Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Vintage and old timer models
Vintage and old timer models Discuss nostalgic vintage aircraft
Old 01-13-2012, 03:42 AM   #26
Dragonflyer
BTW my Playboy has a 67 1/2" wing. If yours is this then the CG measurements fit. Didn't realize the wing I have was so big.
If your stab is glued on then you could raise the trailing edge of the wing instead. This will change the incidence of the stab in relation to the wing. It also would give up thrust so you still may have to play with the downthrust for powered flight.
Bill
Dragonflyer is offline
Old 01-14-2012, 03:29 AM   #27
Patsy2Shoes
Patsy2Shoes's Avatar
Club: Meroke RC club (Long Island NY)
Hi Guys
Today I had an oportunity to look a little further at the Playboy.It has a wingspan of 50 1/2 inches the wing cord is 7 inches .the CG on the plan is 50 % at 3 1/2 inches from the leading edge.
I have been able to make a temporary stop for the front of the wing on the pylon .The wing can be moved back as a temporary basis to try some gliding experiments .It could be moved back as much as 1 inch .
I tried several locations and found that I could move the battery back into the fuselage and use the exising 3/4 oz. of lead in the nose and still get a nose down balance wiith the wing moved back just 5/8 inches .
I think this is a reasonable starting place for the next maiden flight .
Charlie
Patsy2Shoes is offline
Old 01-14-2012, 03:53 AM   #28
Dragonflyer
Charlie,
The @50% balance point of the cord is correct. My plans show it at the same location. My cord is 9 3/8", but still same airplane and same balance point..
I noticed in one of the pictures that you may be able to move the motor forward 1/4".
From what I gather it does not balance, correct.
Bill
Old 01-14-2012, 05:03 PM   #29
Patsy2Shoes
Hi Dragon
I have removed the screws from the motor and pulled it forward about 1/2 inch .With it in the forward position It made very little if any difference .This is because the motor is very light .If memory serves me right it is only 34 grams.
What I am going to explore today wifey permitting with honey do's is to remove the servo rods .The ones supplied with the kit were god awfull heavy and I should have replaced them with light fabricated balsa rods .I was not thinking enough at that step .As you know the tail is very long and can get heavy very easily with all that leverage.
Stay tuned
Charlie
B-47 9th Scale, Boeing Stratojet...In The Middle Flite-Metal Electric Ducted Fan Jets 275 04-26-2016 09:09 PM
Need info ,I would like to try 1/2 A electric Texico Patsy2Shoes Vintage and old timer models 15 09-12-2012 03:05 PM
Anyone interested in a Longest Flight Contest? AEAJR Hi-Performance and Sailplanes 26 07-23-2011 03:27 AM
T-bird free flight conversion F7U Scratch and Kit Built Aircraft 5 03-29-2011 06:18 AM
Page generated in 0.06449 seconds with 27 queries
