMM
f you can use nylon bolts to hold the gear in place, use them! They shear off easily and save the fuse from damage most every time. I would rather do that and securely glue in the wood block.
dkrhardy is offline
MSR - indestructible landing gear and severely reduced tail blowout TBO Thewyzardofdogz E-Flite Helicopters 2 06-25-2011 10:42 PM
Projet f4 retractable landing gear tires lvjet Electric Ducted Fan Jets 0 05-29-2011 04:49 PM
MSR aluminum tube landing gear Thewyzardofdogz E-Flite Helicopters 1 05-05-2011 03:27 AM
MSR carbon rod reinforced landing gear + permanent 250mAh Li-Po holder Thewyzardofdogz E-Flite Helicopters 1 03-19-2011 06:52 AM
For Sale Landing Gear - Flaps Sown Down Module BEAR-AvHistory General RC items For Sale and WTB 16 03-04-2011 04:04 PM
Page generated in 0.06252 seconds with 25 queries
