Old 11-04-2011, 03:15 PM   #1
maurof
Default Foam reinforcing
I wanted to know your opinions about reinforcing EPO or EPP wings.
It's for a competition, so they have to be strong and very light. We always have the spar option, but I don't think is going to be ass effective for this job.
Does anyone know a good way of coating the wings to make them stronger, without adding too much extra weight? Any homemade formula to protect the wings and fuselage?
Thank you very much!
maurof is offline
Old 11-07-2011, 11:34 AM   #2
eflight-ray
eflight-ray's Avatar
You probably need to define what sort of competition, aerobatic maneuvers ?, weight lifting ?, pylon racing high 'G' turns ?. Also the type and size of model, wing shape and section, also wing thickness, as all these could determine the better and lighter method. Is the wing likely to twist, (wide chord, thin section). There are too many guesses to offer a useful method.
Spars are probably the easier method, but even then a single spar or an 'A' frame is possible. Glassing a wing adds 'ding proofing', but it's still not particularly strong on a thin wing unless you use a heavier cloth and good epoxy resin.
Ray in Wales
As I get older I think more and more about the hereafter.
I walk into a room, and think, 'now what was it that I'm here after?' :o
eflight-ray is offline
Old 11-07-2011, 12:25 PM   #3
View CHELLIE's Gallery13
Friends: (327)
+1 to many varibles, with out knowing what its going to used for, I would guess that a balsa or thin ply wood i beam and honeycombed foam inside the wing, with a lite film covering might be the lightest way to go, but then again, i dont know what your competition rules are, you need to clue us in on that there are a bunch of Nerds, Geeks and Egg heads like myself here that can help you out. Take care and have fun, Chellie
Old 11-07-2011, 12:32 PM   #4
Friends: (327)
My Favorite way to brace a foam wing is with a Square CF tube, i always brace my Foam wings to withstand 10G s, the wing is 9mm depron with a 10mm Square carbon fiber tube, its very very strong it does not take much to get to 10 Gs, http://www.wattflyer.com/forums/show...ighlight=force
Old 11-07-2011, 12:52 PM   #5
maurof
Thanks for the answers!
The competition is has 3 parts: 2 of them are freight flies (got to move around 2kg of payload), and the other is completing laps against time.
we will try to minimize the model, keep it below 1.5 m wingspan, and for the airfoil we were thinking of some standard one with a big camber. But any other ideas would be highly appreciated!!
Thanks again!
maurof is offline
Old 11-07-2011, 09:08 PM   #6
Friends: (327)
Thanks again!
ok, thats about 4.4 Lbs for us in the states are you allowed to use wood and carbon Fiber and whats the ratio of foam to other materials thats allowed, for competition against time, i would make a delta plane with the motor in the front to be on the safe side, as a pusher could give you a prop bite when launching, do you have to lift the 2kg for the lap times If you do, then i would make the plane like a OV-10 Bronco with a short wide thick wing and twin Fuselage and twin motors, the weight then can be put under the wing in the fuselage for your CG. with twin motors it will be fast, and take off in a short distance, the Bronco was made for short take offs and landings, a wide thick wing will allow it to carry a lot of weight under control. Just my 2 cents worth, take care, Chellie
Old 11-07-2011, 11:23 PM   #7
PaperAirplane
Subscribed...
PaperAirplane's Avatar
Club: None (yet...)
Friends: (7)
Sorry if this is slightly off-topic, but if you're doing a foamie then using a KF-3 airfoil (designed for heavy lifting) could be a possibility. Ive heard good things about them.
Hanger: GWS Slow Stick; Nutball
PaperAirplane is offline
Bending foam sheets into shape earthsciteach Scratch and Kit Built Aircraft 8 07-28-2011 09:42 PM
Question on covering foam RC Fan Chris Foamies 4 06-24-2011 06:58 AM
Spray foam project hayesjl Foamies 2 06-17-2011 09:22 AM
Foam or Balsa? Tom Sawyer General Electric Discussions 34 05-29-2011 09:08 PM
Now sure, finishing and painting foam planes winggunner46 Beginners 8 03-01-2011 12:25 AM
Page generated in 0.07206 seconds with 31 queries
