Old 10-26-2011, 06:01 PM   #1
cyclops2
Default 5...Futaba Attack 3 sets not working. Why ?
The throttle channel only works a servo in the stick down direction. Other channel, rudder is fine with the same servo.
If plugged into the throttle channel. The arm is always at 45 degrees off center.
ALL 5 old sets are doing the samething with different servos. Throttle sticks are all in center position. Spring return & centered.
I want to use them in a summer childrens program.
cyclops2 is offline
Old 10-28-2011, 01:35 AM   #2
A.T.
Club: To many to include.
If plugged into the throttle channel. The arm is always at 45 degrees off center. ALL 5 old sets are doing the samething with different servos. Throttle sticks are all in center position. Spring return & centered.
. Reset throttle stick.
Throttle stick has two "Neutral" positions, refer page four of attached manual.
. Center for use with F/R EP models.
. Lowered "center" for use with GP models which require longer throw for throttle and short rearward "brake".
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 10-28-2011, 02:48 AM   #3
Sir Crash-A-Lot
Crash Specialist
Sir Crash-A-Lot's Avatar
Club: AzWingNutz
Futaba radios you need to make sure the throttle channel is reversed for it to work correctly.
Sir Crash-A-Lot is offline
Old 10-28-2011, 01:51 PM   #4
cyclops2
Default It is magic !!
I changed nothing.
They are all working perfectly with the throttle stick in center spring return.
Did NOT use them for 10 to 20 ++ years. Did they have any memory chips that could have been revived after having power on all of them ? All did not work before lunch. All worked after lunch.
Maybe they were hungry to.
Rich
cyclops2 is offline
For Sale New Futaba 8UAP & Futaba Fasst 2.4ghz Conversion $220 shipped! storm2313 Radio Equipment For Sale & WTB 0 08-11-2011 06:58 PM
hitec 05s micro receiver and futaba radio andyrew RC Radios, Transmitters, Receivers, Servos, gyros 2 07-05-2011 12:07 PM
Wanted None Working Futaba 8U rcflyer_09 Radio Equipment For Sale & WTB 0 01-26-2011 05:26 PM
Futaba Receiver Not Working? Zocane General Electric Discussions 3 12-27-2010 09:25 PM
Page generated in 0.25521 seconds with 27 queries
