Old 11-28-2011, 08:24 PM   #1
simibill
General Factotum
simibill's Avatar
View simibill's Gallery34
Club: Simi Valley Flyers
Outstanding Contributor Award
Default heXTronik XT60 Connectors
Anybody have any experience with this connector? How easy is it to solder wires to?
Thanks,
Life's journey is not to arrive at the grave in a well preserved body,
but rather to skid in sideways totally worn out shouting, Holy Crap... what a ride.
simibill is offline
Old 11-28-2011, 09:50 PM   #2
constantCrash
prefectionist
constantCrash's Avatar
Send a message via AIM to constantCrash
I have experience un-soldering them I've replace a handful now with EC3's If i didn't already have a massive stock of EC3's both in use and in bags I would instead change my ESC's over to XT60's
I'm getting tired of having to un-solder xt60s and replacing them with EC3's on all my batteries.
Only thing I don't like about them is they still use heat shrink to hide the solder joints. EC3's / APP's are the only ones that don't need heat shrink.
I wanna be a pirate. Arrrrr
AMA - 885997
constantCrash is offline
Old 11-28-2011, 10:04 PM   #3
simibill
General Factotum
simibill's Avatar
Is soldering the connections like EC3's where you solder the wire to the connector and then shove it into the housing?
simibill is offline
Old 11-29-2011, 07:06 PM   #4
texasclouds
texasclouds's Avatar
View texasclouds's Gallery472
Friends: (12)
I tried the XT60 connectors. The solder side is like a bullet connector with half of the cylinder removed. Like a trough.
Yes, they are easy to solder, but I thought they were too difficult to get apart. I really had to tug on them. I went back to Deans style since everything else is Deans, and my battery supplier uses them.
texasclouds is offline
Old 11-29-2011, 08:33 PM   #5
Lubretepabrax
Banned
Default скачать кряк c
spam removed
Lubretepabrax is offline
Old 11-29-2011, 08:34 PM   #6
Old Fart
Lost at LAX
Old Fart's Avatar
Originally Posted by Lubretepabrax View Post
Spam removed.
And for those of that don't read Klingon?
Jeff/LAX
(don't panic - I don't land the planes)
(but I've been known to lie.....)
Old Fart is offline
Old 11-29-2011, 08:39 PM   #7
Lubretepabrax
Banned
Default скачать патчи
spam removed.
Old 11-30-2011, 05:29 AM   #8
View CHELLIE's Gallery13
Friends: (326)
Buy the XT60 connectors with the wires already attached to them, it makes them a lot easier to install, if you get the connectors with out the wires attached, dont try to tint the ends first, it will make the job more difficult, just push the wire into the connector, add a little rosin core flux on the wire then solder into place, the helping hand from Harbor freight tool works great, it also acts like a heat sink to keep the plastic from getting to hot. hope that helps, Chellie
http://www.harborfreight.com/helping-hands-319.html
the XT60 connectors are a lot better than the Dean connectors IMHO much easier to put together and pull apart, and i think they are rated at 60 AMPS
Old 11-30-2011, 03:41 PM   #9
simibill
General Factotum
simibill's Avatar
Buy the XT60 connectors with the wires already attached to them, it makes them a lot easier to install.
Where can I buy with wires attached?
simibill is offline
Old 11-30-2011, 06:59 PM   #10
Past President of PSSF
Friends: (8)
Here they are
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
I find the XT60 s very easy to use and separate, if you are having trouble pulling them or other connectors apart, try putting a little dielectric grease or Vaseline on them
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 11-30-2011, 07:08 PM   #11
simibill
General Factotum
simibill's Avatar
OK, got 'em. Thanks
simibill is offline
Old 11-30-2011, 07:33 PM   #12
constantCrash
prefectionist
EC3's are by far the easiest soldered connector to assemble. the solder on the bullets OUTSIDE the connector, and then they snap into the connector from the back. you do each bullet separately so your not working in that tiny space between two wires and can significantly reduce the chance of shorting out a battery when doing it.
Here's a video:
AMA - 885997
Lipo - bullet connectors: RONALDO_UK Beginners 8 10-24-2011 09:53 PM
Lipo connectors - bullet/banana: RONALDO_UK General Electric Discussions 6 10-21-2011 10:23 PM
What's the best connector? I hate Deans. mclarkson General Electric Discussions 57 10-16-2011 01:19 AM
Watts Up Power Meter Connectors MDEvil Power Systems 3 06-25-2011 12:35 AM
Most Mysteries About Connectors Solved jim81 Beginners 2 02-09-2011 05:54 PM
Page generated in 0.15997 seconds with 40 queries
