Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 10-19-2011, 06:14 PM   #1
icarus46
icarus46's Avatar
Default Balancing a N-28
Have a question about balancing my WWI 1/6th n28. It's electric power so I need lots of weight in the short nose. My question is, should all the weight, if possible, be in the cowl?
It seems like if I put all the weight as far forward, (in the cowl) this may cause constant nose overs on landings.
If I put some weight in the cowl and some on the firewall, it seems this may help eliminate nose overs but would also make the plane heavier.
How do you guys typically distribute the weight for balancing a WWI bird?
icarus46 is offline
Old 10-19-2011, 06:21 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Correct CG is correct CG, period. So if you have to add weight - as far forward as possible gets you there, as you point out, means you add less (desirable).
Nose overs are just a fact of life with some planes. You learn how to decrease chances but it is always a factor. The solution is more tail weight - but then they don't fly, or more accurate they only fly once.
Old 10-19-2011, 08:44 PM   #3
TM4197
Dope&Fabric
TM4197's Avatar
Club: Mile High Club
I have to agree with rcers. You want that weight up front. The most recent Model I have is the (HK Spad) this girl has three weights attached to the inside of the engine cowling from factory...and believe me,, it feels heavy. But you will get many flights on her even if she does the ole WW1 plunk at the end vs tail heavy. I have noticed with the Spad, on hard surface (dirt) I can keep her nose up by full aft elev after touch down...on grass...its a coin toss!!
TM4197 is offline
Old 10-19-2011, 08:50 PM   #4
TM4197
Dope&Fabric
TM4197's Avatar
BTW: is it a Aerodrome N-28?
TM4197 is offline
Anyone near PA want to fly a contest Aug 27, 28? AEAJR Hi-Performance and Sailplanes 0 08-19-2011 11:04 PM
For Sale Maxford USA Nieuport 28 EP 40" v_dub1968 Airplanes - Electric For Sale & WTB 0 06-12-2011 02:40 PM
Balancing a Flyzone J3 Cub RightFly Beginners 0 05-01-2011 12:55 AM
For Sale ParkZone PKZ1040 2-3 Cell LiPo Balancing Chargers TWO or FOUR HeliScRapYard Batteries and Chargers Forsale/WTB 4 03-14-2011 01:02 PM
Balancing an EDF impeller... magnetic balancer vs knife edge balancer Reindeer Electric Ducted Fan Jets 2 02-22-2011 07:50 PM
Page generated in 0.07008 seconds with 25 queries
