Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > FMA Direct
Old 10-29-2011, 04:31 PM   #1
matthewcornell
Default charging multiple mcpx batteries at once on Cellpro Gold 4S?
Hi Everyone. I've seen a number of threads on this, but I'm still confused and I'm hoping you can give me some advice. I want to charge multiple mCP x helicopter batteries (200mAh 1S 3.7V 25C LiPos) at the same time in my Cellpro 4s Gold Charger ( http://www.revolectrix.com/4sgold_description_tab.htm ), which I bought with the "CP-GP/KO" battery connector adapter ( http://www.revolectrix.com/cellpro_adapters.htm ). The Cellpro tech guy says the charger requires at least 350ma to perform a full charge, and that I'd have to parallel charge enough cells together to reach the 350ma. Isn't there a cable I can buy that would hook three or four together in parallel, with a connector that matches one of those on my CP-GP/KO? I found this one, but it doesn't give specs for its connectors or how it's wired: EA-057-B Charging Cable ( http://www.xtreme-production.com/xtr...mart&Itemid=31 ). To further muddy the water, the Cellpro tech says the cable to connect my cells in parallel would go to their CPBP7 pigtail, and would not connect through the GP/KO adapter. I don't understand why. Last two questions, a) how many could I charge at once (I've seen links to cables that connect six batteries), and b) what rate should I charge at (the Cellpro is automatic, I think). Any help would be great!
matthewcornell is offline
Old 10-31-2011, 03:54 PM   #2
Howard Matos
Production Supervisor
Howard Matos's Avatar
View Howard Matos's Gallery12
Club: Frederick Model Aircraft Club
Send a message via Skype™ to Howard Matos
Hi,
When you are talking about charging a single cell, for the 4S Gold, is the 2 outside wires, the red and black. The reason I suggested for you to use the CPBP7 pigtail is there is not a 1S spot on the adapter you purchased (CP-GP/KO). Also, I do not know the availability of a JST XH 1S parallel adapter and then, how would you connect it to the CP-GP/KO without making a modification to the connector because there is not a 1S position. The CPBP7 in my option is the easiest way to rig up a parallel adapter for charging a single cell.
There is no limit to the amount of cells you can parallel charge except that the charger has a maximum output and it would take longer to charge the more cells you add to charge.
You can use one of the auto charge rates or compute a manual charge rate. To do this, total the capacity of all cells you plan on charging. Then multiple by 1,2, or 3 for a 1C, 2C, or 3C charge rate. Example:
You have 3 of your 200 ma cells connected to charge.
3 x 200 ma = 600 ma total capacity
600 ma x 2C = 1200 ma or 1.2 amps.
This creates a 2C charge rate for 3 - 200 ma cells.
Let me know if you have any questions, thanks.
Fly More, Fly More Often!!!
http://www.fmadirect.com/
Howard Matos is offline
Sneak Peek at the NEW Cellpro PowerLab 8 Tim Marks FMA Direct 63 09-21-2012 05:09 AM
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 07:03 AM
Best (Cheapest/Safest) way to charge multiple batteries at the same time ?? Stevephoon Batteries & Chargers 8 08-05-2011 10:59 PM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 02:04 PM
Page generated in 0.18601 seconds with 21 queries
