Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 11-17-2011, 10:07 AM   #1
cobra 16
cobra 16's Avatar
View cobra 16's Gallery1
Club: Balsa Bees
Default Aerodrome RC Sopwith Triplane
I thought I would share a build of an Aerodrome RC 1/8th Scale Sopwith Triplane. I am posting this also on their website. This has always been one of my favorites and I can not say enough good things about the kit quality . This is my first non ARF project so any advice is apreciated.
Here are a few initial progress shots.
ID:	154855   Click image for larger version
ID:	154856   Click image for larger version
ID:	154857   Click image for larger version
ID:	154858   Click image for larger version
cobra 16 is offline
Old 11-17-2011, 02:14 PM   #2
spad
What servo setup for the rudder and elevator: I have one, too, but haven't figured this out.
spad is offline
Old 11-17-2011, 03:18 PM   #3
TM4197
Dope&Fabric
TM4197's Avatar
Club: Mile High Club
Thanks for sharing..will be following this one!
TM4197 is offline
Old 11-17-2011, 03:33 PM   #4
7car7
7car7's Avatar
View 7car7's Gallery37
Friends: (12)
Yes, very cool! I'm so jealous, I LOVE building kits, I just don't have a lot of spare time. Take lots of pics.
The Museum of Flight in Seattle has a tripe. It is a great looking plane.
My advice? Use silkspan or Polyspan for a more scale appearance - forget the plastic iron on stuff. That's for ARF's IMO.
Make it light as possible. If you don't have one, get a scale that reads down to at least 2 grams. A scale like that will shave grams off of each little thing you put on, and in the end will shed ounces. You'll be rewarded with a wonderful looking and flying plane.
http://www.museumofflight.org/aircra...e-reproduction
7car7 is offline
Old 11-18-2011, 03:21 AM   #5
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Spad
I will use a pull pull set up with the servos mounted in the fuselage box side by side. I know the geometry is not perfect but it has worked great on my SE5 modification. I think I took the idea either from 7car7 or dgreen. They have some pictures on the Great Planes SE5 thread. The set up on this plane should be easier since the pull wires for the elevator exit the fuselage and do not have to be routed through the horizontal stab. Ill post pictures when I get there.
7car7: Thank you for the advice. I have purchased polyspan for the build but it will be the first time I have used it. I used litespan on the SE 5 remodel. I will get a better scale. The one I have is way too much trouble for a plane this size. The pictures are a big help.
Taylor
cobra 16 is offline
Old 11-18-2011, 05:09 PM   #6
7car7
7car7's Avatar
Friends: (12)
Ya, the one in the museum is a re-make, but hopefully cross referencing with photos of a real one it may make some questions more clear.
7car7 is offline
Old 11-18-2011, 05:35 PM   #7
dkrhardy
Club: AMA & ECRCC & RAMM
On their website it says the kit includes "most of the wood required". ?
dkrhardy is offline
Old 11-18-2011, 11:44 PM   #8
cobra 16
cobra 16's Avatar
Club: Balsa Bees
dkrhardy:
It is a short kit, but in this case the only things I have had to purchase beside the normal building stuff are the leading edge material and music wire. It has the square stock and the stringer material included. It even has the wheels, dummy motor, and machine gun. Pretty complete package. The wood quality has been top notch, much better than most of the ARFs I have built.
Here are a few more pictures. The cowl is built up from ply and balsa then I chose to fiberglass it. There are other options of course.
ID:	154918   Click image for larger version
ID:	154919   Click image for larger version
ID:	154920   Click image for larger version
ID:	154921   Click image for larger version
cobra 16 is offline
Old 11-28-2011, 02:12 AM   #9
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Well some progress over the weekend. I spent a lot of time on the cowl but I am pleased with the results. I decided to use a vac-form dummy motor that I had. I’m gluten for punishment. The kit supplied one is excellent. and would have worked fine. The motor and dummy fit great and should look good when finished.
Taylor
ID:	155147   Click image for larger version
ID:	155148   Click image for larger version
ID:	155149   Click image for larger version
ID:	155150   Click image for larger version
cobra 16 is offline
Old 11-28-2011, 05:00 AM   #10
TM4197
Dope&Fabric
TM4197's Avatar
REALLY..nice work!
TM4197 is offline
Old 11-28-2011, 07:41 PM   #11
7car7
7car7's Avatar
Friends: (12)
Looking real good! Keep the pics coming.
