Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Combat
Combat Electric combat discussion in here.
Old 11-14-2011, 07:36 PM   #1
poiyt
Default What's a Good Motor for the Foaminator?
Fellas, I just ordered the Foaminator precut foam kit from gwsprops.com:
http://gwsprops.com/electric_combat_...as_seen_on.htm
It's a 'combat foamie'; but since the website doesn't offer more specifics, what would be some good all-around motor choices for it? I'd run 3S, either my 1000mah or my 1350mah.
Thanks!
Jeff
poiyt is offline
Old 11-14-2011, 07:59 PM   #2
poiyt
How about this motor/esc combo from Grayson?
http://www.graysonhobby.com/catalog/...ies-p-334.html
poiyt is offline
Old 11-14-2011, 10:55 PM   #3
View CHELLIE's Gallery13
Friends: (281)
the grayson combo will work, but the KVs are to low for a combat plane, here is a great 1800KV micro motor form HK and a 30 amp esc, use a 7x6 APC prop and a prop adapter, cut the prop shaft so the prop adapter fits flush with the motors bell collar, that will help to prevent the long motor shaft from bending.
here is an example of this motor with a 7x6 apc prop on 3 cells, a 1350 mah 25C lipo will work great, i use this combo all the time, it works great, dont worry about pushing this motor, as it has thick windings in it, i push them to 20 amps and 220 watts all the time with no faliures.
thats Wattflyer Kosh and his plane with this micro motor on 3 cells.
http://www.hobbyking.com/hobbyking/s...idProduct=5430
http://www.hobbyking.com/hobbyking/s...ontroller.html
use a 30 amp esc, because it will stay cooler and last longer,
http://www.hobbyking.com/hobbyking/s...ler_7x6_E.html
3mm prop adapter
http://www.hobbyking.com/hobbyking/s...t_collet_.html
7x6 APC Prop this the biggest prop that can be used, a 7x4 and 7x5 APC prop works well too
http://www.headsuprc.com/servlet/the...-7-x-6E/Detail
DX5e range test mode- what's a good distance? CNY_Dave Beginners 12 10-28-2011 03:52 AM
What's a good second plane? earthsciteach Beginners 33 09-19-2011 02:59 AM
Good Jenny Prop HobbyJumper WWI Era 4 09-03-2011 04:50 PM
IMAX B6-Pro Charger any good? dkrhardy Batteries & Chargers 7 05-16-2011 09:55 PM
Page generated in 0.30147 seconds with 24 queries
