Old 10-19-2011, 05:01 PM   #1
2014 President of PSSF
Friends: (7)
Default Super strong corner construction
I am building an old Astro Challenger kit, I have had since the mid 80's. It will be modernized as far as motor, battery and ESC goes, but otherwise stock. I am starting into ALeS competition.
I reinforced the corners of the elevator and rudder with CA hinges, some of you may do this, but some of you may not have thought of it,
Basically it is simply cutting a slot into the joint after it is glued together and inserting a CA hinge or a cut piece of one as I did.
I think the pictures will show it better. I believe this way is stronger and lighter than putting a gusset in the corner.
ID:	154051 cut thru center line
ID:	154052 uncut hinge to show how far I went
ID:	154053 trimmed and sanded, will not break here!
Dave R, Proud PGR rider.
Wildflyer is offline
Old 10-19-2011, 05:41 PM   #2
Friends: (18)
Now that is a very clever idea that would add little weight to a model. And if you've got a Great Planes Slot Machine, that would make the required slot even easier to do!
Old 10-19-2011, 06:41 PM   #3
Friends: (7)
HI Denny
I have the slot machine, but I think I need to get new blades. When I tried it, the blades spread apart as they went in, so the micro saw worked much better and is not much slower than a slot machine.
10 of my full size CA hinges weigh 1.2 grams, I cut most of them in half, so each joint is 0.06 grams, plus the CA clue it self, I don't know how much that would weigh but not much.
EasySky 2.4G 4ch Micro Super Piper Cub J3 EasySky ParkFlyers 8 11-26-2011 05:47 AM
For Sale Aluminum motor mount for Flyzone Select Scale Super Cub and 450 size motor terrynshed Motors and Speed Controllers for sale & WTB 43 09-04-2011 04:32 PM
"Best Super Cub, Ever" (well, maybe not) KenSue ParkFlyers 5 05-15-2011 04:16 PM
2 scratch builds, 2 differnt types of construction Saucerguy2 Scratch and Kit Built Aircraft 2 02-11-2011 03:44 AM
For Sale HZ Mini Super Cub All American Airplanes - Electric For Sale & WTB 2 02-08-2010 09:17 PM
Page generated in 0.26343 seconds with 28 queries
