Hum... look quite interesting for 3d.
(features from walkera)
Walkera V120D02 is not only a durable ,strong utility 3D helicoptor, but also a very good looking micro helicoptor.
Canopy-PVC film vacuum-Thermoform artwork make the exterior even and elastic. Mixing with beautiful red ,black and white color ,enjoys your eyes.smooth bow ,clear mark print show no flaw at all
Main blades---Using unique compound material technology,increase the toughness 100%.
light weight promoted the performance a lot;bright and shinny surface,Applying for the silk screen printing artwork on the surface,make the font and graphic more vividly
Skid landing---Adopting the newest engineering plastic material,promoted the skid landing elasticality ,strenthened its durability .Intergrated battery holder and skid landing mold artwork give good consideration to skids intensity,space,and balance.slightly leaning forward stabilizer is in pleasure of sense stable.
Drive gears: Newly upgraded drive gear set. By increasing the contact area and use of low friction materials. The drive train is more durable then previous design, at the same time more reliable and less rotation resistance...
Servo----micro 3g servo ,have been applying in WALKERA classic helicoptor like 4G3,4G6, and flybarless 120 size series models, wide applicability,good quality,stable performance, smart body with prompt response, big torque,the maintenance is simple and convinience,
Shaft driven-------besides the shaft driven feature of high efficiency, the square-shaped carbon fiber tail boom ,not only fixed the horizontal angle but also leave perfect space for the shaft driven structure, manifested the design equisition.
Stabilizer-----brand new hardened body, carbon fiber tail stablizer, plus delicate processing and metalic joints ,showed the V120D02 professional 3D helicoptor charming.
Motor-----upgrade from inner brushless motor to the outrunner brushless motor(WK-WS-15-001) 12000KV, the weight is barely over 8.8g, revolutions is higher ,weight is lighter, loading tempreature is lower, performance efficiency is more excellent, power is stronger.Hurricanes,loops,funnels,rolls and inverted flight performaned with great enthusiatic
Flybarless control system------------- upgrade Receiver 2622V is not only a integration and miniaturization but more important a comprehensive optimized program ,which made the performance of hurricanes,loops,funnels,rolls and inverted flight relaxed,comfortable and smoothly,