7car7 is offline
Old 12-01-2011, 02:52 AM   #12
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Thanks for the encouragement TM and 7car. I have a lot to learn. Here a few more photos of the progress so far. The cowl cheeks are in place/ I tried to replicate the prominent former detail I have seen in most of the photos. It turned out pretty good and should look even better under the polyspan. At least thats the plan.
ID:	155208   Click image for larger version
ID:	155209   Click image for larger version
cobra 16 is offline
Old 12-05-2011, 07:52 PM   #13
CarreraGTSCS
CarreraGTSCS's Avatar
Very nice work. Good to see some building going on.
CarreraGTSCS is offline
Old 12-11-2011, 02:43 AM   #14
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Thanks a lot Mike. Here is an update. The top wing is done. Only 4 more to go. Magnets make it a lot easier
ID:	155468   Click image for larger version
ID:	155469   Click image for larger version
cobra 16 is offline
Old 12-12-2011, 05:48 PM   #15
CarreraGTSCS
I bought the Dare/Tritle Triplane. It's a bit smaller at 35" span. I know someone who's built the Aerodrome version like yours and it a stunner. I'll post some pics later for inspiration.
Old 12-13-2011, 04:29 AM   #16
cobra 16
cobra 16's Avatar
Club: Balsa Bees
I would love to seem them Mike. I almost bought the Dare version before I found this one. I also looked seriously at Peter Rakes 45 inch plane. I really liked the wing design on this one. Only one more section to go and the wings will be done. So many wings and so little time
cobra 16 is offline
Old 12-19-2011, 02:13 PM   #17
cobra 16
cobra 16's Avatar
Club: Balsa Bees
The wings are done except for the final sanding. On to bending some wire for the landing gear
ID:	155633   Click image for larger version
ID:	155634   Click image for larger version
ID:	155635   Click image for larger version
cobra 16 is offline
Old 12-19-2011, 04:42 PM   #18
7car7
7car7's Avatar
Friends: (12)
The framing is gorgeous! I really like how they give you the short ribs. (I'm sure there's an official name for them....)
7car7 is offline
Old 12-30-2011, 04:02 AM   #19
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Thanks 7car. Short ribs/sub ribs. There were a lot of them.
The under carriage structure is done. It will have a functional suspension close to scale. This is my first attempt at soldering music wire. Not my favorite thing to do
ID:	155864   Click image for larger version
cobra 16 is offline
Old 12-30-2011, 04:04 AM   #20
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Here is the bones shot. Everything fits great and seems nice and straight. Insert airplane noises
Taylor
ID:	155866   Click image for larger version
ID:	155867   Click image for larger version
ID:	155868   Click image for larger version
ID:	155869   Click image for larger version
cobra 16 is offline
Old 12-30-2011, 04:11 AM   #21
Gunnar155
Club: Palouse Region R/C Flyers
Friends: (9)
Very Nice!
Gunnar155 is offline
Old 01-04-2012, 02:16 PM   #22
trumps1
that is looking fantastic mate, looking forward to following the rest of your build!
Craig
trumps1 is offline
Old 01-04-2012, 05:05 PM   #23
CarreraGTSCS
Here are the pics of the Tripe that I took at the NEAT Fair last September. Beautiful model. Yours is coming along very nicely.
ID:	156089   Click image for larger version
Old 01-08-2012, 05:52 PM   #24
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Thanks for the pictures. Hope mine turns out that well.
Craig
Thanks for the kind words. It is a great kit and a lot of fun to build
Taylor
cobra 16 is offline
Old 01-11-2012, 09:28 PM   #25
cobra 16
cobra 16's Avatar
Club: Balsa Bees
Here is the latest. The Tripe is on its feet. The landing gear and skid have support. Pretty close to scale set up.
ID:	156310   Click image for larger version
ID:	156311   Click image for larger version
ID:	156312   Click image for larger version
ID:	156313   Click image for larger version
cobra 16 is offline
The VictorValley High Desert Flying Aces Rolling Thunder Informal Clubs 2929 09-29-2015 02:16 AM
Sold KAVAN Sopwith Triplane NEW IN BOX CarreraGTSCS Airplanes - Electric For Sale & WTB 4 11-18-2011 06:20 AM
New SGTalon Enteprise D for Clearview, FMS, RC Desk Pilot ggunners Flight Simulators 0 10-14-2011 10:12 PM
Solid experience on RC Model Lipo Battery Accident & Charger Guide SimonXi Batteries & Chargers 0 08-12-2011 06:08 PM
RCX Chicago Expo August 6th, 2011 LOST IN MN Events, Shows and Fun Fly's - Electric Airplanes 5 08-03-2011 04:16 PM
Page generated in 2.69946 seconds with 111 queries
