Old 12-01-2011, 12:10 PM   #1
View mclarkson's Gallery26
Friends: (8)
Default Blue FFF Sopwith Triplane scratch build
After an unexpected level of success with my very first scratch build, I've decided I have to try it again. I'm starting this thread to hopefully provide me with some incentive to actually finish the thing.
I'm gonna try a 1/12 scale Sopwith Triplane, using another sheet of blue DOW fanfold foam.
Wingspan will be 26.5". Gonna bend undercamber wings.
Power plant will probably be a 2712-12 or 2712-17 pushing an 8" prop.
No idea how the to hook up six aileron's or, indeed, how best to attach the wings.
ID:	155225   Click image for larger version
Old 12-02-2011, 06:37 AM   #2
Friends: (8)
Gonna try using bamboo skewers as spars, mounted flush to the leading edge of all the wings.
Old 12-03-2011, 02:13 AM   #3
Love my Stinger
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (16)
looks like its going to be a neat build. I am eager to see how it goes
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Old 12-03-2011, 07:27 AM   #4
Friends: (8)
I finished up my first 'test' wing. I actually broke it by accident so I'll probably recut this one once I figure out what I'm doing. Ailerons are only attached with some Scotch tape at the moment.
Old 12-07-2011, 05:50 AM   #5
Friends: (8)
All three wings, cambered and shaped with LE spars on.
Still noodling about how I'm gonna do the fuselage and cabanes.
I'm thinking of trying to build the ailerons like the attached renders - similar to those single servo aileron linkages, but hooked directly to two servos which are set into the fuse at wing level.
Or not...
Name:	aileron setup02.JPG
ID:	155362   Click image for larger version
Name:	aileron setup03.JPG
Old 12-08-2011, 04:32 AM   #6
Love my Stinger
Fishbonez's Avatar
Friends: (16)
Looks good. very interested in how you got the curve in the wings.
Old 12-08-2011, 05:06 AM   #7
Friends: (8)
Mainly with my fingers, just running up and down the wing, pinching and pulling, over and over again, until the matched the shape of the 'ribs' I cut out.
My first effort, using the rounded edge of a table, resulted in a cracked wing. So I moved to my current method.
Old 12-09-2011, 07:19 AM   #8
Friends: (8)
Roughing in the layout of the components. The mono-block 3D puzzle approach worked so well for the last plane that I'm going to try it again.
Old 12-10-2011, 07:26 AM   #9
Friends: (8)
Ordered my parts from Headsup today:
  • HURC 2712-17 Outrunner Brushless Electric Motor
  • Emax Budget 18 Amp Brushless Motor ESC
  • 4x 8g EMAX ES08A Sub Micro Servo
  • 2x 6" SERVO EXTENSIONS
  • Prop Adapter for 3.0mm shaft - collet type - small size
  • GWS 8060 Propellers TWO BLACK 8" Slow Fly Props
Old 12-11-2011, 03:48 AM   #10
Friends: (8)
Getting ready to cut out the compartments for the various components.
Did a quick test assembly to get a feel for the size and see what it's gonna look like.
ID:	155471   Click image for larger version
Old 12-11-2011, 05:23 PM   #11
Love my Stinger
Fishbonez's Avatar
Friends: (16)
Wow that looks very impressive I think you ar e going to have a blast. Piere is going to be very jealouse of this one and your moving a long at a great pace. I am eager to see how you hook up elevons for I have never seen it in a triplane before.
Old 12-11-2011, 07:55 PM   #12
Friends: (8)
So am I!
Old 12-14-2011, 06:11 AM   #13
Friends: (8)
After spending several days staring at parts and trying to decide how best to proceed, I've decided that the cabane struts are the key to the build, so I've built and installed them.
The cabanes and wing struts are made from 'craft sticks' - three per strut, as the sticks weren't long enough by themselves and I had to cut them apart and re-glue them in a longer configuration.
The cabanes are 1/2" longer than the wing struts, and will protrude through the bottom of the lower wing so I can build something to attach the wing from beneath. The landing gear will also attach to the bottom of the cabanes.
The cabanes are glued to the inside of the fuselage skin at a 64 degree angle, and fit in grooves cut into the mono-blok.
ID:	155522   Click image for larger version
ID:	155523   Click image for larger version
ID:	155524   Click image for larger version
Old 12-14-2011, 11:54 PM   #14
Love my Stinger
Fishbonez's Avatar
Friends: (16)
Looks like she is coming around nicely.
Old 12-14-2011, 11:58 PM   #15
Friends: (8)
It's so slow, it's killing me. I spend about 3 days staring and vacillating and agonizing for every hour or two of actual building.
My measuring/cutting skills are pretty poor, so I'm always nervous about big commitments like mounting the wings.
Old 12-15-2011, 12:52 AM   #16
Love my Stinger
Fishbonez's Avatar
Friends: (16)
Trust me your skills out weigh mine by far. I am the guy whi gets confused between 16th and 8ths and even 32nds at time and find myself counting lines LOL
As a very wiseman on wattflyer,Roadking or Joe, once told me. Take your time and go slow you will be glad you did as you already knkow the experience gained from it is priceless
Old 12-15-2011, 12:57 AM   #17
earthsciteach
LOVE the looks of your model! I'm anxious to see the finished product!
earthsciteach is offline
Old 12-16-2011, 06:22 PM   #18
7car7
7car7's Avatar
View 7car7's Gallery37
Friends: (12)
Your plane is really great looking, thanks for sharing it. You should post this in the WWI section.
Have you decided how to join up your interplane struts? My suggestion, if I may, is to make it one single strut, from lower wing to the top wing. I have a Great Planes Fokker DR1, and the interplane struts are a joke trying to keep stuff aligned being that they're separate. I'm making new 1 piece ones soon.
7car7 is offline
Old 12-16-2011, 10:08 PM   #19
Friends: (8)
Thanks!
I'm definitely making both sets of structs 1-piece. They'll pierce the middle wing, entirely.
I'm currently planning on using control horns to bolt the struts to the wing.
Old 12-16-2011, 10:16 PM   #20
Friends: (8)
A few more shots. Currently working on the upper fuse - turtle deck and battery cover, as well as figuring out how to mount the wings.
I've brought the cabanes all the way out the bottom to give me room to work up some kind of detachable mounting for the wing and the LG.
ID:	155576   Click image for larger version
ID:	155577   Click image for larger version
Old 12-17-2011, 09:51 AM   #21
Friends: (8)
A little more work while I try to figure out the wings.
ID:	155579   Click image for larger version
ID:	155580   Click image for larger version
Old 12-17-2011, 05:55 PM   #22
7car7
7car7's Avatar
Friends: (12)
Coming along nicely.
7car7 is offline
Old 12-22-2011, 10:55 AM   #23
Friends: (8)
Working out my aileron setup. It seems like it should work.
ID:	155712   Click image for larger version
ID:	155713   Click image for larger version
ID:	155714   Click image for larger version
ID:	155715   Click image for larger version
Old 12-22-2011, 07:37 PM   #24
Love my Stinger
Fishbonez's Avatar
Friends: (16)
Looks very cool
Old 12-29-2011, 01:33 AM   #25
offtom
Megans Servant
offtom's Avatar
View offtom's Gallery6
Club: Maggie Mae's Menagerie
WAA-08 Pilot
Plane is looking good.
Pilot needs a scarf though
Cheesy poofs are what Yankees get when they eat Southen Food!! bub, steve
offtom is offline
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 107 08-27-2013 12:23 AM
$100 Scratch Build Contest: Simple Pylon Racer Stevephoon Scratch and Kit Built Aircraft 57 01-19-2012 02:27 AM
First scratch build Aaeolien Scratch and Kit Built Aircraft 13 08-28-2011 04:30 AM
$100 Scratch Build Contest Best Build Thread hillbillynamedpossum Scratch and Kit Built Aircraft 2 05-17-2011 03:43 AM
$100.00 Scratch Build Contest: 60" Glider Propjobbill Scratch and Kit Built Aircraft 19 05-11-2011 05:08 AM
Page generated in 1.69841 seconds with 93 queries
